Okay, so I used RSD lite not sure if that matters, much of what I have seen/read shows people using the computer Moto-poc to flash trwp is this what I should? And should I flas .15 before trwp?
Having problems Rooting and unlocking XT-926
#21
Posted 22 July 2015 - 05:06 PM
#22
Posted 22 July 2015 - 05:15 PM
I would do the update to .15 first that way you only have to flash twrp once since the update will overwrite it when it is flashed. Or if you want to setup java and get some experience with HOM you can do that as well. It comes down to what you are more comfortable with. Using tools is great but if you get into trouble it is always best to know how to do it completely manually. After this is all finished it would be a good idea to look at the xml file that came in the fxz files. That is a list of commands that rsd uses to do what can be done one command at a time from fastboot. It is a good thing to know, I do most of my flashing command by command unless I am in a hurry. With the tools you don't have to check each line for errors, syntax and typos before you hit enter each time.
#23
Posted 22 July 2015 - 05:41 PM
Alright, Forgive my ingnorance but where to do I find snapdragon tools, I have searched but most of all I see is for qualcomm.com
#24
Posted 22 July 2015 - 06:33 PM
#25
Posted 24 July 2015 - 03:17 PM
Thanks, so when I download the .15 file I put that in the snapdragon windows folder, hold shift and right click, open command window and type fastboot flash recovery twrp-2.8.6.0-xt926.img
#26
Posted 24 July 2015 - 03:42 PM
Hit enter and it will flash. when it is done unplug the phone hold the volume down and power to boot back to the bootloader select recovery and load recovery. don't let it boot normally or it will overwrite the twrp recovery and it will look like nothing happend and didn't flash. That is only for the first boot after flashing twrp. After that twrp makes changes to the system and won't let it overwrite it. if it does boot normally you will have to flash it again. let twrp root the phone on exit. Download SuperSU from the playstore and run it after install it should tell you the binaries need to be upgreaded. select the normal upgrade and you should be done.
You use rsd or House of moto to flash FXZ files. Fastboot to flash twrp. You flash the .15 fxz file just like you flashed the 183.46.10.xml.zip. then after a sucessful boot into the system you will go to fastboot and flash twrp. That is when you don't let it reboot to the system after flashing twrp. You boot back to recovery, then hit the reboot system button inside twrp. That is when it will prompt you to root your device and you will swipe the arrow to confirm the action after that follow the script when it boots and you will be updated, rooted and unlocked. There is one more trick to show you but that will come later if you need to use it. Let me know how it goes.
#27
Posted 24 July 2015 - 03:47 PM
Sorry,I didn't mean to type .15, I meant when I when I flash the twrp. I put the twrp file in in the snapdragon folder, and do the above. I'll let you know, thanks agian.
- spainter likes this
#28
Posted 25 July 2015 - 09:46 PM
Well everything appears to be good to go. 4.4.2, System .15, and root checker shows I'm rooted. Thanks again for all your help. What was that last trick you were talking about? Or is that not needed since everything looks good on my end.
#29
Posted 25 July 2015 - 09:59 PM
With Kitkat there was a change in how the OS handles the external sd card. This is how you fix the issue if you run into it. I did on both of my 926's and edited the platform.xml file and that took care of it. Make a copy of that file so if you ever have to unroot you can copy that back it to the proper directory and don't overlook the part about setting the edited file properties.
#30
Posted 07 August 2015 - 09:59 AM
Great info here spainter! My Razr Maxx HD (just got it, no personal data to save) is still on the non-unlockable 9.18.94. All I've done to it is change the VZW update file extension so it stopped trying to install the 182.46.10.en.us update (it's unlockable right?). I also edited the NV Item 8322 and changed the value of the first byte from 01 to 00 to unlock carrier Should I let it download and install the 182.46.10.en.US, then Lambda root and Motopocolypse unlock? Then fix the SD card issue (can't move apps to it right?).
Oh yeah, then install a custom recovery software? Does anyone use clockwork mod anymore?
I flashed CM7 on a few Moto Backflips years ago, but I'm out of the loop now.
What would you do with an XT926 on 4.1.2 it if it was yours?
Is there anything that was in Jelly Bean that was lost with KK that you really miss?
Thanks so much!
#31
Posted 07 August 2015 - 11:20 AM
Thanks so much!
I have two 926's here on my desk. Both unlocked and sitting on the latest version of kitkat. They are still workable phones but I use them to try to duplicate errors and problems. The only thing I really missed was the way it handled the sdcard. Now though they are the only two phones I own that even have a sdcard slot it them. So I really don't miss JB at all.
#32
Posted 12 August 2015 - 11:48 PM
#33
Posted 13 August 2015 - 12:15 AM
You can't, not with that ROM version, not with any existing methods.Pls have rooted..help me to unlock it 4.4.2 version 183.46.15
Just install Titanium Backup to remove bloatware, Xposed Framework with GravityBox for customization, and Nova Launcher, and it'll be close enough.
- eric09 likes this
#34
Posted 13 August 2015 - 12:37 AM
boss exposed framework how?? Cos I don't have cwm or twrp to flash ..pls how did u do itYou can't, not with that ROM version, not with any existing methods.
#35
Posted 13 August 2015 - 12:40 AM
You don't need a custom recovery or any flashing to install it on KitKat.
Also tagged with one or more of these keywords: root, unlock, droid razr hd, xt926, xt-926
