I have a Droid Maxx Dev, unlocked bootloader. It took some doing but I was able to get the verizopn update 24.13.2 on the phone. Went back to install TWRP and it was installed sucsessfully, or was it? When I boot into recovery I get the droid guy on his back and it says "no command". I have tried everything I can think of but still the same. No custom recoverey no root, big problem. Can anyone help?
Need Help, Droid Maxx Dev cannot install custom recovery
Posted 04 June 2015 - 06:00 AM
Posted 04 June 2015 - 06:59 AM
Flashed several TWRP recoveries, finally got it with 2.8.6.0
- shane1, spainter and vakharia like this
Posted 16 June 2015 - 12:16 AM
I assume you are using fastboot to do this.
Can you also share the commands that you used?
I will be flashing TWRP this week.
- deijah2013 likes this
Posted 16 June 2015 - 03:26 PM
fastboot flash recovery <filename>.img
Posted 16 June 2015 - 03:36 PM
You have to be bootloader unlocked to flash a custom recovery. If you are bootloader unlocked TWRP will give you the option to root as it after it installs. Also note that after flashing TWRP you must unhook and reboot directly back into recovery. If you let it boot normally the stock recovery will over write TWRP and it will appear that the flash didn't work. You will have to flash it again and make sure it doesn't boot the system (normal boot.).
http://www.droidrzr....-unlocked-only/
Posted 19 June 2015 - 04:59 AM
I managed to do this over the weekend.
Thanks.
Phone works fine on OctOS.
- spainter likes this
Posted 06 February 2016 - 02:39 PM
Posted 06 February 2016 - 02:44 PM
