#561
Posted 17 April 2013 - 04:49 PM
#562
Posted 17 April 2013 - 08:50 PM
Thanks! The exploit turned out great!!
#563
Posted 18 April 2013 - 01:34 AM
#564
Posted 18 April 2013 - 09:09 AM
Hurray! It's finally working!
I had to reset to factory defaults, and also in SmartActions the SAVE button was not available untill I have changed an event conditions manually (you can change anything there actually, to make the Save button enabled).
#565
Posted 20 April 2013 - 12:39 AM
Will this work on a Droid Bionic?
#566
Posted 20 April 2013 - 12:46 AM
I tried rooting with an older root program I used before, and got the:
Message -
I did check to make sure I was in MPT mode and debugging is turned on. - Not sure if I should try and run it again or what ?
#567
Posted 20 April 2013 - 01:20 AM
Message -
There is currently no root exploit for the Bionic if you're on JB.
Sent from Maximized FlyingPlatyRazrJellyRaptor
#568
Posted 21 April 2013 - 02:59 AM
#569
Posted 21 April 2013 - 06:04 AM
I updated the Razr giving all the wipes and factory reset but i lost Root access. How should I proceed to get Root access again? I'm from Brazil and only came out this month to upgrade to 4.1 JB. Can you help me?
We dont have much for you on the 910. Go to xda-developers.com for more information
#570
Posted 21 April 2013 - 08:58 AM
#571
Posted 21 April 2013 - 09:00 AM
#572
Posted 21 April 2013 - 05:17 PM
[*] 5. Press the Home button.
780 KB/s (3477 bytes in 0.004s)
[*] Rebooting device...
link failed File exists
So I have seen multiple of people having this error. And the fix is to is to wipe data and cache or something. I did not do that. I did not want to loose any or have to reinstall my stuff. So I went back to the instructions and read again as you are suppose to do when you have an issue BEFORE you post to ask what you did wrong.
In the instructions in the rooting program says:
"Before continuing,ensure USB debugging is enabled, that you have the latest Motorola drivers installed, and that your phone is connected via USB."
Another post says:
Windows-
-Download the zip file and extract.
-Connect device via USB (Make sure you have the current Moto drivers FIRST!)
-Make sure USB Debug is on
-Make sure you have Smart Actions fully installed, unfrozen and unmodified
-Make sure the phone IS NOT in mass storage mode
-Double click run.bat
And someone else somewhere said "Mass storage should be turned off" but did not give much more than that till a page or two later.
Then in the root program it says:
[*] 2. Select "Get Started".
[*] 4. Select "Save".
The first time I tried this rooting program my problem was I saw no "Get Started" In the "Smart Action" app. So I clicked the "+" at the top and clicked "battery saver" as the instructions said then clicked save. BUT I got the same errors as others are getting. At the beginning I had that "Smart Actions" thing disable so I went to Google Play Store, searched it and enabled it. I had uninstalled all the updates months before and disabled under "Settings>apps>All" trying to get rid of that thing.
Any way after my 3rd try I figured I am doing something wrong. Went to Smart Actions app and deleted all the profiles for anything in there. Mine only had 3 battery saver profiles and a sleep profile, just touch and hold and delete. NOW I see "Get Started". Now I am ready there.
So went to Setting>Developer Options and made sure "USB debugging" was checked. Even though it comes up when you plug USB in and says "USB debugging connected".
The mass storage thing was a little more as there seems to be no direct instrucitons I could easily find. So plugged in USB cable, swiped down "status bar" from top of screen, tapped "Connected as a mass storage" of which gave me a few options. I selected "MTP".
Tried the root program again. There it is, no more "permission denied". The "Cleaning" at the end took forever It seemed but I now have SU and root.
And sorry but I didnt wipe any data or anything like that.
Had a little time finding Safestrap that just says RAZR. Other stuff I have looked at says RAZR HD/MAXX of which I understand is different.
Installed just fine.
Now just need to find how to use Safestrap.
Thanks so much Dan for rooting my phone. Maybe one of the few pleasures I have for a while. Thank you.
Sorry so long but hope this helps others. New to this forum. Usually over at the X place. But will be here more as this is just for my bada55 phone.
Again Dan, Thanks.
- freegood and Warus like this
#573
Posted 21 April 2013 - 05:22 PM
OK where are the XT-912M GSM ROMs? Is it just no one had done because or new root? Can you add stuff like Touchwiz without screwing things up?
#574
Posted 21 April 2013 - 06:26 PM
Why is article pinned at the top of news...
#575
Posted 22 April 2013 - 09:06 AM
This is the first time I have rooted my Razr Maxx and it appears to have worked fine. Is there something on the phone I can check to confirm it was successful?
Next step is to flash to PagePlus. I have seen lots of posts and videos to do that, wondering if there are some instructions recommend more than the others?
#576
Posted 22 April 2013 - 01:49 PM
I keep getting...
1112 KB/s (3477 bytes in 0.003s)
- robertguero likes this
#577
Posted 22 April 2013 - 01:51 PM
Download this to check your root:
#578
Posted 22 April 2013 - 07:19 PM
so did you touch "Get started" in "Smart Action" app?I keep getting...
BUT NO ROOT
Are you set to mass storage or MTP?
#579
Posted 23 April 2013 - 11:54 PM
Hello. everyone. Looking for some help. I have tried several times to root my wife's razr 912 with no luck. All drivers are installed and updated. USB debugging is on and the phone is in MTP. Here is the log of the process.
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
link failed No such file or directory
[*] Phase two...
.jar: No such file or directory
11 KB/s (3477 bytes in 0.296s)
arJarDex.jar: No such file or directory
[*] Phase four...
822 KB/s (91992 bytes in 0.109s)
3508 KB/s (1867568 bytes in 0.519s)
2995 KB/s (574184 bytes in 0.187s)
3996 KB/s (63838 bytes in 0.015s)
[*] Cleaning up...
failed on '/data/logger.bak' - No such file or directory
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
Also to note when I get to the stage to enter smart actions and save the battery saver all goes ok however when I hit save. the phone has a yellow "error" under the action. I finish the exploit for the above results. I must also note that prior to taking the OTA update my wife's was rooted and there were apps frozen with Titanium Backup (including smart actions) I did express to her at the time in the event of an update that they should be defrosted prior to the update. That did not happen. The update was applied while all her apps were still frozen. Not sure if this is causing the issue. Since the update the phone has not seemed to have any issues operating but I'm not sure all the apps that were frozen are there. Anyway this is my issue and any help would be appreciated. My next steps are reapplying the update first with out a data wipe then with a wipe if needed. I wanted to get some ideas first before I try these, don't want to brick the phone. Anyway thanks for any help.
#580
Posted 24 April 2013 - 05:30 AM
I'm thinking you will need to wipe data with Matt's Utility. Then do root prior to logging into Google.There has been an issue with Smart actions being updated causing the root exploit not to work. But a fresh install usually takes care of it.
