I would like to introduce......
OverdriveAOKP
based off of DHacker's and Hashcode's amazing aokp rom
with some awesome speed tweaks by jp1044 and SPJESTER
Special thanks go to:
DHacker and Hashcode- for their sweet rom
jp1044- for his speed tweaks, server space, help, and patience
SPJESTER- for his cool speed scripts
DustinB- for his cool icons. Check out his Cobalt themes in the play store!
Thepatriotvirus- for testing this for me
Rootuser94- for letting me poke around in his files and use some
timmy10shoes- for his governors, schedulers, and script
Here are the screenshots:
78.21KB 977 downloads 39.19KB 945 downloads
60.14KB 940 downloads 27.04KB 905 downloads
How to install:
Download the rom
Wipe data and cache
Flash Overdrive
Enjoy!
Older V1.x Changelogs:
V1.3 Changelog:
fixed circles widget bug
added beats audio
overclock with tweakerz and extra modules
Older V2.x Changelogs:
V2.5 Changelog:
Updated with dhacker's and hashcode's JB-MR1 Build 6 build
Added more custom icons
Forgot to add beats back in(oops haha). If someone wants it, i will up a flashable
Please flash this in slot 2
V1.2 Notes:
if you want the circles widget, launcher does not take on install. you need to go to system/app and reinstall razri_homescreen app over the old one to make the widget work.
V2.0-V2.4 Notes:
First and foremost, thanks for the awesome update hashcode and dhacker!
This version must be installed in slot 1, otherwise it will not work!
After initial startup, you will get a black screen. Hold the power button for 3 seconds and release. You will get a popup saying that setup is not responding and do you want to close. Tap ok and everything will go back to normal.
You will need to do a full wipe before installing this version.
Enjoy!
V2.2-V2.4 notes:
In order to use the circles widget, you MUST select homescreen when asked which launcher to use.
Using the GPS toggle in the quick settings for homescreen will cause a fc, you will need to toggle it in system settings.
4.1 Roms:
version 1.0
version 1.1
version 1.2
version 1.3
4.2 Roms:
version 2.0
version 2.1
version 2.2
version 2.3
version 2.4
version 2.5
V2.3+ Bugs:
Known bionic jellybean bugs
microphone not working on speakerphone
Please enjoy it, and let me know what you would like to see in future releases!
