Gsm Xt910 Razr Utility
Posted 08 February 2012 - 01:18 AM
Full Version (Fastboot Files Included)
MD5: decc8d963b18062ce299144e50de5a29
Link:
LITE Version (No Fastboot Option)
MD5: c3ec091570e6a28d45f6944d5fdf7892
Link:
Enjoy my XT910 friends~!
Feel free to donate to my Razr Dev fund if you wanna help out
- Ramdanih, kent_lkc, coolwire and 1 other like this
Posted 08 February 2012 - 05:16 AM
Posted 08 March 2012 - 09:25 PM
- rebeldia15 likes this
Posted 29 March 2012 - 12:02 PM
Posted 22 May 2012 - 11:39 AM
Posted 29 June 2012 - 05:54 PM
AP Fastboot Flash Mode (S) (Flash failure)
0A.6B
Battery OK OK to Program
Transfer Mode:
USB Connected
I downloaded this program, done all the things he said to do but the script seams to stop when writing recovery, nothing appens... what now?
Posted 29 June 2012 - 08:03 PM
you need to boot into ap fastboot and not this screen, if all else fails, cut open the micro usb cable (at the smaller end) then take out the red and black wire inside of it, after that, open the back of your razr, unscrew the battery then screw the red wire under the + side and the black at the - side, plug the usb into your wall charger and charge using that, make sure to check at times if the phone is getting warm.Hello, i have the problem: AP Fastboot Flash Mode (S) (Flash failure) 0A.6B .... Battery OK OK to Program Transfer Mode: USB Connected I downloaded this program, done all the things he said to do but the script seams to stop when writing recovery, nothing appens... what now?
Posted 19 August 2012 - 05:26 AM
Could you please refresh the links; they are empty.I've ported by Razr UTILITY to the GSM XT910 Razr. I added restore files to 651.73.30 EUAustralia version... I am not familiar with which XT910 fastboot files work on which devices for nations, but hopefully I chose a good one. I am uploading 2 of them, 1 with no fastboot and just has other functions.
Link:
Link:
- rec.127 likes this
Posted 24 August 2012 - 03:37 AM
+1 bumpCould you please refresh the links; they are empty.
Posted 25 August 2012 - 10:57 AM
+1 bump
Please, refresh the links.
Posted 26 August 2012 - 08:47 AM
You can find firmware for RSD Lite use here:
Posted 26 August 2012 - 08:56 AM
Although I don't have the update yet
Posted 02 September 2012 - 08:21 PM
Posted 22 September 2012 - 05:00 PM
Posted 22 September 2012 - 05:07 PM
Outdated and likely only to cause bricks at this point since most Razrs are at a higher secure version.Is this still available?
Posted 22 October 2012 - 11:14 PM
Would you place a file once again?
Posted 28 December 2012 - 03:48 PM
If I flash another gsm kernel would it work? Or because of cid, just my region kernels?
Posted 19 March 2013 - 04:53 AM
Posted 19 March 2013 - 06:18 AM
- have french firmware (i'm from the Netherlands and like my OSes in English, so as long as the firmware supports English i don't care where its from)
- rooted
- got OTA update to 4.1.2
- update fails
- unfreeze and recover everything i removed with titanium backup
- still fails
- turns out it failed because i installed a custom bootloader animation, and i lost the original one
- use droidrazrutility to "recover factory rom", but one that contains verizon firmware with cdma (well, $#!+. me and my stupid impulses)
- get bootloader menu with "flash failed" *nearly in tears*
... so should i return it for warranty and say the OTA got interrupted? is there some way to get working firmware on it?
Posted 19 March 2013 - 10:21 AM
i installed RSD Lite and flashed the right rom/firmware/SBF for my device with it.
make sure your battery level is > 50% or else you might need some soldering (special cable) to get that battery topped up again
(flash tool) rsd:
(firmwares) SBF:
