well this gives you root....so since you already have root then this does nothingSoooo with the release of this what if I wanted to start from scratch from a rooted jb droid RAZR what would I need to do??
#41
Posted 15 January 2013 - 05:08 PM
#42
Posted 15 January 2013 - 05:19 PM
1. I wanted to be absolutely sure I was wiped clean. I used the fastboot console to wipe (fastboot -w), then rebooted into recovery and did a factory reset through recovery.
2. Re-flashed the leaked OTA zip.
3. Upon boot, enabled USB Debugging, Mock Locations, and Unknown Resources
4. Ran exploit.
To verify, I downloaded , and I'm presently connected via wifi as I post this (my only isp at home is through my Razr. I live so far out in the boonies, I can't get DSL or Cable, but I do have 4G)
Dan, you're the Exploit King! You've got a few bones coming your way from me. Thanks again!
#43
Posted 15 January 2013 - 05:21 PM
Sent from my DROID RAZR using Xparent Blue Tapatalk 2
#45
Posted 15 January 2013 - 05:40 PM
This IS the bounty one.
My bad bro!! Well donation sent! Just got root ! Lol Boss
#46
Posted 15 January 2013 - 05:45 PM
Okay, first off thank you so much Dan. Your a rock star. I am rooted with Safestrap, running Fuzion rom. I accidently deleted the home launcher on the stock side, so I wasn't able to go in and install Safestrap 3.11. My question is can I simply reinstall the jb leak through recovery? Then use the root exploit?
That's what I was trying to ask earlier ha ha thanks for being more clear
#47
Posted 15 January 2013 - 05:46 PM
No apology necessary, let's all celebrate!
- johnthehillbilly likes this
#48
Posted 15 January 2013 - 05:57 PM
No problem. Now just hoping for an answer.That's what I was trying to ask earlier ha ha thanks for being more clear
#49
Posted 15 January 2013 - 06:10 PM
Sorry, but to be honest, your questions arent all that clear. If you have Safestrap and have JB on Stock ROM slot, then boot back to Stock ROM and apply the exploit to the Stock ROM. OR maybe you are Dual Booting and using Fuzion but your Stock ROM is ICS, in that case, you can reinstall a clean ICS on Stock and go from there.
Maybe I'm missing something, but I think you need to be a little clearer.
#50
Posted 15 January 2013 - 06:15 PM
#51
Posted 15 January 2013 - 06:21 PM
OK OK I have jb leak rooted but completely jacked up my stock ROM how do I just start fresh
define "jacked up"
if he is using safestrap..he's already rooted. You can't run safestrap from the stock rom slot..even on JB if you're not rooted. It won't work
#52
Posted 15 January 2013 - 06:22 PM
putting it simply that is what I'm trying to askOK OK I have jb leak rooted but completely jacked up my stock ROM how do I just start fresh
#53
Posted 15 January 2013 - 06:24 PM
#54
Posted 15 January 2013 - 06:26 PM
define "jacked up"
Yup, understood Tucs. Thats why I was trying to get better info. Cheers.
#55
Posted 15 January 2013 - 06:28 PM
#56
Posted 15 January 2013 - 06:31 PM
I may be completely wrong but I'm wondering if you can use matt's unbrick utility to setup the reapply of the leak through stock recovery. I'm thinking only certain imgs need flashed in order to do that. Then you would use the root exploit and start over.
Others have done that tmyinc.
- smittyjo8 likes this
#57
Posted 15 January 2013 - 06:40 PM
- jp1044 likes this
#58
Posted 15 January 2013 - 06:45 PM
#59
Posted 15 January 2013 - 06:51 PM
#60
Posted 15 January 2013 - 06:57 PM
That's what I was thinking. I just remember it was something like that when we would jump between leaks on the bionic. Thanks for confirming!
