684 replies to this topic
#601 Zeenah
Zeenah
  • Current Device(s):Motorola Droid Razr Maxx
Posted 30 April 2013 - 06:21 PM
Please read up a few posts... You need to do a factory reset then root again prior to logging in to Google
Thank you so much. I was intimidated by the lack of knowledge on the matter to go through the threads, but this has helped! I appreciate it!
  • Memnoch73 likes this
#602 Warus
Warus
Posted 01 May 2013 - 03:21 AM
[*] 5. Press the Home button.
780 KB/s (3477 bytes in 0.004s)
[*] Rebooting device...
link failed File exists
So I have seen multiple of people having this error. And the fix is to is to wipe data and cache or something. I did not do that. I did not want to loose any or have to reinstall my stuff. So I went back to the instructions and read again as you are suppose to do when you have an issue BEFORE you post to ask what you did wrong.
In the instructions in the rooting program says:
"Before continuing,ensure USB debugging is enabled, that you have the latest Motorola drivers installed, and that your phone is connected via USB."
Another post says:
Windows-
-Download the zip file and extract.
-Connect device via USB (Make sure you have the current Moto drivers FIRST!)
-Make sure USB Debug is on
-Make sure you have Smart Actions fully installed, unfrozen and unmodified
-Make sure the phone IS NOT in mass storage mode
-Double click run.bat
And someone else somewhere said "Mass storage should be turned off" but did not give much more than that till a page or two later.
Then in the root program it says:
[*] 2. Select "Get Started".
[*] 4. Select "Save".
The first time I tried this rooting program my problem was I saw no "Get Started" In the "Smart Action" app. So I clicked the "+" at the top and clicked "battery saver" as the instructions said then clicked save. BUT I got the same errors as others are getting. At the beginning I had that "Smart Actions" thing disable so I went to Google Play Store, searched it and enabled it. I had uninstalled all the updates months before and disabled under "Settings>apps>All" trying to get rid of that thing.
Zeenah: thanks for your update. I too was stuck and unable to root because I had some smart actions already programmed  Once I deleted them.. everything works just fine and I'm now among the ROOTED!
#603 MoonspellPL
MoonspellPL
  • 6 posts
  • LocationPoland
  • Current Device(s):XT910 - JB
Posted 02 May 2013 - 08:00 AM
In process I get "Permission Denied"
I've tried this 3 times now, I cant get this to work :-(.
I have Debugging enabled, I connect as MTB, I did factory reset, I did the Smart Action thing and yet I am failing :-(
Please help!
#604 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 02 May 2013 - 08:06 AM
I notice you have an XT-910. This is for the 912 only.
You can use
one however it will require Linux
#605 MoonspellPL
MoonspellPL
  • 6 posts
  • LocationPoland
Posted 02 May 2013 - 08:23 AM
You can use
I see, however on this video
it clearly says Razr and Razr MAXX. So it is all a bit confusing.
#606 Memnoch73
  • 5,016 posts
Posted 02 May 2013 - 08:35 AM
Yes those are DROID Razr XT-912. You have a RAZR XT-910.
#607 MoonspellPL
MoonspellPL
  • 6 posts
  • LocationPoland
Posted 02 May 2013 - 08:57 AM
Fantastic, thanks for the info. And sorry for the trouble.
#608 thetastycat
thetastycat
  • Current Device(s):XT912
Posted 04 May 2013 - 06:09 PM
Here's my sob story:
[*] Motochopper: Android root exploit (Windows version)
[*] v1.0
[*] Tested on the Motorola Razr HD, Razr M, Razr Maxx HD, and Atrix HD.
[*] Supports lots of other devices as well. ;-)
[*] Before continuing, ensure that USB debugging is enabled, that you
[*] have the latest USB drivers installed, and that your phone
[*] is connected via USB.
[*] WARNING: This will likely void the warranty on your device. I am
[*] not responsible for any damage to your phone as a result using this
[*] tool.
[*] Waiting for device...
[*] Device found.
[*] Pushing exploit...
4164 KB/s (1283460 bytes in 0.301s)
[*] Pushing root tools...
