848 replies to this topic
#301 mpodval
mpodval
  • 85 posts
  • Twitter:mpodval
  • Google+:mpodval
  • LocationNew York
Posted 12 February 2013 - 08:03 PM
If you are running superuser you can use voodoo ota root keeper to back up root then temp unroot when using the email client. If you are using SuperSu there is a temp unroot option available also but not sure if you have to buy the pro or not to use it. Superuser app does have a temp unroot option if you swipe to the left screen but I personally haven't used it. The bad thing is you will have to temp unroot when using the email client then restore root/uncheck temp unroot in some cases when you are done. Might be a little tedious lol.
Yes! I didn't even think about using voodoo. That could work! My company subsidizes our data plan. So I guess I can unroot/root as I am essentially getting paid to do that now vs losing the subsidy by taking a blackberry.I really hope this method works
  • tmyinc likes this
#302 mpodval
mpodval
  • 85 posts
  • Twitter:mpodval
  • Google+:mpodval
  • LocationNew York
Posted 12 February 2013 - 08:04 PM
Thank you tmyinc.
#303 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 12 February 2013 - 11:28 PM
Thank you tmyinc.
You are welcome. Hope it works out for ya. Good luck.
#304 corrsfan99
corrsfan99
  • 41 posts
  • Twitter:corrsfan99
Posted 13 February 2013 - 07:43 PM
Here's a question. I'm a longtime SuperUser Elite user. Is there a way to use SuperUser instead of SuperSU? Not sure if I can replace files or what the best way to go about it is.
#305 cmh714
Posted 14 February 2013 - 07:06 AM
Guys,
I will really need help on this one. My company is trying to stick it to us! We use GOOD technologies as an enterprise server for emails/address books/calendars. To get GOOD to work I even gave up my unlimited data!
Now my company is saying that anyone that has a rooted phone can't use GOOD and must go back to using a blackberry. A BLACKBERRY!!! I called GOOD and they confirmed they have the ability to see whether I am rooted or not.
I don't want to go back to a BB! Is there any way to disguise my phone's rootiness?
Any help would be apprieciated
Yes, use Divide. I dont believe that temp un-rooting will work for you, as it hasnt for me in the past for this type of situation. Divide creates a separate partition for you to keep work in. Try that and see if it works.
#306 cmh714
Posted 14 February 2013 - 07:07 AM
You would need to uninstall SuperSU and install superuser
#307 mindhead1
mindhead1
Posted 15 February 2013 - 03:01 PM
. It is untested as I don't have a razr in JB to try. If it needs fixing, please, let us know and we can iron it out. Thanks
I tried rooting my Razr MAxx on my Mac, but was not successful. I kept getting the following error.
link failed File exists
Used the Windows version on my other machine and the process went smoothly. I am now rooted and on JB. Is this the equivalent of giving Big Red the finger?
#308 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 15 February 2013 - 03:10 PM
Only if you can unlock the bootloader but its close lol
#309 cmh714
Posted 15 February 2013 - 03:26 PM
When playing with the phone I have better luck using Windows in a VMWare from my Mac, than the Mac utilities....
#310 Arsonik
Arsonik
Posted 15 February 2013 - 10:49 PM
So I've searched high and low for a solution to this, but to no avail.
I have followed the prerequisites and directions exactly as displayed, I have the proper drivers, etc. but I continue to get this message:
[*] Waiting for device...
* daemon started succesfully *
error: more than one device and emulator
[*] Device found.
[*] Phase one...
[*] Rebooting device...
[*] Phase two...
So on and so forth. I've tried a factory reset, uninstalling and reinstalling drivers, removing and re-adding any associated devices in my device manager. Nothing works.
And as a side note, when it claims to be doing something, (ie: rebooting the phone) nothing happens.
Any help would be vastly appreciated.
EDIT: Figured it out. Apparently the Bluestacks App Player causes a conflict with emulation. So for anyone else who experiences this, just uninstall Bluestacks or any other emulators from your computer and you're good to go.
  • stullos7 likes this
#311 cmh714
Posted 16 February 2013 - 10:36 AM
[quote/]
[/quote]
Good info thanks for sharing!
#312 Abcent
Abcent
Posted 18 February 2013 - 02:10 PM
Can't figure out what I'm doing wrong.. I have never used smart actions before so it was the first time I opened the app, I am in USB debug mode with mock locations on and unknown sources on, I was on 4.0.4 and the other day I manually installed 4.1.2 and lost root and want it back tried using this exploit and this is how it goes..
[*] is connected via USB.
[*] Device found.
[*] Phase one...
link failed No such file or directory
[*] Phase two...
.jar: No such file or directory
[*] 2. Select "Get Started".
[*] 4. Select "Save".
[*] 5. Press the Home button.
848 KB/s (3477 bytes in 0.004s)
arJarDex.jar: No such file or directory
[*] Phase four...
117 KB/s (91992 bytes in 0.764s)
2173 KB/s (1867568 bytes in 0.839s)
3030 KB/s (574184 bytes in 0.185s)
1113 KB/s (63838 bytes in 0.056s)
[*] Cleaning up...
failed on '/data/logger.bak' - No such file or directory
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
  • wooddale likes this
#313 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 18 February 2013 - 02:23 PM
Usb debuging is in developer options. Why dont you use the other method worked for me
#314 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 18 February 2013 - 02:26 PM
Some people have had to uninstall all the updates for Smart Actions. That may be your issue
  • wabmorgan and Abcent like this
#315 Abcent
Abcent
Posted 18 February 2013 - 02:28 PM
Just read that from here
About half way down the page someone commented saying that and I'm gonna say that's gotta be it.. Uninstalled updates rebooting phone.. Will edit with result..
EDIT: Uninstalled updates and everything worked fine after that.. Root success.. Thank you Memnoch73!!
  • Memnoch73 likes this
#316 Memnoch73
  • 5,016 posts
Posted 18 February 2013 - 02:49 PM
Awesome man. Glad we got you up and running...
#317 huff825
huff825
  • 87 posts
Posted 18 February 2013 - 02:56 PM
Just FYI, I uninstalled all smart actions updates and used MTP mode instead of mass storage. Failed 4 times before I did this, then worked flawlessly.
Sent from my ASUS Transformer Pad TF300T using Tapatalk 2
#318 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 18 February 2013 - 03:00 PM
Huff I no you were from the old Bionic Moto forum
#319 huff825
huff825
  • 87 posts
Posted 18 February 2013 - 03:20 PM
Guilty. Moved to the RAZR MAXX after a long struggle with the Bionic. Very happy with it.
Sent from my Droid RAZR MAXX using Tapatalk 2
#320 huff825
huff825
  • 87 posts
Posted 18 February 2013 - 03:56 PM
This forum moves a bit faster than the other. Although I'm a noob here. Yeah!
