684 replies to this topic
#521 rchampion
rchampion
Posted 31 March 2013 - 07:47 AM
Yup! Many times. Clear data each time I try. I just tried to "upgrade" (which was really a downgrade to an old version) smart actions and then "removing updates" to restore the app back to stock. This also did not help. I just keep getting:
Then I follow the Smart Action steps and after pressing enter get:
Later after "Cleaning up..." I get:
having the same exact issue - any luck?
#522 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 31 March 2013 - 08:02 AM
The only fix for this it seems is to use the Utility to return to stock JB then root prior to logging in to your google acct
#523 timwood
timwood
  • 6 posts
Posted 31 March 2013 - 08:51 AM
No luck yet rchampion. I haven't really tried anything since I originally posted. The longer I wait the staler my last Titanium backup gets. :-(
#524 tbetz
tbetz
  • Current Device(s):Razr Maxx XT912
Posted 31 March 2013 - 11:14 AM
So our fearless root master, Dan Rosenberg (
), has successfully achieved root for the JB OTA and it's here first on DR.com! This root exploit is applicable to the RAZR and RAZR MAXX (XT912).
Again, huge thanks to Dan for his diligent work!
I came to the Jelly Bean party too late (just a couple of weeks ago) to be able to use this glorious root hack.
When I run it I get this:
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
link failed No such file or directory
[*] Rebooting device...
[*] Phase two...
.jar: No such file or directory
[*] 2. Select "Get Started".
[*] 4. Select "Save".
[*] 5. Press the Home button.
0 KB/s (3477 bytes in 4.278s)
arJarDex.jar: Permission denied
link failed Permission denied
[*] Phase four...
701 KB/s (91992 bytes in 0.128s)
741 KB/s (1867568 bytes in 2.461s)
450 KB/s (574184 bytes in 1.246s)
760 KB/s (63838 bytes in 0.082s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
error: more than one device and emulator
[*] Exploit complete!
[*] Press any key to exit.
So, has Dan, or anyone, come up with a root hack that works with System version 98.72.16.XT912.Verizon.en.us ?
Thanks.
#525 Guest_BDH_*
Guest_BDH_*
Posted 31 March 2013 - 03:07 PM
[*] Device found.
[*] Phase one...
[*] Phase two...
[*] Phase four...
[*] Cleaning up...
[*] Rebooting...
Thanks.
This works on the .16 JB OTA just fine.
#526 gekko59
gekko59
Posted 31 March 2013 - 05:56 PM
Found this quote buried in this thread. Bringing it forward in time, in case it helps others as it helped me:
scratchsf, on 12 March 2013 - 10:10 PM, said:
For those using the OSX / Mac script, I updated the razr_blade.sh file in order to get it to install. Like others in the group, I was getting the error that others have posted where the script would fail. Rather than perform a FDR i used it as a clue that perhaps the phone hadn't completely settled down yet when the script was trying to continue. So, my change was to change the Sleep command in the script from Sleep 40 to Sleep 80. After making this change, the script ran perfectly.
Hope this helps anyone with the problem on a Mac, although I suspect the same situation could apply for a PC.
You do need to understand how to edit files in *nix to do this. Open your terminal, use nano or vi or vim, find the line "sleep 40" and change the 40 to an 80. Save and close the file, then run razr blade per the instructions.
#527 tbetz
tbetz
Posted 31 March 2013 - 10:50 PM
Thanks for the confirmation that I screwed up.
I missed unsetting Mass Storage mode.
If the attempt I'm running now fails, I'll try a wipe and start over.
#528 Guest_BDH_*
Guest_BDH_*
Posted 31 March 2013 - 10:59 PM
Lol no worries, wasn't trying to be rude or anything. Sorry if I came off that way.
#529 talha4prez
talha4prez
  • 12 posts
  • LocationU.S.
  • Current Device(s):Razr XT912
Posted 01 April 2013 - 07:01 AM
Hey I received the same message, but nothing has happened I have attempted 3 times, am I missing something. I've updated my drivers, turned on USB debugging, and switched from mass storage to media device. Am I missing a something?
