Problem on XT907 ... Need help please
4 replies to this topic
#1 MohAbs
MohAbs
Posted 02 November 2015 - 07:38 AM
My XT907 show messages ( Unfortunately, "all apps" has stopped )
I tried to do data factory reset and cache partition wipe but my phone stayed the same before factory reset and pattern stayed and don't deleted
Also, I tried to flash FXZ rom ( VZW_XT907_4.4.2-KDA20.62-15.1_1FF.xml and VZW_XT907_4.4.2-KDA20.62-10.1_CFC_1FF.xml.zip ) but pattern and messages still
Please any one can help me...
#2 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 02 November 2015 - 08:40 AM
Are you sure the files flashed correctly? I would reflash the latest firmware because it seems like the flash didn't work. What program did you use to flash?
Sent from my XT1575 using Tapatalk
#3 MohAbs
MohAbs
Posted 02 November 2015 - 09:10 AM
Flashed through RSDLite6.1.4 with no errors and tried flash through HouseOfMoto
#4 MohAbs
MohAbs
Posted 02 November 2015 - 09:20 AM
Are you sure the files flashed correctly? I would reflash the latest firmware because it seems like the flash didn't work. What program did you use to flash?Sent from my XT1575 using Tapatalk
I tried this (VZW_XT907_4.4.2-KDA20.62-15.1_1FF.xml) I think this the latest firmware for XT907 if avaiable another firmware after this please tell me and any idea for this problem ... Please
#5 thewraith420
thewraith420
    Crack Flasher
  • 112 posts
  • Current Device(s):XT907 jbbl Blisspop
Posted 03 November 2015 - 06:45 AM
Do you know how to use fastboot? You could
fastboot erase userdata
And
Fastboot erase cache
Same thing as factory reset
Sent from my XT1060 using Tapatalk
