#101
Posted 16 January 2013 - 03:50 PM
#102
Posted 16 January 2013 - 03:59 PM
Extract the whole zip to its own folder on your desktop. That error means you are running it from inside the zip or you only extracted the .bat file.Im getting a " 'adb' is not recognized as an internal or external command, operable program or batch file" after phase one. I get to the end and nothing happens to my phone...
WHAT DO I DO?? D:
- zooyork0721 likes this
#103
Posted 16 January 2013 - 04:18 PM
I'm currently using Atrix HD MB886 on 4.1.1.
#104
Posted 16 January 2013 - 04:22 PM
Will this work with the Atrix HD? I heard the Razr and Atrix are almost identical except for carrier and slight software differences.
[ROOT][Windows]-Razr-Blade:-Droid-Razr-4.1-JB-root-exploit#entry173345
Post 134
#105
Posted 16 January 2013 - 04:29 PM
Post 134
As far as I've gone with my research, MotoFail2Go does not work on 4.1.1 JB. I have been told by 3+ users on Reddit there is no way to root on 4.1.1 (as of 2 days ago), and no way to downgrade back to 4.0.4 that I could find. However some root guides say it works on any version, but those are from October, so I don't think they meant 4.1.1, which wasn't released until December.
#106
Posted 16 January 2013 - 04:35 PM
130
#107
Posted 16 January 2013 - 04:39 PM
[ROOT][Windows]-Razr-Blade:-Droid-Razr-4.1-JB-root-exploit#entry173289
130
Thanks, I haven't been on this forum for more than an hour, this was the first thread I've seen, and hope I'll be able to downgrade then upgrade back to keep root. Thanks, again!
#108
Posted 16 January 2013 - 04:41 PM
#109
Posted 16 January 2013 - 04:42 PM
#110
Posted 16 January 2013 - 04:45 PM
#111
Posted 16 January 2013 - 05:03 PM
#112
Posted 16 January 2013 - 06:48 PM
#113
Posted 16 January 2013 - 06:58 PM
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
[*] Rebooting device...
[*] Phase two...
[*] 2. Select Get Started.
[*] 3. Select Battery Saver.
[*] 4. Select Save.
[*] 5. Press the Home button.
780 KB/s (3477 bytes in 0.004s)
link failed File exists
[*] Phase four...
4775 KB/s (91992 bytes in 0.018s)
4359 KB/s (1867568 bytes in 0.418s)
2946 KB/s (574184 bytes in 0.190s)
2722 KB/s (63838 bytes in 0.022s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
- QDMama likes this
#114
Posted 16 January 2013 - 07:11 PM
Same here.guys, not working..have read the entire thread..uninstalled updates to smart actions and then cleared it's data..usb debugging enabled..in mtp mode..trying to avoid a factory reset at all costs..please tell me if i'm missing something obvious, thanks..
[*] Device found.
[*] Phase one...
[*] Phase two...
[*] 4. Select Save.
[*] Phase four...
[*] Cleaning up...
[*] Rebooting...
- QDMama likes this
#115
Posted 16 January 2013 - 07:30 PM
this is what it should read..
[*] Device found.
[*] Phase one...
[*] Phase two...
[*] 4. Select Save.
1788 KB/s (3477 bytes in 0.001s)
[*] Phase four...
2404 KB/s (91992 bytes in 0.037s)
3677 KB/s (1867568 bytes in 0.495s)
4565 KB/s (574184 bytes in 0.122s)
4142 KB/s (63838 bytes in 0.015s)
[*] Cleaning up...
[*] Rebooting...
hopefully, this will help some along as well..
- draculam3k likes this
#116
Posted 16 January 2013 - 08:05 PM
Open SQlite, go to "Setting Storage" with the tools, settings, settings, scroll down to number 79 entitlement check, move to the right and long press on the number should be a 1, select edit field, change the 1 to a 0, save and back out and reboot. You should have free wifi tether.)
Did all that, but 79 isn't entitlement in this build and could not find where it moved.
with that being said, i download this app from the market https://play.google.com/store/apps/details?id=com.googlecode.android.wifi.tether
And wifi worked well with that.
#117
Posted 16 January 2013 - 08:16 PM
#118
Posted 16 January 2013 - 08:51 PM
polar135: It's now 150, not 79.
#119
Posted 16 January 2013 - 09:16 PM
I first laughed with irony when I loaded the webpage and had seen this thread posted. Why? Earlier today I had called into verizon wireless about issues with my razr maxx and in light of things I will be receiving a brand new razr maxx later today.
I am greatly appreciative of all the developers hard work they have committed to their droidrzr.com fans.
#120
Posted 16 January 2013 - 09:39 PM
I'm using that app too. It seems to work well.
