Motorola Droid Persistent Adb Shell Root
10 replies to this topic
#1 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 14 November 2011 - 04:52 PM
Now that we have some mod's and themes , There is one thing you are going to want to do to your razr. this is the Echo hack . What is does is allows you to gain su with out typing su. In other words it puts your phone it root in adb without you having to type it. You will need this if something goes wrong and need to enter BP tools. TRUST ME, LOL
Thank you @p3droid and @Djrbilss for this.
1) connect phone to computer
2) open command prompt
3) type ---> adb shell
3) type ----> su (at this point if you have not done adb keep phone awake and hit allow for su)
4) type ----> echo "ro.sys.atvc_allow_all_adb=1" > /data/local.prop
5) type ----> reboot
Now anytime you enter your phone from a command promp it will have root access. To test this out when connected to your computer in a command window you should be able to type adb remount. Or when you type adb shell you should see a # after spyder not a $
You can find the original thread
  • PillClinton, mines_01 and ibolski like this
#2 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 03 January 2012 - 07:26 PM
Thanks for this!
#3 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 17 January 2012 - 11:32 AM
Quick question: Is there any way to run this hack (or something similar) so that the
will always open with root permissions, without having to type "su?"
#4 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 17 January 2012 - 01:23 PM
This should work in terminal also. I've tried it. The problem is after a reboot it does not work anymore. I think the problem lies in , how the razr boots different. I believe I can alter the hack so that it does work properly. I will get back to you on this.
#5 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 17 January 2012 - 02:42 PM
Thanks for the response, stoked to see what you come up with!
#6 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 04 February 2012 - 07:49 PM
Hey DDX, any luck with this? You may want to consult DT on this one, on one of his Bionic roms, I'm pretty sure his terminal automatically opened up with root. I don't recall exactly which rom it was from though!
  • bogginblazer likes this
#7 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 05 February 2012 - 01:00 PM
U no what I did figure it out. I will post it later on
  • PillClinton likes this
#8 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 05 February 2012 - 02:11 PM
Cool, thanks!
#9 mestisso79
mestisso79
  • Twitter:@mestisso79
  • Google+:mestisso79@gmail.com
Posted 05 March 2012 - 08:12 AM
helloI dideverything righthasdeniedPermissions :angry:
#10 _base2
_base2
  • 810 posts
Posted 15 April 2012 - 10:25 AM
Are you rooted? We need additional details...
[ sent from _base2 ]
#11 ssmaynv
ssmaynv
  • 243 posts
  • LocationLas Vegas
Posted 17 April 2012 - 09:01 AM
This works for me for 1 reboot only. Meaning, if I perform these steps and reboot, I have root access in "adb shell" and can "adb remount". If I reboot a second time I lose automatic root access in adb and have to enter the echo command again and reboot. It's a viscous cycle.....In my best "Fat Bastard" voice....
I reboot because I don't have access.......I don't have access because I rebooted.
