tried this on the latest verizon update .165 and it all went through until the clean up stage where it said it could not find su and su on the phone doesnt work what should i do? xt912
#821
Posted 20 February 2014 - 01:15 PM
#822
Posted 20 February 2014 - 04:16 PM
- johnthehillbilly, Redalert and kanka like this
#823
Posted 20 February 2014 - 05:12 PM
You can down grade, root, root keeper, update then restore root OR, just use this....
Shhhhhh ! Sent From My DEV X
wow this super spooky super secret program worked without a problem
- Memnoch73, johnthehillbilly and livinginkaos like this
#824
Posted 20 February 2014 - 05:37 PM
not really secret. Just not talked about for nowwow this super spooky super secret program worked without a problem
Sent From My DEV X
#825
Posted 22 February 2014 - 11:21 AM
Sent from my GT-I9505G using Tapatalk
- johnthehillbilly likes this
#826
Posted 02 March 2014 - 03:29 PM
trying this but but seems to not work
*server not running*
[*]waiting for dvice...
*daemon not running. starting it now *
*daemon started successfully*
& after that nothing
help please
#827
Posted 02 March 2014 - 03:32 PM
stuck at daemon started successfully
help?
#828
Posted 02 March 2014 - 05:57 PM
are you in fastboot mode, is it a usb 2.0 port, are you using the real Moto cable the phone came with, are the drivers installed properly.....
#829
Posted 23 March 2014 - 08:32 AM
I am having the same issue. The phone is in the home screen. I installed the new motorola drivers and I do have USB debugging on. I am running a non-HD Razor Maxx. I tried in Fastboot mode too and have the same issue.
12:44 Update, found my issue. I needed to reboot the phone after installing the motorola drivers on the PC. Why dunno, but it started working from that point forward.
#830
Posted 12 April 2014 - 07:38 AM
Could someone advise in what direction I need to go with my phone?
It's a Razr Maxx running 4.1.2 and has been rooted for years. Until the JB update where it appears that I am stuck in some sort of root limbo (first picture below). I was hoping this exploit might help, but it doesn't seem to be working for me (second picture below). The exploit was done with USB debugging on and in MTP mode- MotoCast is v2.0.31. I have tried unrooting, which has no success either.
#831
Posted 12 April 2014 - 07:48 AM
- jl90 likes this
#832
Posted 12 April 2014 - 07:54 AM
You can also open command window and CD into the directory where you have the root utility.. Then use the above command.....
#833
Posted 12 April 2014 - 07:58 AM
As for root, use this exploit instead -
Sent From My DEV X
#834
Posted 12 April 2014 - 09:08 AM
It would appear Bluestacks was my issues with multiple devices.
The exploit on the first page worked for me, so I now have root access again.
However, the saferoot-moto did not. For some reason the installation of SuperSU failed. I guess the bottom line is I now have root access again!
Thanks for the help!
#835
Posted 21 April 2014 - 01:55 AM
the mtp mode works for me.... stupid mass mode..... it will work with the lock on but it easyer if it off.....
#836
Posted 25 April 2014 - 06:29 AM
I've returned with good news. I've found a solution for the problem. A user on the XDA forums was able to help, luckily before I began a clean wipe.
You need to have your lock screen disabled. So : Settings > Security & Screen Lock > Screen Lock > None
I think it essentially just allows access to the phone and files where it kept getting denied and failing to find files.
The maintenance update Verizon rolled out this week WILL BREAK ROOT, BUT the exploit does re-root.
I forgot a couple of points along the way which required me to make about 4 attempts before I got it right.1. Follow all the directions.2. Make sure you re-enable smart actions if you had frozen it. You must then go to "manage apps" and clear data for the smart actions app.3. Go into developer options and enable USB debugging4. When you connect the USB cable make sure you are in MTP mode NOT mass storage mode (this caused me 3 attempts before I found my mistake)5. If you are getting failures in step 3 of the install you either need to clear data on smart actions again or double check you are in MTP mode.6. During the "cleaning up" stage, there is a superuser request for ADB shell that you may not notice if your screen times out. The install won't complete until you grant ADB shell root. Watch your phone at this point so you don't miss it or you will be sitting around waiting like I was....Anyway, good luck to you and just know that it does re-root.
I did all of this and it worked great for me.
#837
Posted 25 April 2014 - 06:31 AM
I got this when I hit enter too soon before "Battery Saver" was finished saving.
#838
Posted 16 May 2014 - 06:52 AM
This works very well, the instructions are explicit, follow them and you're good to go. Don't forget to allow access on your phone during "cleanup phase".
As a side note, I screwed up system files after achieving root access when trying to open up tethering. Long story short, copying the .db file onto your PC, changing
entitlement value and recopying to phone DOESN'T work, you have to amend the database value on your phone (use SQLite Editor, best $3 you'll spend). I had to FDR the phone and the phone maintained root, no issues. Hotspot\tethering working great.
Thanks Dan!
#839
Posted 25 June 2014 - 04:16 AM
I can'r seem to get the RazrBlade bat to get past the smart actions. I followed the instructions, cleared the app data, didn't see any updates but it just won't get past this step. One time it installed Superuser but didn't root properly and every time after it fizzles with no feedback after I follow instructions and hit enter for the next step after Smart Actions battery saver.
#840
Posted 25 June 2014 - 04:18 AM
Sent from my S-Offed One M8
