684 replies to this topic
#641 cmh714
Posted 12 July 2013 - 07:13 AM
We can probably help but you need to provide more information than that. Do you know how to open the Terminal app? If you can do that and follow the instructions in the OP you shouldnt have too much trouble.
You can find Terminal in Applications/Utilities.
#642 twinsmagic
twinsmagic
  • 5 posts
Posted 15 July 2013 - 09:07 AM
I've followed I believe all of the instructions but it's still not working. It has installed superuser but when I check for root, it's not there. Here's a screenshot:
Any ideas?
#643 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 15 July 2013 - 09:12 AM
Any ideas?
The issue is probably with your smart actions updated. You can try to go into apps and clear app data and cache on Smart actions also uninstall updates if available. If none of these work then you will need to restore using the Utility and root prior to logging in to Google
#644 twinsmagic
twinsmagic
  • 5 posts
Posted 15 July 2013 - 09:20 AM
I did wipe the phone (not photos and such). I'm trying to do this now before logging into google. I can't go into the play store since I'm not logged into google. I'm stuck here. I did go to smart actions app info and clear data. When I rooted this phone a year ago, I had it done in 5 minutes. I'm going on 5 hours now...
#645 cmh714
Posted 15 July 2013 - 09:32 AM
If I were you I would use Memnochs other suggestion.....re-flash and start over.
Use the utility in this thread:
After you flash with Option 1 (or 2), do NOT login to Google and then immediately do the other Option for root, and you should be ok.
#646 twinsmagic
twinsmagic
  • 5 posts
Posted 15 July 2013 - 10:16 AM
I'm doing that now but when I go to install the drivers from that package, I get this error message: 07.15.2013-13.46.png
should I just continue on or should I first try to uninstall the Motorola Drivers that are on my computer? The phone I'm trying this on is Droid Razr Maxx XT912. Thanks.
#647 twinsmagic
twinsmagic
  • 5 posts
Posted 15 July 2013 - 10:24 AM
How do I make sure the phone is in AP fastboot mode?
Update: I figured out AP fastboot mode and now am running that utility. Fingers are crossed! My wife is giving me annoying looks (it's her phone)
#648 twinsmagic
twinsmagic
  • 5 posts
Posted 15 July 2013 - 11:52 AM
We're rooted! Thanks for your help!
  • Memnoch73 and cmh714 like this
#649 cmh714
Posted 15 July 2013 - 12:00 PM
Scary when you have to root the wifeys phone ;)
Glad the team could get you working again.
#650 rjack2
rjack2
  • Current Device(s):Razr Maxx, Tranzformer Prime
Posted 16 July 2013 - 10:48 PM
Just donated... Thanks...
#651 rksplace
rksplace
Posted 18 July 2013 - 01:57 PM
thankyou very much :D
#652 Clooney003
Clooney003
  • LocationIndianapolis
  • Current Device(s):Razr Maxx XT912
Posted 27 July 2013 - 05:40 AM
I rooted my XT912 well over a year ago and am still on Android version 4.0.3. How should I go about wiping my phone and going about this new method so I can get the latest ROMs?
#653 cmh714
Posted 27 July 2013 - 06:52 AM
Easiest way is to use Matts utility:
#654 kcody
kcody
Posted 19 August 2013 - 05:06 AM
Wanted to say that this thread was extremely helpful. I have now successfully rooted my RAZR, which is quite an accomplishment considering I needed Google's help just to find the command prompt on my Mac.
Thank you all.
  • Memnoch73, johnthehillbilly and livinginkaos like this
#655 milesbass123
milesbass123
Posted 22 August 2013 - 10:00 AM
i got this and i have no idea what i did wrong please help i am new to topic but not computers
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
[*] Rebooting device...
[*] Phase two...
[*] 2. Select Get Started.
[*] 3. Select Battery Saver.
[*] 4. Select Save.
[*] 5. Press the Home button.
1580 KB/s (3477 bytes in 0.002s)
link failed File exists
[*] Phase four...
2686 KB/s (91992 bytes in 0.033s)
3480 KB/s (1867568 bytes in 0.524s)
4027 KB/s (574184 bytes in 0.139s)
2641 KB/s (63838 bytes in 0.023s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
i used a DROID RAZR original 4.2.1 jelly bean
#656 Memnoch73
  • 5,016 posts
Posted 22 August 2013 - 11:44 AM
You're smart actions app has been updated. You need to fastboot back to stock then root prior to logging in to your Google account
#657 dougbert
dougbert
  • LocationColorado
  • Current Device(s):XT912 Razr Maxx
Posted 03 September 2013 - 06:19 PM
milesbass123,
It's been several days since you posted your issue.  I hope I'm not too late to help.
I ran the .bat file at least a dozen times.  I always saw the following errors listed while running the .bat file during Phase 3:
After much frustration, I re-read the majority of the previous posts.  I saw a suggestion, and decided I had nothing to lose, as I still wasn't rooted.  If your phone's anything like mine (250+ apps), it takes a long time before your interface is fully up and functional.  The suggestion was to increase the Sleep time in the .bat file from 40 to 80.  I increased to 100 just to make sure, though 80 might have worked just fine.
In the run.bat file, edit the following line in the run.bat file to read at least "sleep 80":
It currently reads:
echo [*] Phase three (this will take a minute)...
adb shell "sleep 40"
I ran the run.bat file again and I was rooted; no errors.  This is the only mod I made to anything.
Good luck!
  • 0ddh1nn likes this
#658 mikerosas
mikerosas
Posted 08 September 2013 - 09:12 PM
Hey any help here this is the outputI'm getting for my Razr Maxx from Telcel in México:
[*] Device found.
[*] Phase one...
[*] Phase two...
.jar: Permission denied
[*] 2. Select "Get Started".
[*] 4. Select "Save".
154 KB/s (3477 bytes in 0.022s)
arJarDex.jar: Permission denied
/system/bin/sh: can't create /data/dontpanic/apanic_console: Permission denied
[*] Phase four...
1448 KB/s (91992 bytes in 0.062s)
4025 KB/s (1867568 bytes in 0.453s)
4414 KB/s (574184 bytes in 0.127s)
3896 KB/s (63838 bytes in 0.016s)
[*] Cleaning up...
[*] Rebooting...
I have clear dat from SmartActions and I'm on MTP usb mode as required.
#659 mikerosas
mikerosas
Posted 08 September 2013 - 09:24 PM
PS Dpugbert extending sleep time didn't do the trick for me.... :wacko:
#660 0ddh1nn
0ddh1nn
  • Current Device(s):droid razr maxx
Posted 09 September 2013 - 07:04 AM
extending the sleep time to 80 worked like a charm after a half dozen unsuccessful attempts.  I have 212 apps installed.
  • cmh714 likes this
