848 replies to this topic
#261 dmlsthe1
dmlsthe1
  • 127 posts
Posted 02 February 2013 - 01:54 PM
Don't keep me in suspense. LOL do you know how to do it. will definitely work with 4.1.1? So for all the tethering apps I found so far they keep on prompting me saying checking subscription plan. will this fix it?
The sqlite hack should fix that but i don't know how to do it off top of my head. I use wifi Tether for root users. Have you tried it?
#262 superfly611
superfly611
  • 7 posts
  • LocationUSA
  • Current Device(s):Droid Razr Maxx HD & Vizio Tablet
Posted 02 February 2013 - 03:50 PM
my phone is not rooted and im running 4.1.1 i'm afraid to root it. i really dont want to brick it and that would be my luck.
#263 durango992007
durango992007
  • 7 posts
Posted 02 February 2013 - 04:38 PM
I understand that this answer might be in the thread somewhere, but it might just be a little easier to ask and have some answer than read the whole thread. Is it possible to return back to stock 4.1.2 JB after rooting? Not really sure I want to root and and not be able to revert back to stock. Thanks a lot!
#264 dmlsthe1
dmlsthe1
  • 127 posts
Posted 02 February 2013 - 04:45 PM
I don't think it's possible to get free wifi without root on jb. I believe Foxfi was the only way but it does not currently work on jb. There may be options through usb but i don't think you'll find wifi tethering possible without root.
Before i had root my phone when i was on ics i tried using the built usb tethering and it worked. I didn't get redirected to any Web pages or anything. I never saw anytime mention that but thought you might think it's worth a shot.
I'm totally unsure of this part but from my understanding you should than be able to use (a capable) computer as Thu wifi hotspot using the internet being tethered through usb. I saw the possibility on windows 7
#265 dmlsthe1
dmlsthe1
  • 127 posts
Posted 02 February 2013 - 05:20 PM
I'm not too sure how it works but you can check out the unbrick utility.
Edit: do not use the unbrick utility if you are already on jellybean
#266 cmh714
Posted 02 February 2013 - 05:37 PM
I'm not too sure how it works but you can check it the unbrick utility here
Do NOT use that utility. Its not for you.....Once you root the best you can do is "unroot". However, depending on your phone, there is a code that says whether you are or have been rooted.
#267 superfly611
superfly611
  • 7 posts
  • LocationUSA
Posted 02 February 2013 - 06:03 PM
I used to use that app. It worked great Until Verizon got smart. I could probably deal with just doing USB tethering. I know PDA net works great so far. I wonder when Verizon will get smart to that. Should I do something to prevent it from doing an update and preventing that from working?
If I don't really mind dealing with the USB tethering. why else should I root? What else would be some of the benefits to it?
#268 superfly611
superfly611
  • 7 posts
  • LocationUSA
Posted 02 February 2013 - 06:09 PM
Yes I read that thread more carefully and I see it says Do Not use this if you have jellybean. Good thing I did not try it yet and brick my phone.
#269 cmh714
Posted 02 February 2013 - 06:42 PM
Making backups, custom ROM's that run better...
#270 dmlsthe1
dmlsthe1
  • 127 posts
Posted 02 February 2013 - 06:52 PM
Sorry about making that so easy to mess yourself up. I updated the post and took out the link for people who just jump into to it without reading. I also added that you shouldn't you use if you're on jb. However, i thought that someone had used it to return to stock for warranty purposes which is why i posted it. Once again my apologies. I was only trying to help
+1
P.s. Many custom ROMs have have tweaks such as 1% battery, volume rocker to skip songs, and many others
#271 superfly611
superfly611
  • 7 posts
  • LocationUSA
Posted 02 February 2013 - 07:24 PM
no worries man. it would've been my fault if i didn't do my research and read more. i was being lazy and skimming.
as for battery tweaks and things like that, its not to appealing to me. i guess rooting wouldn't be for me. the only main thing i would like to have back is wifi tethering but its ok dealing with a wire. its cool.
#272 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 03 February 2013 - 08:23 AM
For some reason all my emails from this forum are going to spam I requested instant on delivery. I didnt realize it at first because I dont ck spam very often. Am I doing something wrong should I set something different? Doing the same on phone as well.
#273 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Posted 03 February 2013 - 09:34 AM
Add to safe list, unspam
Site Rules and Guidelines
#274 Redalert
Redalert
    Half Man, Half Amazing
  • 1,198 posts
  • Current Device(s):Note 3 / Razr Maxx / Droid2 / LG Ally / Moto Q / Nexus 10
Posted 03 February 2013 - 09:54 AM
Make sure the domain is added to safe as well.
Sent from my DROID RAZR MAXX using Tapatalk2
#275 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 03 February 2013 - 10:33 AM
I Ill try that weird though that one came through may be it is because Im on AOL.
#276 copax
copax
Posted 03 February 2013 - 04:06 PM
I apologize in advance if this is answered somewhere else in the thread, I did my best to look for it. I got the razr maxx hd yesterday, and fully updated OTA. Later I decided I'd try to root it. I tried the steps listed in the OP but ran into problems others have had, permission denied errors, ln failures, etc. Some have said this is due to still being on ICS, but I'm currently running 4.1.1. I tried doing a factory reset, but I'm still running into the same problems. I've seen people mention reapplying the OTA update after a factory reset. How do I do that? Is there someplace I can download the latest update and reapply off of the sd card?
#277 livinginkaos
Posted 03 February 2013 - 04:19 PM
This thread is for XT912 only not the HD. For the HD , Since you are in JB you must roll back to ICS using matts utility
[Windows] and root then protect root, temp unroot, run the update, then back to root.
Let me know if I missed something. I'm still sick and not thinking 100%.
DROID BIONIC on 246 via Tapatalk
#278 copax
copax
Posted 03 February 2013 - 04:23 PM
My apologies. Thank you livinginkhaos, I got confused.
#279 livinginkaos
Posted 03 February 2013 - 04:48 PM
No prob.
#280 samuelsonv82
samuelsonv82
  • 6 posts
  • LocationSan Diego
  • Current Device(s):RazR XT912
Posted 06 February 2013 - 06:00 PM
After the root is complete, how do I get rid of the factory apps like facebook and kindle? Also, does the appearance not change at all?
