848 replies to this topic
#641 kdemsky
kdemsky
  • 5 posts
  • Current Device(s):RAZR MAXX
Posted 28 March 2013 - 06:41 PM
I tried a bunch of things and it worked. Sorry gang, don't know what did work.
I had Bluestacks installed before the whole process began. I uninstalled that.
I think it even worked with the latest version updated smart actions. I have auto updates on (but how do I know?)
Need to clear cache and data from apps>manage apps. I stopped processes also.
When running the root app, I had to help the reboot process or be more patient. When it was rebooting and appeared hung, I rebooted it manually with the power button and the script recognized the reboot when powered on.
I tried so many combinations of things that I'd not know what worked. It saved me from wiping the phone as recommended!
Good luck!
#642 kdemsky
kdemsky
  • 5 posts
Posted 29 March 2013 - 07:52 AM
Has anyone posted a normal script output? Is it useful, or do good results appear different every time? Here's the one that worked for me. Sorry, I screen grabbed and did OCR because I forgot to output text.
[*1
[*1 Razr Blade Motorola Droid Razr 4.1 Root Exploit (Windows Version)
[*1 by Dan Rosenberg (@djrbliss)
[*1
[*1 Thanks to p3droid for assistance in testing.
[*1
[*1 Hotel this will not work on Razr HD, Razr H, etc.
[*1
[*1 Before continuing, ensure USB debugging is enabled, that you
[*1 have the latest Motorola drivers installed, and that your phone
[*1 is connected via USB.
[*1
[*1 Please carefully follow any instructions provided in the exploit.
[*1
[*1 Press enter to root your phone...
[*1
[*1 Waiting for device...
[*1 Device found.
[*1 Phase one...
[*1 Rebooting device...
[*1 Waiting for phone to reboot.
[*1 Phase two...
[*1 Complete the following steps on your device
[*1 1. Open the Smart actions application.
[*1 2. Select "Get Started".
[*1 3. Select "Battery Saver".
[*1 4. Select "Save".
[*1 5. Press the Home button.
[*1
[*1 Press enter here once you have completed the above steps.
1131 KB/s (3477 bytes in @.@@3s)
[*1 Phase three (this will take a minute)...
[*1 Phase four...
2191 KB/s (91992 bytes in @.@41s)
2356 KB/s (1867568 bytes in @.774s)
3893 KB/s (574184 bytes in @.144s)
2811 KB/s (63838 bytes in @.@31s)
[*1 Cleaning up...
[*1 Rebooting...
[*1 Exploit complete?
[*1 Press any key to exit.
#643 mwsf3
mwsf3
  • 15 posts
  • Current Device(s):RAZR MAXX HD
Posted 29 March 2013 - 10:01 AM
I cannot get this to work , tried 3 times and followed all steps. Appreciate your efforts , on 4.1.1
#644 mwsf3
mwsf3
  • 15 posts
Posted 29 March 2013 - 10:02 AM
i will go to 4.1.2 and try again
#645 #root#
#root#
  • 6 posts
  • Google+:weigandweston@gmail.com
Posted 29 March 2013 - 01:45 PM
Can this work on 4.1.2?
#646 Guest_BDH_*
Guest_BDH_*
Posted 29 March 2013 - 05:56 PM
Yes it will :)
#647 mwsf3
mwsf3
  • 15 posts
Posted 29 March 2013 - 07:25 PM
I've tried 8 times thus far, no go. RAZR HD 4 1 2
1. Media / camera mode
2. Reinstalled smart
3. ADB Driver updates
Would like to know if you can
#648 Guest_BDH_*
Guest_BDH_*
Posted 29 March 2013 - 09:33 PM
Read the thread title maybe? It says XT912 ONLY.
  • mwsf3 likes this
#649 fuzzyman20
fuzzyman20
  • 16 posts
Posted 30 March 2013 - 12:56 AM
i cant figure this out. ive never had a problem. i seem to be missing the run.bat batch file.
any suggestions?
#650 fuzzyman20
fuzzyman20
  • 16 posts
Posted 30 March 2013 - 01:00 AM
i must have not wiped properly? but the "get started" is not there. how do i do a cache wipe? ive always just done it in safestrap.
