684 replies to this topic
#581 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 24 April 2013 - 05:49 AM
I'm thinking you will need to wipe data with Matt's Utility. Then do root prior to logging into Google.There has been an issue with Smart actions being updated causing the root exploit not to work. But a fresh install usually takes care of it.
IMO...
Smart Actions seems to conflict with System Apps
Its Bubba
~Stubborn In Your Bones~
#582 helloitsjackk
helloitsjackk
  • 9 posts
  • Current Device(s):Droid RAZR and Nexus 7
Posted 25 April 2013 - 11:42 AM
so did you touch "Get started" in "Smart Action" app?
Are you set to mass storage or MTP?
Yeah im doing both, but im giving up b/c nothings working!  :(
#583 freegood
freegood
Posted 25 April 2013 - 07:43 PM
Thanks so much Dan for rooting my phone. Maybe one of the few pleasures I have for a while. Thank you.
Sorry so long but hope this helps others. New to this forum. Usually over at the X place. But will be here more as this is just for my bada55 phone.
Again Dan, Thanks.
Thanks for documenting your journey/walkthrough. It helped me out a lot.
I also had to reboot three times despite reading this. The second time was because I thought I was smart and created the profile before hand...
Just delete all profiles and create Battery Saver during the root process.
#584 lindaj
lindaj
Posted 26 April 2013 - 08:48 AM
Hi All- lots of great tips here but still having issues. I have XT910.  I'm getting same error below as others are having I have tried about 30 times to get it working this morning.
I have enabled debugging mode. I have reset my phoneto factory defaults  but did log into google accounts. I have tried smart actions zillion times. emptying cache/data.  I am connected im MTP mode. I am using windows 64-bit.
I am about to try wiping data and fresh jb firmware as suggested, by Memnoch73 on post #457.
<a href="
">DROID RAZR Utility XT912 Jellybean -- Windows + Mac + Linux (All In One!)</a>
 utility and use option :1 Flash Official Jellybean Firmware (Wipe Data)
I see there are warnings not to use on an an XT910- Is this just for rooting or can still use to wipe???
Thanks!
Linda
#585 lindaj
lindaj
Posted 26 April 2013 - 09:17 AM
I keep seeing all the posts saying this root is only for XT912 and NOT XT910 however is first original post is says:
So our fearless root master, Dan Rosenberg (
), has successfully achieved root for the JB OTA and it's here first on DR.com! This root exploit is applicable to the RAZR and RAZR MAXX (XT912).
To the best of my knowledge the Android RAZR is the XT910?????
 This might be causing  the confusion.
So will this work on not on the XT910?
#586 cmh714
Posted 26 April 2013 - 09:34 AM
No this one doesnt work on the 910 however the amazing Dan (djrbliss) came out with a new one that can get you root on the 910. Its on our front page called Motochopper
see here:
#587 lindaj
lindaj
Posted 26 April 2013 - 09:57 AM
Argh, well.. I did try using
 to wipe data and get clean jellybean firmware.
I am getting horrible error on start up...
AP Fastboot Flash Mode ( Flash Failure)
I can get out of this by turning off power then go into boot mode by pressing power and volume + Volume _ key at same time.. then choosing "normal boot" mode.
Everytime phone shuts down tho I get that screen and have to go thru whole thing again.
I am in a nightmare and feel like an idiot.
I have all ready tried factory reset from within phone and in recovery mode and still happening.
I would be very grateful for a solution.
Thanks again,
Linda
#588 cmh714
Posted 26 April 2013 - 10:38 AM
Thanks again,
Linda
You just need to get one thing to flash properly to get rid of that message and go forward. Even flashing logo.bin should fix this. We have some thread for this somewhere in our forum.....will see if I can find it
But as I said a fastboot flash logo logo.bin should work
  • lindaj likes this
#589 lindaj
lindaj
Posted 26 April 2013 - 12:19 PM
Thanks- I would really appreciate it. Not sure why after I did a reset I have jellybean. I was on rooted ICS and yesterday I did update without thinking about how it would unbreak phone.. woke up this morning with a frozen screen and have spent all day trying to get phone functional.
I would love to get some kind of a root ( and I am useless with linux so not an option) so I can restore with Titanium Backup.
