[Solved]Stuck on "WARNING BOOTLOADER UNLOCKED" after homemade-fastboot-flash failed
7 replies to this topic
#1 tehSpoke
tehSpoke
Posted 24 January 2013 - 06:12 PM
Hello,
I've decided to flash the 81.5.31002.Retail.en.GB homemade fastboot.
I'm a linux (Ubuntu) user, so I haven't used the FlashAndRoot.bat script, I just entered commands which were in the script :
fastboot flash system system.img.ext4
fastboot flash boot razr_i_boot_insecured.img
fastboot reboot
But now, it seems that my device doesn't appreciate this homemade fastboot, because he is stuck at the "Warning bootloader unlocked" screen...
I don't think that I did something wrong... I rather think it's because my device is "french" (I live in France) and I flashed a english homemade fastboot... But, I'm probably wrong... Anyway.
I'd like to fix this, but, I can't access to fastboot because... the button-combination (POWER + VolUp) doesn't work ! It's just rebooting again and again ! And even if I reboot it by myself (with POWER + VolDown while 6 seconds) and I quickly press on POWER + VolUp just after, it does anything.
So, what I have to do, now ?
Thanks.
P.S.: According to my build.prop (I did a nandroid backup before all of this sh*t), my build number is the following : 8.7.1I-110_IFW-31
So, I think that I've just flash a previous version... (I'm so stupid)
#2 tehSpoke
tehSpoke
Posted 25 January 2013 - 09:08 AM
After severy attempts, I did it ! I booted in fastboot mode... And, just after, I restored my backup...
So, the problem is solved. :)
#3 billah420
billah420
  • Google+:arifpatel95@googlemail.com
  • LocationBolton, England, UK
  • Current Device(s):Motorola RAZR i XT 890
Posted 06 April 2013 - 07:45 AM
I also have this problem. However, I am having problems getting in to the fastboot mode therefore I have no way of solving this.
Am i doing anything wrong to get into the fastboot mode as i am trying the normal method, by turning off the phone and then pressing the volume down and power button together.
All HELP will be appriciated....
THANKS....
#4 snives
snives
  • 947 posts
Posted 06 April 2013 - 08:13 AM
THANKS....
Any chance you are posting in the wrong place? Your profile says you have an XT912, but this thread is for an XT890. For the XT912 Power + VolDown is a simulated battery pull, Power + VolUp + VolDown is the boot menu.
#5 billah420
billah420
Posted 06 April 2013 - 08:28 AM
My appologies... That was a typing error... I have a Motorola Razr i XT890. I did have a Razr XT912 previously which is why i probably typed XT912 without realising.
Thanks for pointing that out to me...
I have just tried going into fastboot mode again a few time but no luck. It just keeps bootlooping to the warning booloader unlocked screen over and over again even while i have the volume down and power button pressed...
#6 koolwilliam
koolwilliam
  • Twitter:koolwilliam97
Posted 06 June 2013 - 12:07 AM
I have the same but on mine I have the logo then the warning.
I have been looking for how to fix for 2 days now.
#7 JC2life
JC2life
Posted 10 August 2013 - 10:34 AM
Is no way to fix this? I have the same problem and I can´t to access to Android.
JCXT890
#8 JC2life
JC2life
Posted 11 August 2013 - 04:25 AM
Ok I contact directly to tehSpoke and he explained to me all... my mistake, don´t left the power button when the gren led turns on.
