XT910 White LED and nothing else
4 replies to this topic
#1 marsamgod
marsamgod
Posted 28 August 2015 - 12:27 PM
Firstly apologies if this has been posted before but I was given an XT910 via a house clearance.
When I plug it in via the PC usb bock all I get is a white LED, nothing seems to boot the thing up, I have a factory cable and no amount of button pressing and/or swearing seems to get it to do anything.
Is it worth trying to repair or shall I just toss it in the bin?
#2 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 28 August 2015 - 02:46 PM
Try plugging it into a ac wall charger for a few hours. Watch it and make sure it doesn't get hot.  The battery may be dead or has gone bad from sitting.  If nothing changes or it starts to get hot you will have to change the battery.
#3 marsamgod
marsamgod
Posted 28 August 2015 - 03:27 PM
Charged it for 4 hours earlier, no heat from battery and still nothing, guess it's a new battery then, thank you for the reply
#4 sibujacob
sibujacob
  • 7 posts
  • Locationkuwait
  • Current Device(s):XT910
Posted 03 September 2015 - 09:10 AM
Probably there is no software installed....Droid XT910 and XT912 Razr phones do not charge without an operating system
#5 05LEVY
05LEVY
  • 17 posts
  • LocationSouth Texas, USA
  • Current Device(s):Droid Razr Maxx HD, Droid Razr
Posted 16 September 2015 - 12:12 PM
Little late but yes, you might have a battery problem. My razr does the same thing if I allow the battery to fully discharge. It will came back to life after about 5 min. of charge, every time.
Note: It will not turn on with the power charger only, it needs the battery so, if you have a bad battery, then it probably will not.
Good luck!
05LEVY
