#521
Posted 20 March 2013 - 12:28 PM
#522
Posted 20 March 2013 - 03:30 PM
#523
Posted 20 March 2013 - 03:45 PM
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
[*] Rebooting device...
[*] Phase two...
[*] 2. Select "Get Started".
[*] 4. Select "Save".
[*] 5. Press the Home button.
434 KB/s (3477 bytes in 0.007s)
link failed File exists
[*] Phase four...
3251 KB/s (543080 bytes in 0.163s)
3570 KB/s (1867568 bytes in 0.510s)
3610 KB/s (476557 bytes in 0.128s)
3191 KB/s (63838 bytes in 0.019s)
[*] Cleaning up...
[*] Rebooting...
[*] Exploit complete!
Hit ENTER to return.
............wtf this is after a fresh fast boot PHone set to allow unknown sources/allow mock locations/USB debug on and USB type set to MTP
#524
Posted 20 March 2013 - 03:52 PM
#525
Posted 20 March 2013 - 07:53 PM
Droid RAZR M
#526
Posted 20 March 2013 - 11:41 PM
I cant get this to work......
Droid RAZR M
Dude... i don't know how often .... This Exploit is not working on Razr M or HD
#527 Guest_BDH_*
Posted 21 March 2013 - 02:45 AM
This is for the Droid RAZR and Droid RAZR Maxx XT912 and nothing else.
XT912 ONLY!
- livinginkaos likes this
#528
Posted 21 March 2013 - 04:58 AM
#529
Posted 21 March 2013 - 05:02 AM
#530
Posted 21 March 2013 - 07:48 AM
Sorry... Just needed to be more patient...
Edited by washbhr, 21 March 2013 - 07:51 AM.
#531
Posted 21 March 2013 - 02:00 PM
#532
Posted 21 March 2013 - 02:27 PM
#533
Posted 21 March 2013 - 02:35 PM
Are you clearing data in smart actions?? USB debugging on?? Using the USB cord that came with your phone??
Yes to all. I am force stopping smart actions, clearing data in it. USB Debugging on, and this is the cord that came with original phone... this is a refurb that came with factory ICS... I took the JB update in the soak test, which is the same as the OTA I believe. I can't think of a thing.
#534
Posted 21 March 2013 - 02:43 PM
Im having the same issue
#535
Posted 21 March 2013 - 02:47 PM
Then I'm thinking you are going to have to reset your phone. Use the Utility and do option 1 that wipes data. Then after you set it up do root again. It will work after that but there are no more options I can think of that you have not tried.
- llkevoll likes this
#536
Posted 21 March 2013 - 03:25 PM
I also am having trouble. I have rooted and rom'd numerous phones, many with Matt's awesome utilities. I received a replacement Razr, got in on the Soak Test with a phone that had never been rooted. Now, I tried RAZR_BLADE about 20 times, resetting smart actions every time (can't uninstall updates, as the only option is disable.) I have read this thread, as well as Matt's utility thread. I have tried options 2 and 3 in Matt's jelly bean 912 utility. I keep getting the SU not on phone along with the other failures during razr_blade. I was just wondering if anyone has figured this out. I am in media mode. I am holding out on option 1 for a bit, because if option 2 did nothing, not sure about 1. I guess that will be the next step though. Just trying to figure out why this works for some, and not others??
I'm thinking you're going to have to do a full (option 1) wipe. I had the same issues and was really trying to avoid a full reset of the handset but I did it last night and it worked seamlessly. I spent more time waiting for my phone to reboot than it actually took to get root and do the entitlement check hack. Zooming along beautifully now!
- Memnoch73 and cmh714 like this
#537
Posted 21 March 2013 - 03:33 PM
#538
Posted 21 March 2013 - 03:39 PM
Update: Still no luck. This is so frustrating, man. Not sure now what to do. If anyone has any ideas, please let me know. Thanks
#539
Posted 21 March 2013 - 03:49 PM
OK, I did option 1. Setup phone a little bit. Got to very end, no more errors until the end, where it said no su binary installed. I will try again...
Make sure you are covering all the bases. Clear Data on SA, Usb debugging, USB mode to mtp. I know it's easy to forget something when you are in the middle of this stuff
- ccrsems5 and llkevoll like this
#540
Posted 21 March 2013 - 04:08 PM
Well said! Make sure to hit all the points. 1 wrong setting results in Fail. Especially the USB to MTP. Good luck. Keep reporting the results. We'll get it one way or another. I was ready to give up a few days ago, but that "nerd" side of me wouldn't quit!
- ccrsems5 likes this
