848 replies to this topic
#721 cmh714
Posted 24 April 2013 - 06:57 AM
mine keeps freezing at the cleanup phase.  followed the steps exactly as written in the program.  Deleted and restarted smartactions to the get started step and chose the battery saver like it says.  tried twice and still freezing at cleanup.  I have no idea what is going on.  It puts SU on my phone but not safestrap or anything else.  Does not seem to be rooted but cannot check to find out.  Should I manually install the safestrap.apk or should I try something else with the root utility?
This utility just roots the phone, it doesnt install anything else like Safestrap. You can use a tool that requires root, or you can get Root Checker to determine if you have root.
#722 Maxx86
Maxx86
  • 65 posts
Posted 26 April 2013 - 09:38 AM
quick theres no option to unroot?! what do i do?! i need to go to verizon!
#723 cmh714
Posted 26 April 2013 - 09:41 AM
Easiest way is to reflash using Matts JB utility OR get his Unroot Application from Play store for 99cents I think
#724 Maxx86
Maxx86
  • 65 posts
Posted 26 April 2013 - 09:43 AM
why what happened to the simple unroot selection that matts utility used to have? i read comments on play store they said app doesnt work
#725 cmh714
Posted 26 April 2013 - 09:47 AM
Do you believe everything you read on the internet?!?!?! Never used any of Matts utilities that had an unroot option, thats not to say they never did though.
Use one of the methods I previously stated.
#726 Maxx86
Maxx86
  • 65 posts
Posted 26 April 2013 - 10:09 AM
i gotta do the whole fastboot crap all over again?! i dont understand i cant fastboot what do u mean by reflash? this is retarded now i wish i never rooted my damn screen cracked and theyre gonna make me pay full price if they find root they did it to me once before!
#727 livinginkaos
Posted 26 April 2013 - 10:27 AM
I would just FXZ it to stock if you are taking it in.
#728 Maxx86
Maxx86
  • 65 posts
Posted 26 April 2013 - 10:29 AM
it is stock its just rooted AND i changed the boot screen and cant change it back cause now es file explorer or any other file manager i use isnt getting su access its like i have root but i dont have root wtf?! it worked just fine a few months ago when i changed the boot screen! manually too not with any apps
i dont even see a fastboot option in matt's 1.90 utility!!!
#729 livinginkaos
Posted 26 April 2013 - 10:33 AM
Just sayin' , if you want to be sure they don't suspect rooting, if you FXZ, there won't be any superuser left behinds and any apps that require root won't be there - they would have no way of knowing since their silly root counter doesn't work.
#730 cmh714
Do what Kaos said, just fxz with RSD or Matts utility
#731 Maxx86
Maxx86
  • 65 posts
Posted 26 April 2013 - 10:35 AM
i dont even see a fastboot option in matt's 1.90 utility anymore!!! rsd is too confusing to use and never works! omfg wtf! $#!+ cant be simple like it used to. im on official ota never installed any leaks all matt says is ice to leak leak to offical idfk i never had the leak!
#732 cmh714
Posted 26 April 2013 - 10:39 AM
1.90 is old dude, find the all-in-one utility...which I now see I posted here already....do ppl read anymore?!?!?!
#733 Maxx86
Maxx86
  • 65 posts
Posted 26 April 2013 - 10:41 AM
thats all i found that was at the top
#734 cmh714
Posted 26 April 2013 - 10:44 AM
see post 722
#735 Maxx86
Maxx86
  • 65 posts
Posted 26 April 2013 - 10:47 AM
i found matt jb all in one its downloading il see now im so pissed i have to fast boot again i dont think im gonna root anymore if theres no simple option to unroot like their used to smdh stupid damn phone screen randomly cracked and i did nothing to make it crack! now i gotta fight verizon see if they'll warranty replace they'll prob force me to use upgrade now and il lose unlimited his is bs
ok i have the utility now what just hit flash jb (wipe data)? theres no fastboot option
#736 cmh714
Posted 26 April 2013 - 10:58 AM
ok i have the utility now what just hit install jb (wipe data)? theres no fastboot option
Not many ppl want to unroot. And again if you want that pay Matt 99 cents for his app. It works on our devices
Yes Option 1 says it does a wipe.....again dont you read?!?!?
#737 Maxx86
Maxx86
  • 65 posts
Posted 26 April 2013 - 10:59 AM
idk which app is his there was more than one app
no i dont read
#738 cmh714
Posted 26 April 2013 - 11:01 AM
My last post for you:
#739 Maxx86
Maxx86
  • 65 posts
Posted 26 April 2013 - 11:50 AM
i had to reroot to the newest su that fixed my root problemi had an old su from the original jb root. as far as unroot im gonna try the app if it dont work then fastboot
#740 Maxx86
Maxx86
  • 65 posts
Posted 26 April 2013 - 12:06 PM
holy crap the app worked thanks guys so glad i dont have to fastboot
