ADB sideload vs. fastboot flash
xt926 adb sideload fastboot
2 replies to this topic
#1 yeshaya86
yeshaya86
  • 15 posts
Posted 21 July 2015 - 01:16 PM
Hi, I've been recently trying to to flash a stock firmware onto my soft-bricked, stock, locked, not-rooted, Droid Razr HD XT926- running (or was running) 4.4.2. Whenever I've tried to to flash a firmware I've gotten errors along the lines of:
"07/07/15 22:19:11  [Device ID: 0] 1/17 flash partition "gpt.bin"
07/07/15 22:19:12  ERROR: 1/17 flash partition "gpt.bin" -> Phone returned FAIL. - on device ID 0.
07/07/15 22:19:12  [Device ID: 0] 1/17 flash partition "gpt.bin" -> Phone returned FAIL.
07/07/15 22:19:12  ERROR: Failed flashing process. - on device ID 0."
My stock recovery has an ADB sideload option, which allows me to flash update.zip files via my computer. With fastboot, I've been trying to flash the "VZW_XT926_4.4.2-KDA20.62-15.1_1FF.xml.zip" firmware, from drdev.com. If I wanted to try to flash it with ADB, would I just put the phone in sideload mode, rename the file to "update.zip", move it to my current directory, and call "$adb sideload update.zip"? I haven't been able to find much documentation on sideloading, and I assume that whatever is causing fastboot to fail would mess this up too, but I'm pretty much at the end of my rope with this and running out of things to try. Is there any chance that adb would work where fastboot doesn't?
Thanks so much,
Yeshaya
#2 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 21 July 2015 - 04:07 PM
Thanks so much,
Yeshaya
You can't flash the firmware zip via adb sideload.  You have to use fastboot and enter each command that is iisted in the xml file in order or use rsdlite which uses the xml file or house of moto which creates its own script. If it is not flashing with any of the tools and your getting the same error every time and you have ruled out a driver or cable issue then the last thing would be a hardware failure.
#3 yeshaya86
yeshaya86
  • 15 posts
Posted 22 July 2015 - 04:31 AM
Thought so :/ guess I'm out of luck then, thanks so much for the help.
Yeshaya
Also tagged with one or more of these keywords: xt926, adb sideload, fastboot
