684 replies to this topic
#501 RazrFTW
RazrFTW
Posted 28 March 2013 - 09:19 AM
Worked perfectly! Thanks guys, I had been waiting for official JB to release before going root. This was a real easy process.
#502 robocuff
robocuff
  • 415 posts
Posted 28 March 2013 - 02:01 PM
Ok so I uninstalled BMM, tried using quick boot app to boot into recovery on SafeStrap, still shows up at broken android, all I'm able to get into is stock recovery. Shouldn't it automatically boot into safe strap?
edit: tried re-installing safestrap, gives me this message: [INSTALL_FAILED_ALREADY_EXISTS]
If safestrap already exists on my phone why wont it load? ugh this is frustrating, sorry about all the questions. I'm completely new to this, first time rooting a phone.
That app is always going to boot you to the stock recovery. We have a locked bootloader so we can't flash the recovery partition which is what that app boots to. The only way to get into safe strap is to shut the phone down and then restart it. Then you'll see the screen that allows you to get into safestrap. You can use the quick reboot app if you want to but can't choose reboot recovery. If you use it you have to choose normal reboot. Then you'll see the safestrap screen when it reboots.
#503 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 28 March 2013 - 03:13 PM
What do steps 1 and 2 do? I had found the link to root my phone seperately so that's how I got it done prior to this thread. My phone was already on JB 4.1.2 from the OTA
Awesome, If your on the New OTA JB...All is Good...Step #1 or 2 is Irrevalant if you found another Source that works for you..
Its Bubba
#504 timwood
timwood
  • 6 posts
Posted 28 March 2013 - 05:25 PM
I've encountered the same exact problems as many others on this thread, specifically the "...DataClearJarDex .jar: No such file or directory" problem. No suggestion, that I've tried, has worked. Only thing I haven't done and I'm really, really trying to avoid is a factory reset. I tried running the exploit on one Windows 7 machine and also a Linux machine. I tried modifying the scripts waiting time when using the Linux script. I have smart actions version 4.2.2.4.2, but when I go to the play store on my phone it lists version 4.2.2.4.0 as the latest version. I don't have an option to uninstall updates for the smart actions app. Should I try to side load this older version from a backup? Would I even be able to do that without root?
Basically I want to avoid factory reset, so if anyone has suggestions it's greatly appreciated.
Thanks!
#505 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 28 March 2013 - 05:28 PM
Thanks!
Did you clear data on Smart actions??
#506 bamame
bamame
Posted 28 March 2013 - 05:34 PM
I used this method to root my maxx a few days ago and it worked like a charm. However, I have encountered a problem that hopefully someone here can answer. After my device was rooted, I performed a FDR to clean up everything. My phone was working great and I installed all my apps back using TB. Anyways, here is my problem. When I turn my phone off now it enters a bootloop and will stay on the red eye. The only way to have my phone boot properly is to perform another FDR. Does anyone know what I can do to fix this or have similar problems? Thank you
#507 timwood
timwood
  • 6 posts
Posted 28 March 2013 - 05:58 PM
Yup! Many times. Clear data each time I try. I just tried to "upgrade" (which was really a downgrade to an old version) smart actions and then "removing updates" to restore the app back to stock. This also did not help. I just keep getting:
Then I follow the Smart Action steps and after pressing enter get:
Later after "Cleaning up..." I get:
#508 timwood
timwood
  • 6 posts
Posted 28 March 2013 - 06:01 PM
Are there any alternate root methods anyone is aware of?
#509 peacekeeper293
peacekeeper293
  • Current Device(s):Droid 4
Posted 29 March 2013 - 05:26 AM
I am trying to root my Droid 4 with Razr blade and its giving me " ADB " file is not recognized .. How would I get past this??
Thanks Paul
#510 finka
finka
  • 20 posts
Posted 29 March 2013 - 06:13 AM
#511 finka
finka
  • 20 posts
Posted 29 March 2013 - 06:23 AM
This is far as it gets. Waited about 15 minutes. Any suggestions :
[*] is connected via USB.
[*] Waiting for device...
#512 robocuff
robocuff
  • 415 posts
Posted 29 March 2013 - 07:04 AM
Thanks Paul
Most likely you aren't unzipping the file when you run it. Unzip the entire contents of the zip to a folder of your choice and then run the .bat file from that folder.
