848 replies to this topic
#661 mojoseer
mojoseer
  • 8 posts
Posted 31 March 2013 - 11:27 AM
I'm an idiot. Didn't have phone connected through MTP mode. Worked fine.
#662 d2jsp4life
d2jsp4life
Posted 01 April 2013 - 02:33 PM
Dan, thanks for all your hard work! I'm new on this forum (spent a lot of time at XDA until I got a Razr), but I'm not a complete n00b at this stuff, yet I must be doing something wrong. The exploit executes, but fails at a few points, and since the exploit has worked for others, I'm guessing I'm doing something wrong, or there's an issue with the phone. While executing the script, it seems to fail on pushing pwn.jar, as it indicates that 0 bytes were copied. The full output is below. Any tips would be greatly appreciated!
Had the same problem but after I Factory Reset it worked just fine. I'm running the newest update 4.2.1, just updated today actually and it still worked.
  • mwsf3 likes this
#663 mccookc
mccookc
  • LocationUSA
Posted 01 April 2013 - 06:38 PM
Hey guys kind of new to rooting, done everything you said but getting weird msg when running bat file any suggestions please!
device found
phase one...
adb is not recognized as an internal or external command, operable program or batch file.
goes on to phase 2 which I do correctly
more of same comment
the exploit complete, press any key to exit.
how do I know this did right?
#664 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 01 April 2013 - 06:46 PM
device found
phase one...
That looks like the error when you have not extracted the zip file to your desktop and are trying to run the bat file from within the zip
#665 mccookc
mccookc
  • LocationUSA
Posted 01 April 2013 - 07:05 PM
yeap that was the problem! thanks for the help. one more question any suggested boot program? i'm reading tons on rooting device trying to get my foxfi wifi tether back up and running. need a simple program to operate.
#666 Guest_BDH_*
Guest_BDH_*
Posted 01 April 2013 - 07:09 PM
SQLite :) Then you don't have to use FoxFi.
Sent from my CM10.1 Nook HD using Tapatalk HD.
#667 mccookc
mccookc
  • LocationUSA
Posted 01 April 2013 - 07:12 PM
Thanks BDH any link on how to operate that? It's the one for 2.99 on play right?
#668 Guest_BDH_*
Guest_BDH_*
Posted 01 April 2013 - 07:18 PM
Yes that one. If you search the forums for "sqlite hack" you'll find it. I'm mobile right now so I can't really look it up.
#669 DroidDE
DroidDE
Posted 02 April 2013 - 06:58 AM
Newb to rooting and first time post. Just wanted to give a big thanks to the developer and that root was successful:)
Only question I have is, since I modified Smart Actions during the root process (battery saver), I now have that SA enabled and it dims my screen? Can I go into SA and disable that function or do you have to keep it turned on indefinitely?
#670 Memnoch73
  • 5,016 posts
Posted 02 April 2013 - 07:00 AM
Go ahead and turn it off. That was only for the rooting procedure
#671 DroidDE
DroidDE
Posted 02 April 2013 - 07:25 AM
Sweet! Thanks.....You guys are awesome...great directions, great feedback, great support...really appreciate it!
BTW, just downloaded the SQLite, changed the entitlement and built in VZ app working flawless!
  • Memnoch73 likes this
#672 Flameroid
Flameroid
  • 27 posts
Posted 03 April 2013 - 07:37 PM
is this for official or leak?
