848 replies to this topic
#581 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 23 March 2013 - 05:27 PM
Access control enabled, same symptoms :-(. No connect.
Do you have wifi at home and if so are you right next to it if so go in another room mine wont work either if its right next to wifi because its always trying yo get wifi
#582 grimducati
grimducati
  • 11 posts
  • Current Device(s):Mot Razr XT912
Posted 23 March 2013 - 05:53 PM
OK! will do, thank-you. Getting ready to head to SQL :-)
#583 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 23 March 2013 - 05:58 PM
Sorry it didnt work for you it has always worked for me your sure you got evetything ckd. I think with sqlte you gotta change line 67 to zero or something I never did it that way. Good luck.
#584 grimducati
grimducati
  • 11 posts
Posted 23 March 2013 - 06:03 PM
Thanks again, still haven't given up on sorting this, but even after going back thru setting exactly as on paper, I am still foiled. Rebooted twice...will go to a no wifi available environment to see if that makes a difference.
#585 str8fan7
str8fan7
  • 6 posts
  • LocationColorado
  • Current Device(s):Droid Razr converted to Razr Maxx
Posted 23 March 2013 - 06:06 PM
In the sql editor, go to settings storage, settings.db and then line 79 entitlement check change to 0
#586 tucstwo
  • Google+:tucstwo@gmail.com
Posted 23 March 2013 - 06:08 PM
Afterward, I got FoxFi working again by installing SQLite (a $2.99 purchase), and following these instructions.
The difference is my phone's entitlement check was on line 150, as opposed to the example. FoxFi works again, and all is good.
Now I need to decide where to go from here with my rooted phone.
Many thanks to the OP, and all the help provided (including the other posters).
FWIW, if you go through with the SQL trick and reboot your phone. Foxfi isn't even necessary. The stock Moto/VZW Hotspot app from the Settings menu will work just fine. Hope this helps. :)
  • mattkilla likes this
#587 Guest_BDH_*
Guest_BDH_*
Posted 24 March 2013 - 01:03 AM
On stock JB it's line 66 :)
#588 grimducati
grimducati
  • 11 posts
Posted 24 March 2013 - 05:30 AM
tucstwo, found the entitlement where you quoted, line 150. Stock XT912 Razr on OTA jelly bean.
I could not get the wifi tether app 3.2-beta2 to accept a connection as described above. I did go for SQLite and now native tether working. Installed Titanium back up. Couple of reboots and it is running...maybe time to delve into a ROM...after some more reading.
Thanks to all for the help!
#589 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 24 March 2013 - 06:00 AM
You are using the wifi tether for root users with my way right? Maybe you can google it and find an older edition. Ihave had mine on my card and TB for a long time. I think its 3.0 or 3.1
#590 grimducati
grimducati
  • 11 posts
Posted 24 March 2013 - 06:08 AM
Yes, wooddale using the wifi tether for root and strictly followed the instructions you generously provided...thought about an earlier version but with JB, figured most recent would be best. All looks fine on the Razr, it is the "client" that just tries to join and spins away, never connects. The client has no problem with other AP and when Razr was ICS with PDAnet, it was A-OK.
#591 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 24 March 2013 - 06:12 AM
The one I have is 3.1. If you google Wifi tether for note 2. You can get the latest which is 3.3 he says it works.
#592 grimducati
grimducati
  • 11 posts
Posted 24 March 2013 - 07:13 AM
OK, thanks will uninstall 3.2 and download the 3.3 version
assume that is the correct apk
#593 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 24 March 2013 - 07:28 AM
Thats what he says like I say I have 3.1 and it works. Unless something vot messed up when you rooted. Sometimes guys just start over again and it works no reason why.
#594 grimducati
grimducati
  • 11 posts
Posted 24 March 2013 - 10:12 AM
Well, tried the WiFi Tether - TrevE Mod (root users) 3.3 pre2...still no luck.
I did see the tablet recognize an ip and subnet that looked odd.
IP Address: 169.254.64.230
subnet mask: 255.255.0.0
#595 cmh714
Posted 24 March 2013 - 12:59 PM
the 169.254 range is for a host that cannot find a dhcp server and cannot get an IP address....
#596 rangerm
rangerm
  • 25 posts
Posted 24 March 2013 - 02:14 PM
Thanks. I figured since I'd already purchased FoxFi, I may as well use it.
#597 robocuff
robocuff
  • 415 posts
Posted 24 March 2013 - 03:02 PM
Well, I think if you use FoxFi, it's sort of a redundant thing. I'm pretty sure that FoxFi works by using the built in hotspot. If you did the sqlite hack, there's really not much sense in having another app running when you're just ending up using the same app anyway ;) .
#598 zztop80
zztop80
  • 5 posts
  • LocationFrance
Posted 24 March 2013 - 11:37 PM
hello sorry for my little english ^^ i am french !!! :) Razr blade is not fonctionnel with me " XT910 " JB vodaphone eu :(
#599 pidow
pidow
Posted 24 March 2013 - 11:52 PM
It's look work with only USA version :(
#600 Guest_BDH_*
Guest_BDH_*
Posted 25 March 2013 - 01:32 AM
Well if you 2 would read the title of the thread, you would see that it says XT912 ONLY. There have also been about 50 comments telling you guys that it will only work on the XT912.
  • Memnoch73 likes this