[*] Device found.
[*] Phase one...
[*] Phase two...
217 KB/s (3477 bytes in 0.015s)
link failed File exists
[*] Phase four...
1149 KB/s (91992 bytes in 0.078s)
3071 KB/s (1867568 bytes in 0.593s)
2759 KB/s (574184 bytes in 0.203s)
1993 KB/s (63838 bytes in 0.031s)
[*] Cleaning up...
[*] Rebooting...
#530 cmh714
Posted 01 April 2013 - 07:41 AM
Do you have Safestrap installed?? It needs to be deactivated, as in the Recovery needs to be removed.
#531 talha4prez
talha4prez
  • 12 posts
  • LocationU.S.
Posted 01 April 2013 - 08:07 AM
I didn't but I figured out what I was doing wrong. This is for those (such as myself) that are getting the same:
I copied all of the files that were in the razer blade folder (minus the run.bat file) to the SD card in my phone and ran it again,
root successful.
Hope this works for you guys it just worked for me at 12:30 pm 4/4/13 (NOT AN APRIL FOOLS GAG)
#532 candilue
candilue
Posted 01 April 2013 - 05:53 PM
Yay!!! It worked for me!!!!!
#533 phnguyk
phnguyk
  • Current Device(s):razr
Posted 01 April 2013 - 06:51 PM
seems stuck at cleanup,phone screen keeps going on and off, about ten minutes now. Any ideas?
#534 phnguyk
phnguyk
Posted 01 April 2013 - 06:53 PM
What do you know, I post, it reboots, all is good.
#535 timwood
timwood
  • 6 posts
Posted 02 April 2013 - 06:05 AM
root successful.
This did nothing to help me. :-(
#536 timwood
timwood
  • 6 posts
Posted 02 April 2013 - 12:14 PM
I ended up wiping data and restoring back to stock JB using RAZR utility option 1. This allowed me to use the RAZR Blade root tool successfully. I hate that I had to wipe data. Thanks for the utility!
#537 RiverTroll
RiverTroll
Posted 03 April 2013 - 11:49 AM
Is it supposed to take a really long time to "Clean Up"? I have SuperSU in my apps list on my phone now, but the command prompt window has been saying Cleaning Up for 10 minutes or so now.
I had this problem myself, turns out the phone was sitting there (screen off) waiting for me to grant superSU permissions to something'r'other. As soon as i did that it finished cleaning.
#538 RiverTroll
RiverTroll
Posted 03 April 2013 - 11:52 AM
Fix for issue with no SU Binary
The first time the program ran all the way through, said complete, gave me that one superSU permissions ping that was keeping the cleaning up step hung on my PC (post above).
However, then when i tried to open superSU it gave "There is no SU binary installed and SuperSU cannot install it. This is a problem!"
Read through here more, went back and uninstalled the updates to smartactions. Just cleared the data and unticked autoupdate in the market. Then just ran the batch file again and ta-da!
Actually failed step 3 the second time around said
"failed on '/data/logger' - Permission denied
link failed File exists"
Obviously, all of those files were already there from the first batch run and I didn't have root access to mod them.
But still went to step 4, still completed, and still gave me root!
So no factory reset is required i think. Just go clear smartactions data and stop it from autoupdating. Then go again!
Thanks to DjrBliss. I bought him a beer or two :)
  • flakdroid likes this
#539 cldklr18
cldklr18
Posted 03 April 2013 - 01:40 PM
Awesome man thanx so much!!!!
#540 flakdroid
flakdroid
  • 21 posts
Posted 04 April 2013 - 07:14 AM
Hello all, for this to work for me I HAD TO SET THE USB MODE TO MEDIA DEVICE, after that it worked. I was thrown off by trying to uninstall updates to SmartActions, I dont think there were any updates to uninstall hence the option was not there for me. I also learned along the way that only apps that are built into the firmware (like smartactions) have the ability to uninstall updates... apps that youve downloaded do not.
In summary, you must set USB to media device for razer blade to work.
