848 replies to this topic
#241 tucstwo
  • Google+:tucstwo@gmail.com
Posted 25 January 2013 - 06:41 PM
On topic, this topic has a new home in Off Topic. Go find it if you care :)
#242 Droidin
Droidin
  • 15 posts
Posted 27 January 2013 - 11:42 AM
The exploit says it is not compatible with the RHD. Does anyone know why?
#243 robocuff
robocuff
  • 415 posts
Posted 27 January 2013 - 04:56 PM
Ummm; because it doesn't work with the RHD? ;)
Sorry, but the answer seemed kind of obvious. That said, I suppose the hole in Smart Actions that's exploited here doesn't exist in the HD.
#244 livinginkaos
Posted 27 January 2013 - 06:24 PM
not to worry though, the HD currently has the ability to roll back to ics and take root there and rootkeeper back to JB.
DROID BIONIC on 246 via Tapatalk
#245 Droidin
Droidin
  • 15 posts
Posted 27 January 2013 - 08:50 PM
I guess I should have seen that coming :P
I was hoping not to have to go backwards first. This one seemed much easier.
#246 ufkal
ufkal
  • 14 posts
  • Current Device(s):Razr Max, Nexus
Posted 29 January 2013 - 01:47 PM
Ok, I've read through everything, and from what I gather, everything is pretty dang awesome. So that means I have questions.
1. I just rooted using the DroidRazrUtility 1.82 (major pain in the rear end[the phone, not the app]{thanks to all who helped me over there to get it fixed}
2. I am at complete STOCK. I didn't install any safestrap or anything.
3. Wife has just updated Smart actions and I understand that I need to a) force stop and then B) revert update c:) if the first 2 fail, factory reset.
4. If I want her to be on JB, I need to find the ripped OTA and flash it? {this is my big big question here}
5. Then I can root her to JB using this awesomesauce exploit.
6. Dig around the forums for how to configure the wifi tether to actually work for her laptop and tablet (that is all she wants anyway. )
Thanks for taking the time to read this, for letting a Noob Razr person ask questions. I can find my way around a Nexus or a Incredible or even the Transformer Prime. Motorola just kicks my rear end for some reason.
#247 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 29 January 2013 - 01:57 PM
You're good man. Just put the JB update on your sd card and flash through Moto stock recovery
Link for JB thread:
You can also follow the instructions in the JB thread to use OTA voodoo rootkeeper to save ICS root then upgrade
#248 ufkal
ufkal
  • 14 posts
Posted 29 January 2013 - 02:06 PM
Link for JB thread:
I'm going to facepalm myself for asking this..... Moto Stock recovery is Powerbutton and down volume?....
#249 Memnoch73
  • 5,016 posts
Posted 29 January 2013 - 02:07 PM
Lol... no worries. Hold both volumes and power from an off state
  • ufkal and kdemsky like this
#250 T Rex
T Rex
  • Current Device(s):Droid Razr XT912
Posted 30 January 2013 - 10:50 PM
Looking for some help rooting this phone. It has been a thorn in my side since the ICS update in July. Rooting Gingerbread==>no problem. ADB Drivers never wanted to work with ICS so no root. Recently flashed JB on my phone and the ADB is working again.
Ran the bat file the first time and got a failed root very similar to what everyone else has been posting. Erased the Smart Actions data and now I am getting what I have below.
Any ideas? If I have to do a full reset, is there any way to back up my phone w/o root so I dont have to download everything again and reconfigure it all?
Any help would be appreciated. Thanks!
#251 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Posted 31 January 2013 - 05:54 AM
Run this through CMD, then CD to the folder and run again, make sure you have MTP on and Debug
Site Rules and Guidelines
#252 cmh714
Posted 31 January 2013 - 07:16 AM
I believe some people actually DID have root even thought the message may have said failed. I would look and see first, but I agree with Satman, I run from a Command prompt.
#253 T Rex
T Rex
Posted 31 January 2013 - 07:36 AM
Tried running from cmd as admin but it didn't work out. I used a root checker and still have no root or superuser.
#254 T Rex
T Rex
Posted 31 January 2013 - 07:37 AM
Thanks for the help though!
#255 trent1234108
trent1234108
  • Current Device(s):RAZR XT912
Posted 31 January 2013 - 07:17 PM
you are above my favorite person right now. without being able to reset battery stats and set cpu to low when my screen was off my battery sucked! youre the man!!!
#256 superfly611
superfly611
  • 7 posts
  • LocationUSA
  • Current Device(s):Droid Razr Maxx HD & Vizio Tablet
Posted 31 January 2013 - 07:59 PM
i was sent to this thread from another link but i just wanted to know whether or not it's safe to use this on a droid razr maxx hd? I thought I saw somewhere that it was. I hate the fact that they took away free Wi-Fi tethering in the new update.
#257 Memnoch73
  • 5,016 posts
Posted 31 January 2013 - 09:37 PM
No this is for the 912 razr only.
What are you trying to do?? Go back to ICS?? Look for Matt's 1.10 utility in the Razr HD section
#258 superfly611
superfly611
  • 7 posts
  • LocationUSA
Posted 02 February 2013 - 06:57 AM
I basically just want to get my free WiFi tethering back. is there a video out there that shows the complete procedure on putting it back to Ice Cream Sandwich ? I'm a better visual learner I know you need that utility and I believe you need to hold the power and both volume buttons. it seemed like it didn't do anything when I did that. I will try it again.
#259 cmh714
Posted 02 February 2013 - 07:23 AM
Theres a tweak you can do using sqlite for wifi tethering. I suggest searching for that. It takes all of 5 seconds....
#260 superfly611
superfly611
  • 7 posts
  • LocationUSA
Posted 02 February 2013 - 11:17 AM
Don't keep me in suspense. LOL do you know how to do it. will definitely work with 4.1.1? So for all the tethering apps I found so far they keep on prompting me saying checking subscription plan. will this fix it?
