848 replies to this topic
#601 zztop80
zztop80
  • 5 posts
  • LocationFrance
Posted 25 March 2013 - 06:35 AM
thx my friend ok not work version UE :( A day can etre it will be possible thank you again
#602 pidow
pidow
Posted 25 March 2013 - 06:48 AM
Well if you 2 would read the title of the thread, you would see that it says XT912 ONLY. There have also been about 50 comments telling you guys that it will only work on the XT912.
The only difference between the RAZR and RAZR MAXX is the battery size. The hardware is identical, so that shouldn't make a difference.
j'espere egalement. je recherche en tout cas activement ;)
#603 boostberry09
boostberry09
  • 7 posts
  • Current Device(s):razr maxx, galaxy s2
Posted 25 March 2013 - 07:01 AM
i have tryed at least 10 times and it never works I keep getting abd server is out of date killing? please help????????
#604 cmh714
Posted 25 March 2013 - 07:10 AM
Well, kind of sounds like you have an old adb from the message you posted....do you have another version of adb in your path? Try running the utility from within the folder where it exists, as there should also be an adb.exe there as well and it should pick that one first.
#605 boostberry09
boostberry09
  • 7 posts
Posted 25 March 2013 - 08:30 AM
HELP THIS WILL NOT WORK AT ALL
  • boostberry09 likes this
#606 boostberry09
boostberry09
  • 7 posts
Posted 25 March 2013 - 08:39 AM
I do not know how to update my abd? there is an abd exe file in the download but when i click it it flashes then nothing else
#607 rangerm
rangerm
  • 25 posts
Posted 25 March 2013 - 08:53 AM
Perhaps this may help?
#608 cmh714
Posted 25 March 2013 - 08:58 AM
If its really the case that it is not old, but still running, then from the command line before starting the run.bat file, from within the directory, issue the "adb kill-server" command without the quotes, then run the run.bat file.
#609 boostberry09
boostberry09
  • 7 posts
Posted 25 March 2013 - 09:43 AM
ok thanks I now have the phone showing rooted when i press ##7764726 but when i run root checker it says phone is not rooted and wifi tether for root users will not work.... Thanks so much for all of your help
#610 cmh714
Posted 25 March 2013 - 09:46 AM
Have you rebooted?
#611 boostberry09
boostberry09
  • 7 posts
Posted 25 March 2013 - 09:47 AM
yes rebooted 2 times? I am so confused
#612 boostberry09
boostberry09
  • 7 posts
Posted 25 March 2013 - 10:51 AM
Have you rebooted?
I am just lost i have rebooted bunches of times and still not working
#613 cmh714
Posted 25 March 2013 - 10:53 AM
I dont know.....could spend time troubleshooting this or you can use Matts JB utility to just fix it all....
#614 boostberry09
boostberry09
  • 7 posts
Posted 25 March 2013 - 02:16 PM
do you know where I can find a link for jb utility?
#615 cmh714
Posted 25 March 2013 - 02:33 PM
Will reset you and includes Dan's razr blade all in one:
#616 jim10009
jim10009
  • LocationIdaho
  • Current Device(s):Razr maxx
Posted 25 March 2013 - 08:54 PM
No Love here :(
Novice user on Ubuntu 12.10
Here is the log from attempt. Any help greatly appreciated :) Thanks in advance.
btw: wasn't sure what to do for motorola drivers for linux. not much came up on google search and motorola site lists windows and Mac drivers only...
jim@HP-DV7:~$ cd Downloads
jim@HP-DV7:~/Downloads$ cd Rzr-root
jim@HP-DV7:~/Downloads/Rzr-root$ chmod +x razr_blade.sh
jim@HP-DV7:~/Downloads/Rzr-root$ bash razr_blade.sh
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
[*] Rebooting device...
[*] Phase two...
[*] 2. Select Get Started.
[*] 3. Select Battery Saver.
[*] 4. Select Save.
[*] 5. Press the Home button.
1630 KB/s (3477 bytes in 0.002s)
link failed File exists
[*] Phase four...
897 KB/s (91992 bytes in 0.100s)
3804 KB/s (1867568 bytes in 0.479s)
3774 KB/s (574184 bytes in 0.148s)
1583 KB/s (63838 bytes in 0.039s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
#617 lechuckthepirate
lechuckthepirate
  • Twitter:jvilarino
  • LocationBarcelona
  • Current Device(s):Razr MAXX XT910
Posted 26 March 2013 - 01:51 AM
Is there any WIP for a XT910 EU root???
#618 gldickens3
gldickens3
Posted 26 March 2013 - 05:14 AM
Yesterday, I upgraded my Droid Razr Maxx via OTA to JB 4.1.2, system version 98.72.16.XT912.Verizon.en.US. Then I immediately downloaded this exploit and executed the bash script under Linux. I keep getting these errors with the /data/logger file as reported by others:
The solution proposed several times in this thread is to uninstall any updates to SmartActions and clear the data for that app. However, I can't find anywhere how to do that on my Droid. So, could somebody please tell me how to uninstall updates to SmartActions and clear SmartActions data? Also, does anybody else have any suggestions for me to try to get this to work?
Many Thanks!
Gordon
#619 bcfour
bcfour
Posted 26 March 2013 - 05:39 AM
I was rooted -- accepted the OTA and had no issues there. Lost root. Have tried the exploit several times now (and cleared Smart Actions). Everything appears to be working and it says exploit was successful, but I still don't have root access. I've tried three times.
Any ideas on what else I can try without doing a full data wipe?
#620 gldickens3
gldickens3
Posted 26 March 2013 - 05:59 AM
I found how to clear SmartActions data on my Droid with:
Settings > Apps > All > SmartActions
I cleared the SmartActions data and then retried the exploit, however, it did not work with the same old errors:
So, could somebody please tell me how to uninstall updates to SmartActions since that has been recommended several times in this thread? Also, does anybody else have any other suggestions for me to try to get this to work?... I am getting frustrated....
Thanks,
Gordon