Ideally I would like to go back a functioning rooted ICS.
I wonder if /when there will be an XT910 root? Is there much demand do you think
I am looking at this method, which requires downgrade to ICS root, then up to JB again.
It is for Maxx  but  I THINK it might work. I am very gunshy after disaster this morning :(
#590 cmh714
Posted 26 April 2013 - 12:45 PM
NOOOOOO Linda. You cannot downgrade to ICS. Not happening.
We have root for the 910 if thats what you have, look on the front page of the site or for Motochopper, that will get you root on a 910.
If you have a 910 you will need to get the 910 fxz files and flash them, we only have that for the 912 here
#591 cmh714
Also may be easier if you jump into the chatroom, you can realtime help
#592 rrsarge
rrsarge
Posted 29 April 2013 - 08:27 AM
On an OG RAZR XT912 98.72.16.XT912
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
link failed Cross-device link
[*] Rebooting device...
[*] Phase two...
.jar: Permission denied
[*] 2. Select "Get Started".
[*] 4. Select "Save".
[*] 5. Press the Home button.
1131 KB/s (3477 bytes in 0.003s)
arJarDex.jar: Permission denied
link failed File exists
[*] Phase four...
1860 KB/s (543080 bytes in 0.285s)
2994 KB/s (1867568 bytes in 0.609s)
3021 KB/s (476557 bytes in 0.154s)
2710 KB/s (63838 bytes in 0.023s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
[*] Exploit complete!
Hit ENTER to return.
Doesn't work for me.
#593 chromedarkfire
chromedarkfire
  • Current Device(s):razr xt910
Posted 29 April 2013 - 03:53 PM
Are you successfully rooted?
Sent from my DROID RAZR MAXX Limited Edition running Xparent Blue Tapatalk
i got this as well. and it didnt do a thing. didnt do a thing. just kept saying it was finished and yet everything just said it couldnt do it
#594 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 29 April 2013 - 04:03 PM
You guys need to do a factory reset then run this again prior to logging in to your Google account
#595 chromedarkfire
chromedarkfire
Posted 29 April 2013 - 10:06 PM
yeah mine was freshly installed to jellybean. still nothing
#596 Kach474
Kach474
  • 28 posts
Posted 30 April 2013 - 03:00 AM
Ok thanks. Il try to convince the wife to wipe it. lol she gets nervous when I toy with her phone. Thanks
#597 Memnoch73
  • 5,016 posts
Posted 30 April 2013 - 05:18 AM
Okay we need to dig deeper. First did you do it prior to logging in to Google??
Cover the basics... Moto drivers installed, USB cable that came with your phone, Fully unzip the files to your desktop, USB debugging on, Phone set to MTP mode??
Also take a read though this whole thread. There are many questions and answers that may be a fix for you.
Let us know more info and we can get ya going.
#598 Zeenah
Zeenah
  • Current Device(s):Motorola Droid Razr Maxx
Posted 30 April 2013 - 04:27 PM
Hi, Dan
Thanks for making this tool available to everyone. Truly appreciated!
I am having some difficulties rooting my Droid Razr Maxx, and I'm not sure why. I tried several times and this is what I get:
[*] Device found.
[*] Phase one...
[*] Phase two...
141 KB/s (3477 bytes in 0.024s)
[*] Phase four...
308 KB/s (91992 bytes in 0.291s)
1644 KB/s (1867568 bytes in 1.109s)
2346 KB/s (574184 bytes in 0.239s)
959 KB/s (63838 bytes in 0.065s)
[*] Cleaning up...
[*] Rebooting...
[*] Press any key to exit.
I truly appreciate any help! Thanks!
#599 Memnoch73
  • 5,016 posts
Posted 30 April 2013 - 04:30 PM
Please read up a few posts... You need to do a factory reset then root again prior to logging in to Google
#600 chromedarkfire
chromedarkfire
Posted 30 April 2013 - 04:44 PM
i managed to finaly get it to work. took some time to get it working and what not. just need to update superuser binary
EDIT: so tryed to do something that needed root. and it didnt work. says root isnt there. yet superuser was installed and the thing said the exploit was done
