Hi, Can someone tell me if my Verizon XT926 is unlock able to use with my Cricket account and if so point me in the right direction...this is really pissing me off I want to be able to use my Razr HD again.
Droid Razr HD with Cricket
Posted 18 July 2015 - 02:48 PM
Posted 18 July 2015 - 03:29 PM
It looks like Cricket has stopped supporting CMDA phones earlier this spring. But here is a url to see if it is compatible:
Posted 19 July 2015 - 08:40 AM
Spainter thanks for the link I'm new to this phone stuff although I have had a lot of experience with satalite hacking. Cricket says the phone is conpadible but it has to be unlocked. Can u point me in the right direction on how I can unlock this phone? Thanks for the reply.
Gene
Posted 19 July 2015 - 09:05 AM
Gene
By the way don't buy an unlock code from 3rd party sites. Here is some reference material.
- scudkel likes this
Posted 20 July 2015 - 02:57 PM
Looks like these two Razr HD phones are paper weights. I didn't find anything that says it will work with last years update, Thanks for the help!
Posted 20 July 2015 - 03:17 PM
Did you look through this thread?Looks like these two Razr HD phones are paper weights. I didn't find anything that says it will work with last years update, Thanks for the help!
Sent from my Nexus 5
- spainter likes this
Posted 16 September 2015 - 05:35 AM
Yes, it's possible. You need cdma workshop to unlock the sim. PM me if you are still interested and I can assist. I've been using Cricket for 6 months. LTE does not work on this phone with Cricket. You need to freeze "Modem Fastdormancy". No issues at all. I have four XT926 on Cricket.
