848 replies to this topic
#141 kprice8
kprice8
  • 14 posts
Posted 16 January 2013 - 04:02 PM
/kick me in the arse. I am such a douche. Sorry djrbliss..
That will teach me to not read everything and post... Dang.
  • Memnoch73 likes this
#142 Redalert
Redalert
    Half Man, Half Amazing
  • 1,198 posts
  • Current Device(s):Note 3 / Razr Maxx / Droid2 / LG Ally / Moto Q / Nexus 10
Posted 16 January 2013 - 04:54 PM
Razr Blade, an exploit that gains root access on the Motorola Droid Razr running 4.1 (Jelly Bean), is available at:
To run the exploit (currently Windows only), download and extract the entire zip file, ensure your device is connected via USB, ensure you have the latest Motorola USB drivers installed, ensure USB debugging mode is enabled on your device, and double-click "run.bat".
PLEASE FOLLOW THE DIRECTIONS IN THE EXPLOIT CAREFULLY.
Please do not re-host or modify this exploit without asking permission first, since this makes support difficult and annoying.
Enjoy,
Dan (@djrbliss)
Thanks Man
Paypal:
#143 Samsonite79
Samsonite79
Posted 16 January 2013 - 06:29 PM
You gotta uninstall the update not install the update and/or clear the smart action app data :blink: If that fails then try the full factory wipe because there might be something funky with the app. Good luck!
I already had ran updates from the Market before running the tool and ran into issues. I factory reset my phone from settings and re-ran the tool and that did it!
  • kdemsky likes this
#144 lutheranpriest
lutheranpriest
  • 33 posts
Posted 16 January 2013 - 07:23 PM
This is Razr and Razr MAX NON HD
dude,do you know who you just responded to?
Oh snap!! :o
Now thats funny. And why djrbliss should just lurk and leave the rest of the community to help on the simple stuff.
Thx DJR!
Damn, that was some good entertainment! Reminded me of that classic "Who's on first" bit.
#145 codyv88
codyv88
Posted 16 January 2013 - 07:54 PM
i have been trying to run this root program but no luck, keeps saying complete but it still never changes....HELP!! plz
#146 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 16 January 2013 - 07:56 PM
You may have to do a factory reset then try the root method again. This has worked for a bunch of other people with your issue
#147 codyv88
codyv88
Posted 16 January 2013 - 09:08 PM
still no luck
#148 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 16 January 2013 - 10:20 PM
still no luck
Can you post what the utility reads out after you run it?
#149 enrique73711
enrique73711
Posted 17 January 2013 - 12:53 AM
Thanks, worked like a charm, I want to advise that if you have updated Smart Actions from Market, try to uninstall it or try to revert it back to factory because I ran into the same issues as mention before. All I did was uninstall the update and follow the instruction to the letter, and it went through. Thanks again!! Keep up the great work!
I went through the same issues, i was getting this Message "link failed No such file or directory." from every phrase (1-4). But as soon as i uninstalled the update and did as you requested everything worked flawless. Just heads up for others that might be wondering what the heck is wrong, check your "SmartActions" app and uninstall the updates and revert it back to factory as "Samsonite79" mentioned.
And Dan you did an amazing job with this. Keep up the Good Work
#150 Spydr07
Spydr07
  • 17 posts
Posted 17 January 2013 - 06:49 AM
Ok, since upgrading to JB on my xt912 and using this root, safestrap 3.07 and 3.11 install, but fail when opened. Any ideas?
#151 Spydr07
Spydr07
  • 17 posts
Posted 17 January 2013 - 06:52 AM
And when I attempt to update the Superuser binaries, I get:
Unpacking sutools... okay!
Checking current install path... /system/bin/su
Downloading new binary... okay!
Gaining root access... fail!
#152 livinginkaos
Posted 17 January 2013 - 07:18 AM
I got that error when trying to update my binaries last time. I uninstalled the Superuser update then re applied the update and did the binaries again and it worked fine.
#153 studiorat
studiorat
  • 303 posts
  • LocationEast Coast
  • Current Device(s):Jelly Wizzed JB Droid Maxx
Posted 17 January 2013 - 08:05 AM
Enjoy,
Dan (@djrbliss)
Paypal:
you are the Friggin Man!!!!! thank you
Offending The Masses since 1967.........FTW........Christianity is a Farse!!!
#154 doggman716
doggman716
  • Current Device(s):Droid Razr i
Posted 17 January 2013 - 08:11 AM
You my kind folk are a miracle worker! Worked perfectly, Thank you so much!!!
#155 studiorat
studiorat
  • 303 posts
Posted 17 January 2013 - 08:26 AM
Wipe data and start over. Probably need a virgin smartactions app.
my smart actions is not a virgin I raped it first thing when I got the OTA and lost root....I opened it and had battery saver already set...i just selected a action and hit save....all was fine.....
#156 Spydr07
Spydr07
  • 17 posts
Posted 17 January 2013 - 09:27 AM
Ok, how do I uninstall Superuser on JB kernal since I can't use Matt's Utility?
#157 sk842018
sk842018
  • 39 posts
  • Current Device(s):droid incredible 2/ droid RAZRxt912
Posted 17 January 2013 - 09:47 AM
Just download super su update the binaries on that and than you will be able to update su binaries
#158 HighVelocity
HighVelocity
  • LocationDFW
  • Current Device(s):Razr Maxx
Posted 17 January 2013 - 10:26 AM
Mine appears to be stuck at cleaning up in phase 4. How long should I wait? It's been about 10 minutes.
  • doggman716 likes this
#159 doggman716
doggman716
Posted 17 January 2013 - 10:31 AM
Look at your phone on the "Cleaning up " stage. it is going to ask for Root Permissions, GRANT it, then it will reboot, and all done !
  • foxkat and doggman716 like this
#160 doggman716
doggman716
Posted 17 January 2013 - 10:32 AM
I learned the hard way. It sat F O R E V E R as it was waiting for me to grant the root permissions ;-)
  • foxkat likes this
