Can't flash stock rom.
Best Answer spainter , 07 October 2015 - 05:52 AM
Hello, so i have the problem about flashing stock rom. i tried to flash many stock roms but with no success. i also tried to flash newest rom for my phone but it stoppes and gives me system.img usb error. i also tried to flash rom which i had pastly but it cant flash some files (tz.mbn and boot.img. P.S This is last picture saved from my device. P.P.S i also tried to flash 9.8.1Q-94 rom but still with no success.
12077117_1056367957741718_999014381_n.jp
tz error indicates security violation.  The tz partition  has been upgraded at some point and is considering the flash as an attempt to downgrade.  Is your phones bootloader unlocked? USB error falls into the normal troubleshooting steps.  USB 2.0 port directly from the computer not a hub. Use a motorola cable that came with the phone not a 3rd party cable. Make sure you have the proper usb drivers from motorola not a universal usb driver. Flash the correct fxz file, The screenshot shows jellybean.  The latest file would be 4,4,2.183.46.15. That version is not unlockable if your not already unlocked so you should try to flash 4.4.2.183.46.10 first. if you get a fail to flash error there you will end up going to the .15 version.
Go to the full post
14 replies to this topic
#1 enzy1337
enzy1337
  • 11 posts
Posted 07 October 2015 - 05:07 AM
#2 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 07 October 2015 - 05:52 AM   Best Answer
  • enzy1337 likes this
#3 enzy1337
enzy1337
  • 11 posts
Posted 07 October 2015 - 08:14 AM
no my phones bootloader isnot unlocked. i dont have original motorola cable, i can not find normal download link for 4.4.2 183.46.10, but on the forums it shows me that 4.4.2 18.46.10 is for xt907 and my phone is xt926
#4 enzy1337
enzy1337
  • 11 posts
Posted 07 October 2015 - 08:17 AM
I already tried KDA20.62-10.1 and 15 too but i cant flash it. on 15 it goes perfectly before system.img flashing stoppes here and says usb error should i try to flash with original motorola cable?
#5 livinginkaos
Posted 07 October 2015 - 09:04 AM
You should always flash with the Moto Cable.  The other thing, are you using the proper platform tools?
#6 enzy1337
enzy1337
  • 11 posts
Posted 07 October 2015 - 09:12 AM
Thank you both for posting on this thread i will use original motorola cable. yes im using proper platform tools
#7 enzy1337
enzy1337
  • 11 posts
Posted 08 October 2015 - 02:52 AM
So i got original moto cable and this worked fine thank you for helping me.
  • soocold likes this
#8 saidsiddo
saidsiddo
  • 5 posts
Posted 13 June 2016 - 05:05 AM
Hi, can you please help me i got the same problem with my xt926. I can't flash it, it shows me failed when process to flash gpt.bin
i'm using rsd lite . the phone stucks on moto M logo and i can't even enter recovery mode but got access to fastboot mode. i can't charge it cause when i put it on charge the M logo still want move but my battery is full.
help help help please thanks :)
#9 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 13 June 2016 - 10:40 AM
What does the fastboot mode screen show exactly. Also the exact error RSD is giving you
#10 saidsiddo
saidsiddo
  • 5 posts
Posted 15 June 2016 - 06:50 PM
there is no change on the screen, but a flash of the written: usb connected. I was sleeping the day it gets stuck on the M logo, it was turned off and charged 100 per cent then i turned it on and turned the data connexion on too. after about 2hours (i did't touch it since i turned the data on) when i took it, it keeps on showing that apps are stopped (all apps even phone's) and then realised that even the sim card is missed (removed it self), i decided to reboot the phone by turning it off (normal turn off) but when i turned it on it stucks on the M logo. i can't get access to the recovery mode cause when the M logo vanish after entering recovery mode nothing is shown. even when i put it charge it stuck on the M can't show me the battery meter.
P.S: i used to flash it(because it was stuck on the electric cercle) using the same computer, the same usb cable.
Sorry for my bad English :-( and thanks in advance for helping :-)
#11 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 15 June 2016 - 07:52 PM
The one suggestion would be to setup House Of Moto 4.3 from here:
Follow the instructions exactly to set it up. Make sure you have the proper FXZ file and since you are unlocked I would flash the last version .15.
If it fails to flash the latest version and gives you the gpt error I am guessing that the memory module is gone bad.  If it is just a corrupt partition using HOM should straighten it out it uses fastboot commands to flash with.  There have been a lot of times it will work where RSD wouldn't.
#12 saidsiddo
saidsiddo
  • 5 posts
Posted 16 June 2016 - 05:01 PM
when i tried with rsd i got the gpt error. but i'm going to try with moto house i will report back the result
thanks a lot in advance
#13 saidsiddo
saidsiddo
  • 5 posts
Posted 21 June 2016 - 03:25 PM
Hi sir, i tried using house of moto as said but all processes return failure reports, all failed. What should i do now?
#14 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 21 June 2016 - 04:51 PM
I am afraid it is time to replace the phone. Fixing yours wouldn't be cost effective.
#15 saidsiddo
saidsiddo
  • 5 posts
Posted 21 June 2016 - 07:15 PM
Thanks for helping :-)