3208 KB/s (91980 bytes in 0.028s)
4291 KB/s (1867568 bytes in 0.425s)
4171 KB/s (969701 bytes in 0.227s)
        pkg: /data/local/tmp/Superuser.apk
Failure [INSTALL_FAILED_ALREADY_EXISTS]
[*] Rooting phone...
[+] This may take a few minutes.
[-] Failure.
[*] Cleaning up...
[*] Exploit complete. Press enter to reboot and exit.
Anybody have any ideas?
Many, many thanks.
#609 cmh714
Posted 04 May 2013 - 07:32 PM
Many, many thanks.
Well, lets see.....your profile or whatever says you have an XT912, so if thats the case, we get to have a good laugh as the utility you are using doesnt work on that device.... :)
You would need Razr Blade. If you have one of the devices listed, than you have a problem but posting here wont help as much as posting in the right place.
#610 thetastycat
thetastycat
Posted 05 May 2013 - 07:41 AM
Okay, I'm seriously confused - I have a Razr Maxx and I downloaded and tried the file at the beginning of this thread - have I messed up?
Thanks all.
#611 cmh714
Posted 05 May 2013 - 07:56 AM
Thanks all.
Messed up, not anything that we shouldnt be able to get right :)
But when I try the links in the OP, I get the correct utility for the XT912.
You posted this: [*] Motochopper: Android root exploit (Windows version)
What you should have and is in the OP should say this: [*] Razr Blade: Motorola Droid Razr 4.1 Root Exploit (Windows version)
#612 engineer333
engineer333
  • LocationCT
  • Current Device(s):Droid Razr, GSIII
Posted 05 May 2013 - 08:45 AM
So, how long till it finds my phone?  Only got to here.....
and thats it.  Thoughts?
***edit
GOT IT!  USB wasn't showing up in Device Manager... used another!  Finishing now!
***edit edit
I think it worked..... wasn't sure if I should do anything when it asked about Superuser requests.... third time I hit grant.
Thank you so much for this!  Been waiting for this day for over a year!
#613 thetastycat
thetastycat
Posted 05 May 2013 - 10:46 AM
Well I'm a complete moron - how did I do that? Thanks a ton, cmh - lemme try again.
  • cmh714 likes this
#614 cmh714
Posted 05 May 2013 - 11:03 AM
No worries, we have all been there before :)
If you cant get Razr Blade to work, it may be because your Smartactions got updated. You can try to remove the update, via Manage Apps, find the 3 smart actions apps and clear the update. If that doesnt work, the easiest thing is to get Matts all-in-one JB utility,
Use Option 1 which will wipe the phone, install JB fresh and then without setting up your Google account, use Option 3 to root.
#615 thetastycat
thetastycat
Posted 05 May 2013 - 06:13 PM
Worked perfectly.  I really, really appreciate it  :D
#616 cmh714
Posted 05 May 2013 - 06:19 PM
Good deal, glad it worked
#617 atearwhofellnot
atearwhofellnot
Posted 07 May 2013 - 04:39 AM
Wonderful, thank you very much
#618 dan4590
dan4590
Posted 07 May 2013 - 10:24 AM
Is there a method to root my bionic running JB?
#619 Memnoch73
  • 5,016 posts
Posted 07 May 2013 - 11:18 AM
Will need to be done in Linux though
#620 birdbrain5381
birdbrain5381
Posted 07 May 2013 - 05:13 PM
For those using the OSX / Mac script, I updated the razr_blade.sh file in order to get it to install. Like others in the group, I was getting the error that others have posted where the script would fail. Rather than perform a FDR i used it as a clue that perhaps the phone hadn't completely settled down yet when the script was trying to continue. So, my change was to change the Sleep command in the script from Sleep 40 to Sleep 80. After making this change, the script ran perfectly.
Hope this helps anyone with the problem on a Mac, although I suspect the same situation could apply for a PC.
This was also required on the linux script.  Fixed and worked like a charm.  This works for the chmod error at step 3 that many users have posted.  If any linux user isn't saavy enough to edit the script, I'd be happy to assist - it's all about learning new things!
