#781
Posted 03 September 2013 - 07:18 PM
#782
#783
#784
Posted 05 September 2013 - 08:49 AM
I have not been following this topic for a while. Anyone have any issues with Verizon not able to see what phone you have or it actually shows a really old Motorola phone in the Verizon system?
#785
Posted 17 September 2013 - 06:13 PM
This just pooped my rooting cherry :
Tahnk god i found this forum rather than the old exports i was going to use from 2012, ha :
#786
Posted 15 October 2013 - 05:06 AM
When trying this on my 910 (yes I know the exploit's for 912 only, but figured I'd give it a try anyways as to my knowledge 910 and 912 are virtually identical other than being released in different continents) I was given this, if anyone's interested in where things go wrong. Pretty annoying, there's been so much unnecessary stuff clogging up my cpu since upgrading to JB, but it looks like I'll be stuck with it till upgrade time though :/ its spent the past few months running like a 1-legged tortoise...
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
link failed Permission denied
[*] Rebooting device...
[*] Phase two...
.jar: Permission denied
[*] 2. Select "Get Started".
[*] 4. Select "Save".
[*] 5. Press the Home button.
54 KB/s (0 bytes in 3477.000s)
arJarDex.jar: Permission denied
/system/bin/sh: can't create /data/dontpanic/apanic_console: Permission denied
[*] Phase four...
151 KB/s (0 bytes in 91992.000s)
1742 KB/s (0 bytes in 1867568.001s)
1560 KB/s (0 bytes in 574184.000s)
997 KB/s (0 bytes in 63838.000s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
#787
Posted 15 October 2013 - 05:32 AM
You already know youre using the wrong utility so not sure why you are asking any questions......if you look harder you will find whats needed for the 910
#788
Posted 05 November 2013 - 07:28 AM
Once again your app saved the day! It was not doing anything sitting on demon but then i realized once i unplugged the black hat device. boom it worked perfect!
#789
Posted 22 November 2013 - 04:10 PM
im not getting root access either. USB debugging and in mass storage mode. any ideas?
any mode except mass storage mode. should fix your problem..
#790
Posted 22 November 2013 - 05:30 PM
Lol... you realize you answered a question from 10 months ago. :
Was the correct answer though.
- Bama and livinginkaos like this
#791
Posted 23 November 2013 - 09:11 AM
Do I need to wipe, flash max leak, voodoo, update Jb, restore root?
Sent from the MAXX using Tapatalk 4
#792
Posted 23 November 2013 - 09:13 AM
#793
Posted 23 November 2013 - 09:14 AM
#794
Posted 23 November 2013 - 09:17 AM
#795
#796
Posted 23 November 2013 - 09:19 AM
#797
Posted 23 November 2013 - 09:23 AM
#798
Posted 23 November 2013 - 09:39 AM
#799
Posted 23 November 2013 - 09:40 AM
#800
Posted 23 November 2013 - 09:43 AM
