Device stuck in boot loop, Unable to Re-Flash
Posted 22 September 2015 - 01:58 PM
Posted 22 September 2015 - 02:25 PM
HI,So things goes like this; few months ago my Motorola Razr maxx XT910 (India) stuck in boot loop. I did a lot of research for the solution of problem, then i found RSD Lite and compatible firmware for my device so i flashed my device through RSD lite from ICS (Asia) to jelly bean (EU).here is the file name ( cdma_spyder_9.8.2O-72_VZW-16_1ff.xml ) the firmware which i have used for flashing.Eventually everything was good but from few days my phone is going into the bootloop again but restarting making it boot properly. But today it is stuck in Boot loop and just looped......i did wipe cache partition and wipe data/factory reset from Recovery option but after rebooting it's again into boot loop. I tried RSD lite again to flash again from cdma_spyder_9.8.2O-72_VZW-16_1ff.xml this file but getting below error:Failed flashing process. 6/16 flash motoboot " motoboot.img " -> Phone returned faillet me know if you need any more info....Please help ....RegardsDevank
Try downloading the firmware again as well as make sure you are using the factory cable and your usb drivers are up to date and using a usb 2.0 port. The newest version of rsdlite is 6.24. You might also think about setting up House Of Moto 4.3 to flash with.
Posted 23 September 2015 - 11:54 AM
Hi Spainter, thanks for the reply
Yes i'm using the factory USB cable connected to and xtra extension coming from USB 2.0 port. As you told i have updated my drivers to 6.4.0 and a newest version of RSD Lite 6.2.4( but getting an error on 1st step ) so i have installed RSD Lite 6.1.5 getting same error on 6th step (Failed flashing process. 6/16 flash motoboot " motoboot.img " -> Phone returned fail)
so i have tried Houe of moto 4.3 and got this error (plz check attachment) even though its continued and finished .
now after boot loop Android bot coming with it heart open and some blue color wheel rotating in front of him then a lying on ground android bot with open heart and some red sign then again it goes into boot loop....
Posted 23 September 2015 - 01:16 PM
There is something wrong with the file you are trying to flash. What country are you in and what provider do you use?
Posted 23 September 2015 - 01:17 PM
Take a look at these two spec sheets.
Posted 24 September 2015 - 02:01 AM
I am in India and using service provider: Idea cellular
Posted 24 September 2015 - 02:17 AM
I am having this one
In india it is named as XT910
Posted 24 September 2015 - 03:33 AM
Try finding your firmware on this page
Posted 25 September 2015 - 10:29 PM
i guess the situation got worsen now as i'm facing more issues
Posted 26 September 2015 - 07:29 AM
Sent from my Android M N6
Posted 28 December 2017 - 05:34 PM
can any one give me working links to download utilities to repair this i tried liks but they dont work
Posted 28 December 2017 - 05:50 PM
A couple years ago the DCMA made a sweep and took a lot of sites off line that had the fxz files for these phones. The only thing I can suggest is use google and search the web for your model of phone + factory image files and looking that way. Most of us here have long since dumped the files for these older phones. I know the oldest phone I have files for are the droid razr maxx hd and that is because I still have a couple of them around that work.
