Maxx October system update 24.13.3/SU6-7.3
7 replies to this topic
#1 claps1775
claps1775
  • 596 posts
Posted 31 October 2015 - 03:08 PM
I took the update as why not. No way on getting root/unlock bootloader. Not sure what was updated. I clicked the link to learn more. Just showed what phones get updates. Will look more and see. Any one else get an update?
Sent from my XT1080 using Tapatalk
#2 claps1775
claps1775
  • 596 posts
Posted 31 October 2015 - 03:28 PM
Just a security update is all.
#3 savannahman
savannahman
  • 90 posts
Posted 06 November 2015 - 06:58 AM
I have XT1080M Dev, unlocked bootloader. I installed stock recovery to take update. Got error unable to take update. This has happened before with OTA's on this phone. I have had to flash with RSD lite. I used to be able to find the firmware online but it seems it's no longer available. any thoughts? anyone?
#4 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 06 November 2015 - 07:30 AM
If you have a Motorola account which you should having a dev edition phone, or you can sign up for one they are free. Bookmark this link because it is for the dev edition software, That way you will have a way back to the page after you create your account.
https://accounts.mot...recovery-images
Warning to people that DO NOT have a DEV Edition phone.  This firmware is for the Developer Edition Phone Only.
#5 savannahman
savannahman
  • 90 posts
Well here is the problem I still have root. I uninstalled Superuser SU pro and it went back to the standard version. But that is not showing up under apps in settings where i can delete it. All root apps are still functioning and rootchecker says I have root. I disabled superuser SU since I couldn't delete it and still, I have root. WTF???
#6 savannahman
savannahman
  • 90 posts
Posted 06 November 2015 - 10:29 AM
Interesting, I was able to take update by flashing back to obake-maxx_verizon-user 4.4.4 SU6-7 7 release-keysMSM8960PRO_BP_23255.132.81.00R then taking 2 OTA Updates. Re-flashed TWRP  recovery but there is something here not allowing the install of superuser SU. If I install SU in Google play there is a binary issue with no resolution. Consequently even though I have a dev phone and I am unlocked, I cannot get root access. Could this be part of the 24.13.3 update?
#7 savannahman
savannahman
  • 90 posts
Posted 06 November 2015 - 11:20 AM
Nope, I had the wrong TWRP installed. got root.
#8 shawnlee6184
shawnlee6184
  • 118 posts
Posted 06 February 2016 - 02:38 PM
Any new firmware for security update 24.7.3obake maxx and working fastboot to stock ways? Rsd lite wont connect to phone when I go to flash stock firmwareCFCrkeys.zip. Can you flash CFC.releasekeys.zip from platform tools cmd on android studio if you put CFC files in platform tools folder and fastfboot flash each thing? Someway to flash xt1080 droid maxx so its able to root? Nothings worked so far. Any Recovery's(imgs) that work? Best way to fsstboot would be nice! I have firmware zip ready to flash. Thanks again
