Oh..please dont simply shoot here... I am unable to get y JB 4.1.2 rooted !
Have tried exactly as mentioned with all the prerequisites.
Posted 08 May 2013 - 08:07 AM
Posted 08 May 2013 - 08:21 AM
Because this exploit is not for the XT-910. You need
one
Posted 09 May 2013 - 02:09 AM
It can't find the device? I could just be a moron, but does that refer to a USB connection? Because it is connected...also says it can't find daemon.
Posted 10 May 2013 - 07:22 PM
Posted 10 May 2013 - 08:33 PM
Your Smart actions is updated. You can try clearing data of that app. If that doesn't work you need to do a factory reset then do root again prior to logging in to google.
Posted 13 May 2013 - 10:39 AM
After a couple months of rooted joy, my Razr Maxx is coming unglued now, probably from overheat. (I like to play web radio through Bluetooth audio devices with my phone plugged in to the charger. I guess that it doesn't have enough built-in heat sink capacity for that application.)
I just want to confirm that Razr Blade is still working on "new"/refurbished XT-912s before I wipe it and take it to the VZW store for a replacement. Are we still good?
Thanks.
Posted 13 May 2013 - 11:14 AM
Thanks.
Yeah. My device was a replacement that I got 3 weeks ago; razrblade worked last week
Posted 13 May 2013 - 11:47 AM
Thanks!
Posted 13 May 2013 - 07:34 PM
In the folder containing the rooting files, there is a Superuser.apk that I assume installs SuperSU.
However, I have a problem. With every screen recorder there is on Google Play, when I record, I only capture footage of a black screen. the startup screen (the Android logo, the gear, and the text, picture
Should I replace the Superuser.apk with another superuser apk? If I do that, when I run the batch file, will the new apk be installed, or will I brick my phone?
Edited by ReconnaisX, 14 May 2013 - 09:35 PM.
Posted 23 May 2013 - 06:48 AM
I have just completed this process successfully. How can I verify that my phone has been successfully rooted? When I open up Clockwork Rom Manager it says that it is not. Any help would be appreciated.
Posted 23 May 2013 - 08:24 AM
) I assume SuperSU is the source of this problem, as someone I know uses Superuser (by ChainsDD), and he can record just fine.the startup screen (the Android logo, the gear, and the text, pictureShould I replace the Superuser.apk with another superuser apk? If I do that, when I run the batch file, will the new apk be installed, or will I brick my phone?
Just root normally. After you have rooted, install superuser from the play store and remove superSU
search "rootchecker" on the play store. It will tell you if you have root
Posted 23 May 2013 - 09:15 AM
I have both of the reccomended apps, and both say that I am not yet rooted? I followed all of the on screen prompts and the process said it was successful. Any suggestions?
Posted 07 June 2013 - 07:21 AM
Posted 10 June 2013 - 09:53 AM
thanks amazing job
best regards
Posted 18 June 2013 - 08:45 AM
New to the rooting game. Rooted my RAZR Maxx to make use of AdBlock Plus over 4G. The root worked and ABP is working fine, however when trying to connect to the guest wireless network at my work I can no longer make it to the authentication screen and get errors about not being able to connect to a secure server and cannot use the internet. Is it possible my network can tell my phone is rooted or something may have messed up during the root process?
Posted 19 June 2013 - 07:55 PM
Nothing happens after "daemon started successfully."
Posted 19 June 2013 - 10:08 PM
ADB debugging on? USB connection set to MTP, not mass storage? Latest drivers installed?Nothing happens after "daemon started successfully."
Posted 20 June 2013 - 06:09 AM
ADB debugging on? USB connection set to MTP, not mass storage? Latest drivers installed? Sent from my DROID RAZR using Tapatalk 4 Beta
not a USB 3 port and use the Moto cable too
Posted 23 June 2013 - 03:53 PM
Success! Thanks, for this.
I was worried, because everyone said you must uninstall Smart Action updates or it wouldn't work.
I had no "Uninstall Updates" button, but the script worked perfectly the first time.
Thanks, Joe
Posted 11 July 2013 - 08:53 PM
sorry guys i am a total nube when it comes to using terminal on my mac. can some one tell me how to run this root?