#651 kdemsky
kdemsky
  • 5 posts
Posted 30 March 2013 - 05:59 AM
Fuzzyman, unzip the razr_blade file again, there is a run.bat. Perhaps, your windows file viewing permissions are hiding *.bat file. (guess).
Also, I wiped using home>>apps (options button) > manage apps then find the program, clear data and cache. This worked for me, but from a LOT of reading on this thread (20+ pages) I"ve seen some have an updated smartactions app, and they'll need to factory wipe, install base the Jelly Bean with the original smartactions with the exploit still in there.
#652 robocuff
robocuff
  • 415 posts
Posted 30 March 2013 - 06:05 AM
Also, if you don't see a run.bat, look for one named just run. You may have the setting "hide extensions for known file types" set. It's the default setting so if you haven't ever changed it, it's more than likely set. If so, you won't see the .bat part of the file name.
#653 mwsf3
mwsf3
  • 15 posts
Posted 30 March 2013 - 07:39 AM
I've not had a root in many years , so anyone who can tell me how to exploit , let me know. I got to clockworkmod tecovery on my device , tried a sideload via adb too
I've tried this exploit 10 times. are you saying going to clockworkmod recovery , factory reset , then run before signing into gmail will work ?
#654 lutheranpriest
lutheranpriest
  • 33 posts
Posted 30 March 2013 - 12:49 PM
If you're having problems, as a recommendation, start by flashing the stock rom. Back when I rooted my Razr the day the exploit was released, I couldn't get the exploit to work until I started with a clean, wiped, fresh flash. You can get the stock OTA rom here:
To flash, you need to use RSD Lite in Winblows (Sorry, there isn't a Mac/Linux version) You can find it here:
I don't take any credit for either of those files, since I didn't upload them, but they should work for you.
If you need to flash in Mac OS or Linux, unzip the sbf file, and copy the script I wrote from
, along with the proper fastboot executable into the same directory where you unzipped the contents of the sbf file, and flash by typing the following command in the terminal:
I also converted the run.bat script for Razr Blade to a Mac/Linux sh script.
Just like with the above script, extract the contents, and copy the script and the appropriate adb executable into the directory where you extracted the Razr Blade exploit. To execute the script, type the following command in the terminal within the Razr Blade directory
I tested both of these scripts in Mac OS, and I was able to flash a fresh system and root with no problems. I hope this will help anyone who is still having problems. I only tested the scripts in Mac OS, but they should work in Linux also. Mac OS doesn't require drivers, and I don't believe Linux does either. If anyone wants to test the scripts in Linux, feel free to do so and post your results.
#655 mwsf3
mwsf3
  • 15 posts
Posted 30 March 2013 - 12:50 PM
OK , sorry . Will stand by to donate
#656 lutheranpriest
lutheranpriest
  • 33 posts
Posted 30 March 2013 - 12:53 PM
Your user info says you're on the Razr Maxx HD. This exploit is only for the Razr & Razr Maxx. It will not work on the Razr HD family of phones.
#657 mwsf3
mwsf3
  • 15 posts
Posted 30 March 2013 - 01:41 PM
Sorry, totally misread this to support 9.16 and Razr HD. I hope someone can grab an exploit and standing by to donate. Cheers
#658 lutheranpriest
lutheranpriest
  • 33 posts
Posted 30 March 2013 - 02:31 PM
This should work for you:
  • mwsf3 likes this
#659 mwsf3
mwsf3
  • 15 posts
Posted 31 March 2013 - 06:36 AM
Thanks priest . I have used this utility before , good call. Its a 2-3 hour time investment . I think I'm going to wager on one of these geniuses finding a root exploit on 4.1 2.
#660 mojoseer
mojoseer
  • 8 posts
Posted 31 March 2013 - 08:52 AM
I am having the same problem - data logger permission denied error - after going through smart action steps. Clear data, cache, anything could think of. Always same error message. Seems like lots of possible fixes but can't say I am savvy enough to understand best approach. Not sure what wipe phone even does. Think maybe it's just over my head but help welcome for a simpleton like me. Love to donate if can get my root back. Thanks. Matt
