848 replies to this topic
#481 adauth
adauth
  • 17 posts
  • LocationNew Orleans
Posted 16 March 2013 - 01:08 PM
That's all I did, removed safe strap 3.11 via the app, used supersu un root, then installed the downloaded update. Allowed update, used this exploit to reroot, reinstalled safe strap and now I'm trying roms again.
Sent from my DROID RAZR using Xparent BlueTapatalk 2
Thanks. No safestrap for me so I don't have to worry about that step. Ok so unfreze all frozen apps, smart actions stuff, then full unroot using supersu. Then update and re root with this threads method?
Thanks!
#482 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 16 March 2013 - 01:13 PM
You were on 4.0.4 and went right to JB without foing the security ota?
#483 adauth
adauth
  • 17 posts
Posted 16 March 2013 - 01:17 PM
If speaking to me no. The update is ready for download and install, I was just making sure I use the right steps to get root back after I full unroot to install the jb update.
#484 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 16 March 2013 - 01:22 PM
Ok your talking about the new Ota that just came out for the hd or am I on the wrong page lol.
#485 adauth
adauth
  • 17 posts
Posted 16 March 2013 - 01:25 PM
No talking about the first razr, XT912. Not the HD varients
#486 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 16 March 2013 - 01:27 PM
See I new I was on the wrong page sorry.
#487 zoxxo
zoxxo
  • 5 posts
Posted 16 March 2013 - 03:17 PM
I'm new to this forum but not to Android...
I had root, and attempted to retain root with voodoo, but made the mistake of not backing up my binaries, so root retention failed. I'm running RAZRBlade and it fails in step 3. Here's what I'm getting:
mkdir failed
for /data/logger, File exists
link failed
File exists
If I use Matt's 1.9 utility and select option (1), is this going to restore me to stock .211 with no root? Will internal memory and sdcard memory be wiped, or will those memory locations be intact at 1.9 is done. I'll still do a back-up, but I was curious. Finally should I run a factory reset after running Matt's utility or after the Jelly Bean update (or will I even need to run a Factory reset? Any help or feedbac would be much appreciated!
#488 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 16 March 2013 - 03:43 PM
Are you on 912 or 926
#489 zoxxo
zoxxo
  • 5 posts
Posted 16 March 2013 - 03:56 PM
Not sure what you're asking. I'm on system version 98.72.16 and build number 9.8.20...
#490 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 16 March 2013 - 04:02 PM
Im sorry I meant are you on a Razr 912 or a Razr926
#491 zoxxo
zoxxo
  • 5 posts
Posted 16 March 2013 - 04:04 PM
I'm on a Verizon
I'm on a Verizon RAZR which shows in the system information as 912...
#492 livinginkaos
Posted 16 March 2013 - 04:05 PM
with his system version he is XT912
RAZR HD Dev
#493 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 16 March 2013 - 04:12 PM
Ok Im on 926 I no 1.10 exploit doesnt work for us any more it will get us back to 4.0.4 but everyone is loosing root taking the Ota's. We have to do it manually.
#494 navy2x
navy2x
Posted 16 March 2013 - 06:52 PM
I am not able to root. I have a Droid Razr Maxx running 4.12 (98.72.16.XT912) which was downloaded and installed yesterday. I used Matt's 1.82 utility to to restore .211, then did an OTA update to my current version. I have SmartActions version 4.2.2.4.2. I've read every single post on this thread and don't know what to do. I REALLY do not want to factory reset again. I have USB debugging on and I'm on MTP mode. I've cleared the data and cache on the SmartActions apk. Here is the output of the razr blade .bat. I get this same output every time.
Any ideas? Do you think Motorola has already patched this exploit since I just updated to 4.12 via OTA yesterday? Please help! Thanks!
#495 bradster101
bradster101
  • 5 posts
Posted 16 March 2013 - 07:08 PM
I went through all the steps and everything went fine but when I used root checker to see if I had root it says that "This device does not have proper root access". What does this mean?
Have droid razr max hd
#496 sk842018
sk842018
  • 39 posts
  • Current Device(s):droid incredible 2/ droid RAZRxt912
Posted 16 March 2013 - 07:12 PM
Does not work for HD
#497 bradster101
bradster101
  • 5 posts
Posted 16 March 2013 - 07:16 PM
I thought that this is for the hd?
#498 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 16 March 2013 - 07:18 PM
No.
#499 bradster101
bradster101
  • 5 posts
Posted 16 March 2013 - 07:27 PM
Is there not a root for the hd yet? Ive seen that you have to revert to ICS then root but can anyone confirm this or send a link?
#500 Nockz
Nockz
  • 9 posts
  • LocationPlauen [Germany]
  • Current Device(s):RAZR
Posted 16 March 2013 - 09:32 PM
Should look in the right Area, hm?