#513 Jimbodogg
Jimbodogg
  • 6 posts
  • Current Device(s):Droid RAZR Maxx
Posted 29 March 2013 - 07:46 AM
So I thought I had uninstalled Boot Menu Manager, since that will conflict with SafeStrap starting up. However, apparently I didn't. The app is uninstalled by just going into apps and choosing manage apps and uninstalling, but when I reboot, Boot menu is still there with options. How can I cleanly uninstall it?
edit: found out how, had to reinstall BMM and uninstall using it's built in "installer" feature. Manged to install SafeStrap from here and am currently backing up my Razr!!
#514 Guest_BDH_*
Guest_BDH_*
Posted 29 March 2013 - 12:15 PM
Good stuff, glad you got your phone going again!
#515 sibujacob
sibujacob
  • 7 posts
  • Locationkuwait
  • Current Device(s):XT910
Posted 30 March 2013 - 01:06 AM
Hi Buddy
Guess what my XT910 shows the following symtoms while applying your tool. I have neatly workng Jelly bean 4.1.2 !
[*] Phase one...
link failed File exists
[*] Rebooting device...
[*] Phase two...
.jar: Permission denied
[*] 2. Select "Get Started".
[*] 4. Select "Save".
[*] 5. Press the Home button.
678 KB/s (3477 bytes in 0.005s)
arJarDex.jar: Permission denied
/system/bin/sh: can't create /data/dontpanic/apanic_console: Permission denied
[*] Phase four...
3905 KB/s (91992 bytes in 0.023s)
4250 KB/s (1867568 bytes in 0.429s)
4215 KB/s (574184 bytes in 0.133s)
3666 KB/s (63838 bytes in 0.017s)
[*] Cleaning up...
failed on '/data/logger.bak' - No such file or directory
ANY ADVICE ??.... I badly need to root the device.
#516 sibujacob
sibujacob
  • 7 posts
  • Locationkuwait
Posted 30 March 2013 - 01:07 AM
Hi Buddy
[*] Phase one...
[*] Phase two...
[*] Phase four...
[*] Cleaning up...
#517 gekko59
gekko59
Posted 30 March 2013 - 12:38 PM
As with others, I cannot seem to get the RAZR Blade app to root the phone. I got the OTA in March to an unrooted stock RAZR. I did not accept any Smart Actions updates (did not see any). I have cleared the Smart Actions data. I have USB Debugging enabled. USB connection is set to MTP (Media device) rather than Mass Storage.
As others show, I get this (pared down):
[*] 2. Select Get Started.
[*] 3. Select Battery Saver.
[*] 4. Select Save.
1468 KB/s (3477 bytes in 0.002s)
[*] Phase four...
2887 KB/s (543080 bytes in 0.183s)
2942 KB/s (1867568 bytes in 0.619s)
2913 KB/s (476557 bytes in 0.159s)
3038 KB/s (63838 bytes in 0.020s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
My question is: has the Smart Action exploit been closed with the official OTA push v 98.72.16.XT912.Verizon.en.US ?
#518 wainsie
wainsie
Posted 30 March 2013 - 02:18 PM
hi guys, have just purchased a razr, model xt910, and im trying to root it, it is running 4.1.2, have factory reset the phone, followed instructions to the letter and im getting the same error message everytime
[*] Device found.
[*] Phase one...
link failed Permission denied
[*] Phase two...
108 KB/s (3477 bytes in 0.031s)
[*] Phase four...
959 KB/s (91992 bytes in 0.093s)
2718 KB/s (1867568 bytes in 0.670s)
1497 KB/s (574184 bytes in 0.374s)
1332 KB/s (63838 bytes in 0.046s)
[*] Cleaning up...
[*] Rebooting...
has anyone got any idea how to solve this please
#519 Guest_BDH_*
Guest_BDH_*
Posted 30 March 2013 - 06:28 PM
Again, this is ONLY for the XT912, not GSM, not RAZR HD, nothing else. It even says it in the thread title guys.......... <_<
#520 peng
peng
  • LocationAZ, USA
  • Current Device(s):Razr Maxx, ASUS Transformer tf700
Posted 30 March 2013 - 07:07 PM
This made the difference from my linux machine as well. If you see three errors in Phase three referring to /data/logger, try this before doing the FDR.
Thanks to all on the forums for the help.
Thanks, this also worked for me using kubuntu! It had seemed to start trying to run the script before the phone had rebooted completely.
