848 replies to this topic
#761 Guest_BDH_*
Guest_BDH_*
Posted 14 June 2013 - 09:19 PM
I feel really stupid, not going to lie... I followed all the steps given and it just shows me about a million, " 'adb' is not recognized as an internal command, opreable program or batch file. Can anyone help me out?
That usually happens when you didn't extract the zip file to it's own folder on your desktop. Or you don't have the correct drivers installed.
#762 MoorReese
MoorReese
Posted 15 June 2013 - 06:36 AM
MHYSA! MHYSA! MHYSA! Worked perfectly!
#763 XtcruleZ
XtcruleZ
  • Current Device(s):Droid RazR xt912
Posted 21 July 2013 - 02:28 PM
Hello all! Just wondering, i currently have the Smart Actions app disabled. I understand that i need to re-enable it before i apply this root method. My question is, can i disable it again after the root and still have everything be fine?
#764 aarnold0805
aarnold0805
  • 70 posts
  • Twitter:aarnold3273
  • Google+:aarnold0805@gmail.com
  • LocationRiverton, WY.
Posted 21 July 2013 - 02:50 PM
Yes
Sent from my XT912 using Xparent BlueTapatalk 2
Sent from my 209 KOA RAZR
#765 XtcruleZ
XtcruleZ
Posted 21 July 2013 - 03:08 PM
Thanks! The root was successful, everything went fine.
#766 chjaway
chjaway
  • Google+:chjaway
  • Current Device(s):Motorola Droid Razr Maxx
Posted 22 July 2013 - 08:19 AM
I'm having problems with this...
My phone is running 4.1.2,
I have factory reset the phone at least a dozen times today and followed the steps outlined in the razr_blade utility.
If my phone isn't in "mass storage" usb mode, the razr_blade utility can't find it.
At phase 2, I perform all the steps for Smart Actions as listed in the utility.
At that point, the utility never responds to the "press any key to continue" response.  I've tried "space bar", "return", and random numbers/letters..but it never comes back
If I change the usb mode to "MTP" at this point, or unplug the usb cable, the utility gets angry and starts complaining that it can no longer see the phone.
What's going on here?
#767 craigdavidj
craigdavidj
Posted 26 July 2013 - 07:30 AM
all i get is *daemon started successfully* what gives?
#768 SamuriHL
  • 44,537 posts
Posted 26 July 2013 - 07:32 AM
ADB isn't finding your phone.  There could be many reasons for that.
#769 craigdavidj
craigdavidj
Posted 26 July 2013 - 09:03 AM
reloaded drivers and everything went great after that. but i still cant get root access. its been a while since i have had a rooted phone and cant remember how to so anything. any help is really appreciated
#770 SamuriHL
  • 44,537 posts
Posted 26 July 2013 - 09:11 AM
"My car is making a strange noise....can you fix it?"  Does that give you enough information?  Likewise, your post doesn't provide nearly enough info for anyone to help you fix it.
#771 craigdavidj
craigdavidj
Posted 26 July 2013 - 10:31 AM
I went thru all of the steps listed, everything went as planned. got the "exploit complete" at the end.  downloaded titanium backup, and it said i had no root access. so i downloaded root checker, which also said i had no root access.  messed around for a while checking stuff out on it and decided to re-run the exploit. now it works. I wasnt getting the superuser requests to allow access the first time. now i am.
#772 SamuriHL
  • 44,537 posts
Posted 26 July 2013 - 10:37 AM
Sweet.  Glad it's working.
#773 macdad
macdad
Posted 29 August 2013 - 06:37 AM
Droid razr 4.1.2 JB will not root, says the adb. is not recognized, done this 2 times, used the smartfunction directions....ALL, still no root, what could be the issue? thanks
#774 cmh714
Posted 29 August 2013 - 06:44 AM
sounds like your not in the correct folder to run the script
#775 cedward453
cedward453
  • Current Device(s):Razr Maxx
Posted 29 August 2013 - 08:21 AM
thats what i thought so i did and it still failed
I am having the same issue. Cleared data in Smart actions and forced stop...ended up with a fresh Smart Actions but still no luck.
Get "The Superuser binary (su) must be updated" Clicked "install" (have Razr Maxx btw) fails every time
#776 johnthehillbilly
Posted 29 August 2013 - 08:26 AM
Can't force stop in smart actions..... just uninstall updates clear data clear cache..... smart actions must be running for the exploit to work properly
"... try not, do! or do not! there is no try..."
#777 cmh714
Posted 29 August 2013 - 08:29 AM
When you say clicked "install" thats not exactly how updating the binary works, so are you sure you did it correctly? Which SU app is there, if its Chainsdd version, then you swipe the window to the right and there should be an place where it says what the binary is, and if you tap on it it will update. For the other versions of Superuser, I have not found an update button....
#778 cmh714
Posted 29 August 2013 - 08:30 AM
Since your name is macdad, I will assume your on a Mac. extract the utility and then open a Terminal window, change into the directory where you extracted and then chmod +x on the script file and then run it. Should work.
#779 cmh714
Posted 29 August 2013 - 09:05 PM
And if your kids name is Mac well then your still not in the right directory/folder
  • mattlgroff likes this
#780 Xavi86
Xavi86
Posted 31 August 2013 - 09:01 AM
it wont work, my phoneget superuser but when i put instal says that An error occurred while installing superuser.
Please send a developer error log
help
8 user(s) are reading this topic
0 members, 8 guests, 0 anonymous users
