Thanks Dan. Been wanting this for a while. My phone frequently was running with less than 60MB free and was SO SLOW. Buy having the ability to freeze the unwanted Verizon items, I'm back to 250MB free and the phone is working like a charm.
#661
Posted 18 September 2013 - 04:47 AM
#662
Posted 22 October 2013 - 08:33 AM
after many attempts at rooting my phone, and reading thru the forum, I am happy to say I finally was able to successfully root my phone! Thanks Dan!
#663
Posted 31 October 2013 - 09:04 AM
I have done a factory reset. I have updated all drivers. I have trying both installing and uninstalling updates on SmartActions, but I keep getting this message:
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
link failed No such file or directory
[*] Rebooting device...
[*] Phase two...
/data/data/com.motorola.contextual.fw/files/DataClearJarDex.jar: No such file or
directory
[*] 2. Select "Get Started".
[*] 4. Select "Save".
[*] 5. Press the Home button.
108 KB/s (3477 bytes in 0.031s)
/system/bin/sh: cannot create /data/data/com.motorola.contextual.fw/files/DataCl
earJarDex.jar: No such file or directory
link failed Permission denied
[*] Phase four...
1382 KB/s (91992 bytes in 0.065s)
1775 KB/s (1867568 bytes in 1.027s)
2860 KB/s (574184 bytes in 0.196s)
878 KB/s (63838 bytes in 0.071s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
#664
Posted 01 November 2013 - 05:20 AM
I had a lot of issues under Linux with the su not found and the errors about permission denied. I simply went into the razr_blade.sh shell script on line 50 and instead of sleeping for 40 I sleep for 140. I noticed it took awhile for the Razr to come back fully "online" after that reboot for whatever reason. So instead of:
echo "[*] Phase three (this will take a minute)..."
./files/adb shell "sleep 40"
I used:
./files/adb shell "sleep 140"
I hope this may help some others and thank you for the root!
This solution finally got the exploit working on my phone without needing a factory restore. Looks like it just takes a while for SmartActions to load once it reboots, and on a phone with a bunch of software already there, it just takes longer.
Thanks!
- smileyd23 likes this
#665
Posted 05 November 2013 - 06:39 AM
I finally got it rooted, thanks!
#666
Posted 20 November 2013 - 12:37 PM
Nothing is happening after:
[*] Cleaning up...
It has been over 10 minutes.
ugh what next??
Edit: Impatient me! - it is rebooting for the 4th time now!
#667
Posted 15 December 2013 - 09:36 PM
I am requesting assistance in troubleshooting the root process for my Droid Razr Maxx XT912 running 4.1.2 connected to my XP desktop. BusyBox Pro v9.6 is installed. SuperUser is not. Battery is at 100%.
I have done and redone the following:
- I uninstalled and downloaded Motorola Device Manager to ensure I have the latest drivers. (Even ran the check for driver update.)
- I uninstalled and installed SmartActions v4.2.2.4.2. Including clearing the data and ensuring there are no updates.
- I verified USB debugging is enabled and set connection to CTP (other attempts using MTP).
- After several attempts, I ran Razr Blade option 2 with success. Subsequent attempts to root still fail.
[*] Device found.
[*] Phase one...
link failed Cross-device link
[*] Phase two...
.jar: Permission denied
3 KB/s (0 bytes in 3477.001s)
arJarDex.jar: Permission denied
link failed File exists
[*] Phase four...
3085 KB/s (0 bytes in 543080.000s)
2483 KB/s (0 bytes in 1867568.000s)
3309 KB/s (0 bytes in 476557.000s)
1994 KB/s (0 bytes in 63838.000s)
[*] Cleaning up...
[*] Rebooting...
[*] Exploit complete!
* server not running *
#668
Posted 16 December 2013 - 04:29 AM
You can use Matt's utility do to that (and the root exploit is included in the utility) ... get it from here (if you don't already have it) ... (it will be the first utility on the list)
#669
Posted 16 December 2013 - 07:57 AM
That is the utility I used (options 2 and 3). You're suggesting I use option 1--with a data wipe, correct? (UGH)
#671
Posted 14 January 2014 - 04:52 PM
#672
Posted 14 January 2014 - 04:57 PM
Im the owner of the original RAZR and ended up rooting my phpne with Mr. Rosenberg since early 2013, now i received an update from my wireless company and now my phone reboots by itself in an infinite cycle, it is showing the green android laying on the ground with the chest open with a red triangle and an exclamation sign, any way somebody could help me with this? I will greatly appreciated. If you prefer to send me an email please do so at sacul210@hotmail.com
You can try going into recovery and wiping cache and davlik then reboot or if that doesn't work...
You need the Utility up in post #669
- cmh714 likes this
#673
Posted 27 January 2014 - 08:11 AM
Utility mentioned in post #668 to restore stock ROM and root phone, then VooDoo RootKeeper to backup root and disable root, then accept OTA update, then VooDoo to restore root.
#674
Posted 05 October 2014 - 02:21 PM
I have a XT912 and the rooting didn't work.
First time I did this I accidentally choose the mass storage instead of USB to the HD.
Once I realized the mistake I ran the utility again and it went fine. Except... the root utility froze on "Cleaning Up" for 10 minutes, then the Razr rebooted again and was done. There is the "SuperSU" app on my phone but when I used root checker it says it's not rooted. I'd like to get rid of bloatware.
How I can fix this? Advice is appreciated.
#675
Posted 05 October 2014 - 02:27 PM
sent from my G3
#676
Posted 05 October 2014 - 04:19 PM
I don't need to uninstall the files already on my phone?
#677
Posted 05 October 2014 - 04:35 PM
sent from my G3
#678
Posted 05 October 2014 - 06:09 PM
It says this is a root for 4.3 but I'm running 4.1.2, will that be an issue?
#679
Posted 05 October 2014 - 06:58 PM
sent from my G3
#680
Posted 06 October 2014 - 04:58 PM
It's stuck on the "ADB shell gain root permissions." My phone isn't showing the menu.
