[ROM] [CDMA/GSM] Official CM10.1 (JB 4.2.2) [03/22: CAMERA FIXES]
3459 replies to this topic
#1 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
  • Twitter:Hashcode0f
Posted 25 January 2013 - 12:35 PM
POPULAR
[NEW 03/30] BUGTRACKER
CM10.1 / Jellybean 4.2.2 for the RAZR (XT912 / XT910)
*** IF YOU HAVE A GALLERY FC ISSUE, PLEASE TRY MOVING THE CONTENTS OF "DCIM" FROM BOTH SDCARD AREAS OFF OF THE DEVICE ***
NIGHTLIES FOR CDMA XT912:
NIGHTLIES FOR GSM XT910:
GAPPS:
(Use CM10.1 - 4.2.2 version at the top - 20130301)
CHANGES:
  • [03/22]Camera Improvements: Flash working
  • [03/15]Camera Code Rebase / Bugfixes
  • [03/06]BT/Speakerphone Fix (Thanks DHacker)
  • [02/17]CM-10.1 updated to 4.2.2
  • [02/17]Fixed ROM-SLOT booting for any slot (again)
  • [02/17]Fixed 2nd-cpu core (now working again)
WHAT'S WORKING:
  • [03/22]Camera
  • [03/06]BT
  • [01/18]MMS
  • [01/18]Incoming phone call bug fixed
  • Phone / 4G Data
  • Wifi
  • Display rotation has been fixed
  • Camera should work for images/video[/B]
  • GPS
WHAT'S NOT WORKING (NOTE: I expect to be able to fix all of these issues, it's just taking some time):
  • Gallery / Media FC see top of the post for FIX.
  • HDMI
  • Dock/Dock Settings
  • Some random reboots being looked at.
HOW DO I INSTALL?
  • Requires Safestrap 3.11 (has been tested in BMM I think also)
  • Download the .zip and place it on your SD card
  • Reboot into recovery, install the .zip file and GAPPS from here:
    (use CM10.1 version at the top)
  • I've always tested with a full wipe and TitaniumBackup restore of apps/data.
  • Enjoy
SCREENSHOTS COMING LATER
  • tankdroid, weaponx, ballsnaps and 34 others like this
#2 m0nk3y_ma17
m0nk3y_ma17
  • 14 posts
  • Current Device(s):razr
Posted 25 January 2013 - 12:43 PM
Looks like fun
#3 bjoestanley
bjoestanley
  • 75 posts
  • LocationGeorgia
  • Current Device(s):RAZR MAXX
Nice!
#4 perfoliate
perfoliate
  • 159 posts
Posted 25 January 2013 - 01:00 PM
Having issue updating installed Google apps in the play store resulting in unknown error code on install, also if I download voice same error. Non Google apps download and install fine. I did all wipes and 121212 gapps. Anyone else or just me?
Edit: A redownload and reflash of the ROM and gapps fixed my apps updating problem :)
BTW, its running super smooth. Nice work and thanks!
#5 Steeleio
Steeleio
  • 18 posts
  • Twitter:@steeleio
  • LocationColorado
Posted 25 January 2013 - 01:28 PM
Is it just me or is the external SD card not showing up? Anyway, running great and very smooth. Thank you very much Hashcode!
#6 perfoliate
perfoliate
  • 159 posts
Posted 25 January 2013 - 01:29 PM
Not for me either.
#7 littlewing745
littlewing745
  • 25 posts
Posted 25 January 2013 - 01:31 PM
Agreed. That's a big old "not working" :-)
#8 DemoManMLS
DemoManMLS
  • 269 posts
  • Twitter:AngryManMLS
  • Current Device(s):Galaxy Note 2
Posted 25 January 2013 - 01:34 PM
Getting the same thing for external SD card. When I check under Storage the "Mount SD Card" option is grayed out entirely. I took my card out and reinserted it back in. It did the usual scanning SD card and started to show it was mounting but then stopped halfway through.
#9 DemoManMLS
DemoManMLS
  • 269 posts
Posted 25 January 2013 - 01:45 PM
Weird. I just tried to do a logcat by taking out and reinserting my card. Right after I reinserted the card while ADB was running it then decided to mount. There's something very odd going on. Maybe someone else who might know more than I do can chime on in.
#10 tankdroid
tankdroid
  • 36 posts
  • Twitter:@Tank_oZ
  • LocationBirmingham, Alabamastan
Posted 25 January 2013 - 01:48 PM
Thanks Hash. Your a freaking machine!!
#11 DemoManMLS
DemoManMLS
  • 269 posts
Posted 25 January 2013 - 02:06 PM
Can someone test this for me - have your RAZR hooked to your PC and reinsert your micro SD card. Somehow I managed to get it to mount by doing this myself but I want to see if this works for others. I do have debugging enabled as well but no idea if that makes a difference.
At least on this build you'll have to do this step each time you reboot.
Also for those interested here's my Logcats:
<-- this one is when I reinserted without ADB running.
<-- this one is when I had ADB running when I reinserted.
Other things of note:
HDMI and Webtop as expected does not work at this point.
Signal meter at best stalls at around 2 bars for me. Occasionally it hits 3 bars but that's a rare at this point.
#12 tr1dent
tr1dent
  • 35 posts
Posted 25 January 2013 - 02:14 PM
I have been waiting for this for a while. Thanks!
#13 most
most
Posted 25 January 2013 - 02:42 PM
demoman mls it worked
  • DemoManMLS likes this
#14 cmh714
Posted 25 January 2013 - 02:51 PM
Just removing my SD and reinserting and it worked for me.
Yes, Dont get full bars...
#15 DemoManMLS
DemoManMLS
  • 269 posts
Posted 25 January 2013 - 02:55 PM
Weird. I tried to reinsert without my RAZR hooked to my PC yet it wouldn't fully mount the card. Hopefully with the logcats I have provided that should help hashcode and dhacker29 out a bit.
#16 sagrero88luis
sagrero88luis
  • 58 posts
Posted 25 January 2013 - 03:27 PM
Oh this will be reserved for future flash....oh any screenshots?
#17 livinitwarrior
livinitwarrior
  • 105 posts
  • Current Device(s):Droid Turbo 64GB, Nexus 7, Midnight
Posted 25 January 2013 - 03:54 PM
halleluujah! Dude, you made my day better. And I've got the flu.
edit: buttery smooth. The second this has a working camera, I'll probably be using this as my daily driver. Thanks for your hard work Hashcode.
#18 mattkilla
mattkilla
  • 187 posts
  • Google+:mattkilla420
  • LocationNorth Carolina
  • Current Device(s):Droid Razr Maxx xt912 , Samsung Droid Charge (FP8)
Posted 25 January 2013 - 04:11 PM
not too familiar with CM10.1 or much for that matter. someone share a few screenshots?
#19 perfoliate
perfoliate
  • 159 posts
Posted 25 January 2013 - 04:25 PM
Reinserted SD card worked for me also. No one else having issues updating Google apps? I might reflash.
#20 greek6486
greek6486
  • 209 posts
  • Twitter:@greek6486
  • LocationMaryland
  • Current Device(s):Razr Maxx
Anyone have a working notification light?
Sent from my XT912 using Xparent BlueTapatalk 2