#673 robocuff
robocuff
  • 415 posts
Posted 04 April 2013 - 03:35 AM
Both
#674 brandude87
brandude87
  • LocationUSA
  • Current Device(s):Motorola Droid Razr Maxx
Posted 04 April 2013 - 11:07 AM
Hi everyone,
This root tool worked very well for me. However, there is just one problem. Now, when I plug my phone into my laptop with a USB cable, the virtual keyboard on my phone behaves very strangely. When I type, it will behave erratically, and type letters multiple times, or enter letters that are nowhere near the keys I pressed. For example, while my phone was plugged into my laptop just now, I typed, "the brown fox jumped over the lazy dog," however, this was the output on my screen: ".the breypeowon fox djuqtycmzupedk qeouvberrqt .thladeo .ladafjzvmry dog." As soon as I unplug my phone from my laptop, I am able to type with no problems whatsoever. I have tried unfreezing everything in Titanium Backup, I have tried all three USB computer connection settings (Mass Storage, MTP, and PTP), I have tried disabling all developer options (USB debugging, etc), and I have tried restarting my phone, however none of these options corrected the problem. Does anyone else experience this problem or know what would be causing it? I am running stock Android 4.1.2 (Jellybean) on a rooted Motorola Droid Razr Maxx. Thanks!
Update: this no longer seems to be a problem for me. I re-froze all my old apps and everything works fine. I'm not really sure what caused the problem...could be my laptop?
#675 brandude87
brandude87
  • LocationUSA
Posted 04 April 2013 - 11:46 AM
I too used to use FoxFi, until it no longer worked after the Jellybean update. I found a free alternative app that works really well on Jellybean called "WiFi Tether for Root Users":
#676 livinginkaos
Posted 04 April 2013 - 05:37 PM
If you are rooted why would you not use the entitlement change?
Just curious.
RAZR HD Dev
#677 brandude87
brandude87
  • LocationUSA
Posted 05 April 2013 - 08:23 AM
Just curious.
RAZR HD Dev
That's a good question. I did consider that option, and actually did find an instructional video for how to implement the entitlement hack here: http://www.youtube.com/watch?v=X6nCcbJkngY. However, I prefer the WiFi Tether app for a few reasons:
1. It's simpler, easier to implement, less potential for error.
2. The SQLite Editor costs $, whereas WiFi tether is free.
3. The UI gives you more options and is easier to quickly turn on and off.
Update: I ended up downloading SQLite (also had to upgrade to SuperSU Pro for it to work). I figure these could be useful tools in the future anyway. I implemented the entitlement hack, and it seems to works quite well. As far as UI goes, I simply added a hotspot switch in my notification bar using the "Settings Extended" app, which I highly recommend, btw. I figure using the native android hotspot app is probably more efficient than the WiFi Tether app, anyway. Thanks again for the suggestion.
#678 chelseafcfan
chelseafcfan
  • 9 posts
  • Locationindonesia
  • Current Device(s):xt912
Posted 05 April 2013 - 05:50 PM
good God...
this is the easiest rooting I've ever done...
Before using xt912 I used N7000, I9100 all the Samsung family...little bit tricky though for rooting 'cause u have to get inside the recovery section..
But this....one click and then done :lol: :lol:
waattt a jeniusss....thanks mate
#679 acemaxx
acemaxx
Posted 06 April 2013 - 04:58 PM
Hello,
I followed these instructions to root my Razr Maxx and everything went ok. I then tried altering /system/usr/keylayout/Generic.kl accourding to these instructions (I made a backup of the file)
The modification didn't help me with my headset volumn control issue, so I put the original file back. Now my side buttons (power and volume) aren't working. The only way I can get the screen to come on is to plug the phone into USB.
I've tried 2 factory resets and I've confirmed that the Generic.kl file in /system/usr/keylayout/ is the same as the one I backed up.
Is it possible that the root procedure broke the side buttons? Is there any way to completely reload the OS on my phone, like through side loading or something? I noticed that the factory reset doesn't really seem to wipe out all the files because one of the copies I made of Generic.kl (Generic.bak) is still in the /system/usr/keylayout/ directory.
Any help would be greatly appriciated, this is the first time I've tried to modify my phone and I think I've trashed it.
#680 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 06 April 2013 - 05:15 PM
Is the Generic.bak the original file? Have you tried deleting the modified Generic.kl and renaming Generic.bak to Generic.kl?
