For the Smart Actions, I do not have something called "Battery Saver." I have either "Battery Extender" or "Nighttime Battery Saver." I have tried both.
Virtually every time I've run the installer, I've seen it say "link failed No such file or directory" appear immediately after it starts Phase one. It will run through the installer every time, but continuously tell me that there is "No such file or directory."
I've included a screenshot below. Any advice would be helpful!
![Posted Image](http://www.s-fx.com/junk/droid.png)
UPDATE: So after some research and a tip by lutheranpriest (thank you!), I realized that I have to actually flash the leaked Jelly Bean OTA update before I can install the root. When I first read the thread, I guess I (stupidly) assumed that the root would install Jelly Bean for me on its own. After successfully installing the flash, it looks like the root process worked seamlessly.
For those that end up making the same mistake as me, there is an excellent video on YouTube on how to manually flash the Jelly Bean OTA update from your external SD card here:
Please note that the link in the description is actually for a RAZR HD, not the original RAZR. To get the OTA update for the original RAZR, visit and then just follow all the same steps in the video.
Afterwards, follow the steps outlined in the opening post of this thread and you'll be in great shape.
Thanks for the help everyone!
Edited by doubles69, 15 January 2013 - 09:42 PM.
