#461
Posted 14 March 2013 - 10:07 AM
#462
Posted 14 March 2013 - 10:10 AM
MANY THANKS! This worked fine on my Razr Maxx that I just updated to Jelly Bean!
I wonder whats up with that some guys are having problems and others not. Glad it worked for you.
#463
Posted 14 March 2013 - 11:01 AM
My razr was -- so to speak -- "clean as a whistle" -- as I had just done the following prior to running Razr_Blade:
1. Backed everything up with Titanium Backup (and another app, for good measure); also copied my sd & sd-ext.
2. Restored stock ICS with "DroidRazrUtility ver. 1.82" (no issues with this, either)
3. Then:. Installed current Verizon Jelly Bean upgrade -- from my SD card - no issues here, either.
4. As mentioned above, I am in the process process of restoring Titanium backups -- and have had no issues so far.
#464
Posted 15 March 2013 - 09:07 AM
#465
Posted 15 March 2013 - 12:07 PM
I had rooted previously and used Voodoo OTA Rootkeeper during the JB update. This kept root for programs superuser had already been allowed on, but hosed my SU and allowing any new programs to access it. Root Checker did not show having root access.
In running this exploit, I received the same permission denied errors as those posting here. I did a Temp Unroot in Rootkeeper and rebooted the phone. Reran the exploit and all seems to be good now. Root Checker shows success, BusyBox installed and updated, and all root programs are properly requesting and getting root.
Thanks for sharing. I encountered this same issue and your steps worked perfectly.
Also, much thanks to djrbliss for the utility!
#466
Posted 15 March 2013 - 05:01 PM
... Still no sucess...
Could anyone check which Smart Actions Version is included in the Verizon Version? in EU we got 4.2.2.5.0... maybe we got a newer version?
Same here.
I gave a JB FOTA update. The reason:
System Version: 982.124.14.XT910.Retail.en.FR
Kernel Version: 3.0.8-g7198280
Build number: 9.8.2O-124_SPUEM-14
And Smart Actions version upgraded to 4.2.2.5.0 wthout any possibilites of downgrade. (uninstall updates not avaiable)
And this exploit not working. Trying everithing. Always say: link failed, permission denied etc..
Before this 4.0.4. root work perfect.
So this is sucks.
#467
Posted 15 March 2013 - 05:45 PM
Sent from my DROID RAZR using Xparent BlueTapatalk 2
#468
Posted 15 March 2013 - 05:48 PM
debbugging is on, MTP is on .
any ideas?
OG RAZR
#469
Posted 15 March 2013 - 08:03 PM
#470
Posted 15 March 2013 - 08:07 PM
I followed everything exactly as it stated in the tutorial. it mentioned no su and busybox and SuperSU states no su binary file. any clues as to what happened?
Usb debugging on?? In Mtp mode of usb? Cleared data on smart actions?? If yes to all these try a reboot and run it again.
- plainbum and str8fan7 like this
#471
Posted 15 March 2013 - 08:29 PM
that was where I messed up. I forgot to go into MTP mode. Thanks for the quick reply and help! Appreciate it!Usb debugging on?? In Mtp mode of usb? Cleared data on smart actions?? If yes to all these try a reboot and run it again.
- Memnoch73 likes this
#472
Posted 16 March 2013 - 09:32 AM
First sorry I am very new to this..
I just ran this and it completed successfully.
Here comes the stupid question, how do i know if my phone is rooted ?
Thank you in advanced.
#473
Posted 16 March 2013 - 09:37 AM
- smartboy123us likes this
#474
Posted 16 March 2013 - 09:38 AM
#475
Posted 16 March 2013 - 09:43 AM
#476
Posted 16 March 2013 - 10:24 AM
Thanks worked.. I am rooted!You can install from the playstore a app called root checker free
#477
Posted 16 March 2013 - 10:26 AM
#478
Posted 16 March 2013 - 12:28 PM
Basically can i use supersu to fully unroot? then update, then use this to rooting method to re-root my razr with the new jb build?
#479
Posted 16 March 2013 - 12:36 PM
#480
Posted 16 March 2013 - 01:02 PM
I am rooted running 4.0.4 stock rom , didn't install the jb leak back on christmas. Do i need to unfreeze al apps that are frozen and use SuperSU to completely unroot before the recent offical update will take?( got the smartactions part down)
That's all I did, removed safe strap 3.11 via the app, used supersu un root, then installed the downloaded update. Allowed update, used this exploit to reroot, reinstalled safe strap and now I'm trying roms again.
