![Photo](http://www.gravatar.com/avatar/46f69c036d660df4701d68adeba1173e?s=100&d=http%3A%2F%2Fwww.droidrzr.com%2Fpublic%2Fstyle_images%2Fdark_matter%2Fprofile%2Fdefault_large.png)
#181
Posted 18 January 2013 - 04:55 PM
#182
Posted 18 January 2013 - 05:50 PM
Happy all is well for everyone that has xt912... but those of us with xt926 wonder when will it get root?
You have root. If you are on JB you need to use Matt's HD utility to go back to ICS then root and save root then install JB
Edit: is the info you are looking for
#183
Posted 18 January 2013 - 09:38 PM
#184
Posted 19 January 2013 - 07:04 AM
#185
Posted 19 January 2013 - 07:43 AM
Appreciate the response...new to all of this lingo. Of course my maxx hd is not rooted because all access to the files were denied in my xt926 when I ran the xt912 fix.You have root. If you are on JB you need to use Matt's HD utility to go back to ICS then root and save root then install JB
Edit:
Has anyone tried this rooting method for the xt926?
#186
Posted 19 January 2013 - 08:44 AM
I'm confused. Why did you run anything for the 912.
Maybe has a better explanation.
Use this utility to return to ICS. then install Voodoo OTA rootkeeper, Keep root with that app, take the OTA update to JB and then restore root.
Hope this helps
#187
Posted 19 January 2013 - 05:14 PM
Razr Blade, an exploit that gains root access on the Motorola Droid Razr running 4.1 (Jelly Bean), is available at:
To run the exploit (currently Windows only), download and extract the entire zip file, ensure your device is connected via USB, ensure you have the latest Motorola USB drivers installed, ensure USB debugging mode is enabled on your device, and double-click "run.bat".
PLEASE FOLLOW THE DIRECTIONS IN THE EXPLOIT CAREFULLY.
Please do not re-host or modify this exploit without asking permission first, since this makes support difficult and annoying.
Enjoy,
Dan (@djrbliss)
Paypal:
you're the best, no comment
#188
Posted 20 January 2013 - 09:56 AM
Then I read about this exploit.
![:)](http://www.droidrzr.com/public/style_emoticons/default/smile.png)
But three attempts later ... didn't work for me.
![:(](http://www.droidrzr.com/public/style_emoticons/default/sad.png)
Then ... the FOURTH time was the charm!!! Here's what I had to do to get the exploit to work.
- Go to Settings > Apps > scroll over to 'All' > then scroll down to SmartActions
- Press 'Force Stop' > press 'Uninstall Updates' > press 'Clear data'
- Lastly, going against the directions, I put my RAZR MAXX in 'Media device (MTP)' mode ... not 'Mass Storage'.
Rooted once again!!!
![B)](http://www.droidrzr.com/public/style_emoticons/default/cool.png)
#189
Posted 21 January 2013 - 05:13 PM
First try uninstalling any updates to the app "Smart Actions," and clear the data for that app. If that doesn't work, try starting with a fresh flash of the OTA. Wipe first through recovery, then flash.
I was getting the same screen as airborne82 and followed your instructions. Wiped phone, re-loaded OTA and started over - now I get this:
#190
Posted 22 January 2013 - 10:53 AM
#191
Posted 22 January 2013 - 12:47 PM
#192
Posted 22 January 2013 - 12:52 PM
#193
Posted 22 January 2013 - 12:54 PM
#194
Posted 22 January 2013 - 12:57 PM
#195
Posted 22 January 2013 - 12:59 PM
Here's the thread
#196
Posted 22 January 2013 - 01:23 PM
#197
Posted 22 January 2013 - 01:29 PM
get virgin smart action and all works well!
yippiiiii
#198
Posted 22 January 2013 - 01:32 PM
So I went to the thread, and tried to do the fastboot restore, but it gave me a prompt "to return to normal mode, first press power key to power down. Device is Locked Status Code: 0" I'm sorry for the stupid questions, just trying to figure this thing out before I go back to a rotary phone!
I'm thinking you should be good. Just power up the phone and see if it back to stock .211. What did the PC say? Does it look like the utility ran successfully?? Device locked is your locked Bootloader. Every Razr says that.
#199
Posted 22 January 2013 - 02:12 PM
#200
Posted 22 January 2013 - 02:35 PM
From that thread, I install the torrent and the utility to my SD card or my PC? I'm downloading it to my SD card right now and still have no clue if this is right or not.
No, not all... I'm not sure what you're referring to by torrent, as that's usually a term reserved for file sharing using a program like BitTorrent.
If Matt's Droid Utility 1.82 does not have instructions on the thread, then go to the thread for version 1.7. Either you haven't read the instructions, or are misunderstanding/ misinterpreting them. Both threads can be found under the XT912 Development (I think) section.
If after reading the instructions you have questions, there are help threads for both or you can post questions within the threads themselves.
Sent from my RAZR MAXX HD using Tapatalk HD
