Doesnt work for me. Did the usual USB Debugging set the device usb to MTP mode not mass storage. I dont want to do a Wipe/Facture Default as this will kill all my settings. I failed all 4 attempts by the razer-utlilty even though it says "exploit complete" I still do NOT have root, I verified this using another app. Any Ideas?
![Photo](http://www.gravatar.com/avatar/46f69c036d660df4701d68adeba1173e?s=100&d=http%3A%2F%2Fwww.droidrzr.com%2Fpublic%2Fstyle_images%2Fdark_matter%2Fprofile%2Fdefault_large.png)
#741
Posted 28 April 2013 - 08:08 AM
#742
Posted 28 April 2013 - 08:12 AM
If you tried to remove the Smartactions update and failed, then most likely you will need to wipe and its easiest to use Matts JB utility to start. You can try Option 2 in the utility which does not wipe, however, if smartactions has the update the exploit will fail. and you will need Option 1 with a wipe
#743
Posted 28 April 2013 - 08:13 AM
I didnt mess with the stock SmartActions app, I followed instuctions to hit the getting started section.
#744
Posted 28 April 2013 - 08:15 AM
well that may be your problem, the exploit is thru smartactions and if its been updated the exploit wont work.
#745
Posted 28 April 2013 - 08:17 AM
So then I guess I have to either re-flash the phone or do Wipe/Reset Function? If so where can I get the RAZR MAXX OTA leak?
#746
Posted 28 April 2013 - 08:18 AM
Most likely you need to use Matts JB utility with Option 1
#747
Posted 28 April 2013 - 08:22 AM
Alright I will give it a shot, Im downloading it now
#748
Posted 28 April 2013 - 08:26 AM
Also my phone is using encryption so if the utility wipes the phone will that lock me out of all my documents and photos?
#749
Posted 30 April 2013 - 08:49 AM
I understand it'll work on 4.1 but will it work for 4.1.2? Thank you in advanced.
#750
Posted 30 April 2013 - 08:57 AM
Yes
#751
Posted 04 May 2013 - 05:45 PM
Thank you so much you awesome person!
#752
Posted 14 May 2013 - 03:37 PM
im getting "permission denied" and "cannot create" errors through all steps. just did factory reset prior to root attempt. does this not work for doid boinic with 4.1.2? ive seen users posting on this thread with bionics so i assumed it works for bionic too.
#753
#754
Posted 14 May 2013 - 03:39 PM
No sir this is only for the OG Razr as the title suggests.
Edit: Bionic root
#755
Posted 14 May 2013 - 03:44 PM
ugh misleading posts haha. i really dont feel like messing with linux this is not cool
#756
Posted 14 May 2013 - 03:45 PM
What was misleading exactly?
- Memnoch73 and cmh714 like this
#757
Posted 14 May 2013 - 04:38 PM
#758
Posted 23 May 2013 - 10:55 PM
K, I'm at a loss here guys. I've never been unable to get a root method to work on ANY of my devices.....but now I need help.
At first I was getting chmod errors thrown at me during Phase 3 (just like earlier posters). Reflashed JB OTA via Matts utility. Skipping all setup steps on boot I enabled USB debugging, set USB mode to MTP, fired up Matts utility, ran the root exploit...BAM! All 4 phases completed without error.
"Success!!!!" I scream.
Then I fire up root checker, and my face falls: no root. Not even a smidgeon (although the SU app is installed).
I'm at a loss. Trying another factory reset as we speak on the off chance something went wrong in the last attempt, but if that fails I'm fresh out of ideas...
- D000D likes this
#759
Posted 06 June 2013 - 05:06 PM
I'm having the same problem :/ I have everything done, should I just factory restore my phone and try it from there?
#760
Posted 14 June 2013 - 08:10 PM
I feel really stupid, not going to lie... I followed all the steps given and it just shows me about a million, " 'adb' is not recognized as an internal command, opreable program or batch file. Can anyone help me out?
