Bootloop
Posted 05 February 2012 - 06:39 PM
Thanks in advance
Posted 05 February 2012 - 06:53 PM
It seems I have put myself in quite a horrible situation.... I heard if you fastboot the phone that it will return it to its original state. I am currently using the rogers version but heard there isn't a fastboot package available for my phone and that some people have used the BR version.
Thanks in advance
What is a br version?
Donate $10 or more to our Phones For Devs Giveaway and get a Custom Forum title and help the Make a wish Foundation details here: http://www.droidrzr....-custom-titles/
Posted 05 February 2012 - 06:56 PM
BR usually refers to Brazilian.
- mattlgroff likes this
Posted 05 February 2012 - 07:01 PM
Look for the BR fastboot files at xda-developers.comBR usually refers to Brazilian.
BR definitely is Brazil.
Posted 05 February 2012 - 07:03 PM
Posted 06 February 2012 - 02:02 PM
I know a few people have been able to use the BR fastboot files, just make sure they are not the Vivo ones as they apparently do not work that well. USe RSD lite and point it towards the xml file and it should fix the phone.It seems I have put myself in quite a horrible situation.... I heard if you fastboot the phone that it will return it to its original state. I am currently using the rogers version but heard there isn't a fastboot package available for my phone and that some people have used the BR version.
Thanks in advance
Posted 06 February 2012 - 02:06 PM
I have found two tutorials so far that might be able to help me one is using RSD and one doesn't.
ses RSD lite but when I install the adb tool and ask which program to install it doesn't have android 2.3.5, only 2.3.3. So I'm a little iffy about using that
The other tutorial is
This one seems a lot simpler, I was wondering if you could give me some feedback on which one to do
Posted 06 February 2012 - 03:59 PM
- 13i11 likes this
Posted 06 February 2012 - 06:15 PM
I have also found this solution seems relatively simple.
Posted 06 February 2012 - 06:46 PM
Sent from my.....whichever phone I am using at the moment with Tapatalk
Posted 06 February 2012 - 06:48 PM
Posted 06 February 2012 - 06:51 PM
Posted 06 February 2012 - 06:55 PM
Posted 06 February 2012 - 07:04 PM
When the AP menu flashes up it should have a list that tells you if the battery is ok, USB cable connected, if you aren't seeing that you may be a little fubared right now. What charge did your battery have when you flashed whatever caused this?
Posted 06 February 2012 - 07:10 PM
Posted 08 February 2012 - 01:38 PM
Posted 08 February 2012 - 05:10 PM
Posted 09 February 2012 - 03:56 AM
