#481
Posted 24 March 2013 - 07:29 PM
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
link failed File exists
[*] Rebooting device...
[*] Phase two...
.jar: Permission denied
[*] 2. Select "Get Started".
[*] 4. Select "Save".
[*] 5. Press the Home button.
282 KB/s (3477 bytes in 0.012s)
arJarDex.jar: Permission denied
/system/bin/sh: can't create /data/dontpanic/apanic_console: Permission denied
[*] Phase four...
274 KB/s (91992 bytes in 0.327s)
3315 KB/s (1867568 bytes in 0.550s)
3461 KB/s (574184 bytes in 0.162s)
3463 KB/s (63838 bytes in 0.018s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
#482
Posted 26 March 2013 - 02:16 PM
I just received the replacement but with it is a warning that if the hardware OR software was altered they can charge me up to $500.
The problem I have is that multiboot is still installed and I have no idea how to get rid of it. I'm sure all the problems with the new push update are related to Multiboot which, unfortunately, has no instructions whatsoever. I even wrote the developer and offered to pay for help in removing it but the developer hasn't responded.
I tried several times the razr blade exploit but have never gotten beyond the phase where I turn in battery saver in smart actions. I completely wiped my phone yet again (except for the unwipeable Multiboot which could cost me some serious money if I can't get rid of it) and I can't even get the phone to reboot the first time despite enabling USB debugging and media storage not MASS storage.
I desperately need help and am willing to make a decent donation or payment to whomever can help me get rid of multiboot in th next couple of days before Verizon charges me for the replacement phone. If I retrun the replacement and revert to the December 11 4.1.2 update, Verizon will continue to push the update .
Help, please!!
#483 Guest_BDH_*
Posted 26 March 2013 - 08:25 PM
Help, please!!
You need to use Matt's latest utility to fastboot to the stock JB 98.72.16 build. You can find it here:
This will get rid of everything on your phone and put you to stock JB.
#484
Posted 27 March 2013 - 02:05 AM
If you get errors the exploit will likely fail. Motorola has not patched it yet, though. I have all updates for smartactions already done on my phone but got it to work regardless of that by clearing the data for the app. That takes it back to the setup screen when you run it. Also, you have to set up the rule in smartactions at the time the script asks, not before. Once I did this, I had no errors in the script output.
#485
Posted 27 March 2013 - 07:19 AM
#486 Guest_BDH_*
Posted 27 March 2013 - 09:19 AM
Have I need ROOT or BMM to install other version of actual Android?
For example to:
replace "ICS Retail.EU.FR" to "ICS Vodafone.en.EU"
OR
replace "JB Retail.EU.FR" to "JB Vodafone.en.EU"
As entailed in the thread title, this for the XT912 ONLY. No other devices.
#487
Posted 27 March 2013 - 02:21 PM
I tried using CWM and apparently that won't work with Droid Razr Maxx at this time.
How do I go about installing and using SafeStrap? And once installed, how do I set up my back up using this new recovery?
#488
Posted 27 March 2013 - 02:53 PM
#489
Posted 27 March 2013 - 03:01 PM
Will this work for the RAZR MAXX HD?
Nope
#490
Posted 27 March 2013 - 03:10 PM
^^^^ HD Bounty Only or maybe other devices ^^^
#491
Posted 27 March 2013 - 03:33 PM
Can someone please walk me through this? Complete noob here. I've managed to root my droid razr maxx. but before I mess with anything I want to make sure I've backed up my files.
Okay, the Utility you want to use
- JellyBean XT912 All in One
- Now go Back to your Computer Desk Top...
- Should have your Utility Open ready for your Choices
- Then Chose # 3 for Safestrap...Once Installed
- Install Recovery...
- Couple of ways to get into Safestrap...
- Long Press the Power Button or
- Download the Quick Boot App...
- This will give you 4 options...
- Chose Recovery and this will bring you into Safestrap
- As it starts to boot you will see The M Red Logo...Once this goes by on to the Safestrap Red Screen hit the Menu button Now your in Safestrap..
- Note, it shows a Field Icon for Backup...after its completed Reboot...
- Thats it...If you decide to venture into using Slotted ROMs...Please READ all you can first...Just so you understand the process
Its Bubba
- tiebreaker likes this
#492
Posted 27 March 2013 - 09:32 PM
Good Luck but you'll be fine
- Should have your Utility Open ready to your Choices
Its Bubba
Thanks bubba, I managed to download Safestrap using the utility, however, I still can't get into recovery mode for some reason. Even with the Quick boot app. it restarts my phone and brings me to the android with a red triangle and exlamation point and doesn't do anything.
I should also add that I have Boot Manager so on loadup I see an android with clockwork on it. When I tap the screen I get several options, one of which is recovery. I tapped this and it started a screen with "spyder" and "CWM" which I thought didn't work on the maxx, I clicked backup from there and chose full system backup. Am I all backed up? and if so, where is the file and how do I activate it if I brick? I'm confused as to if I even need safestrap or not now
#493 Guest_BDH_*
Posted 27 March 2013 - 09:53 PM
When you see this ^^^^ you need to press both volume buttons at the same time. That will get you into stock e3 recovery if that's what you're trying to get into?
#494
Posted 27 March 2013 - 09:59 PM
Trying to boot up SafeStrap recovery. I've gotten into stock recovery before, but that doesn't help me as far as backing up my ROM
#495 Guest_BDH_*
Posted 27 March 2013 - 10:05 PM
After reading your post again I found your issue. You can't run 2 recoveries. It needs to be one or the other. BMM will override Safestrap.
- The Persuader likes this
#496
Posted 28 March 2013 - 01:11 AM
Ok so I uninstalled BMM, tried using quick boot app to boot into recovery on SafeStrap, still shows up at broken android, all I'm able to get into is stock recovery. Shouldn't it automatically boot into safe strap?
edit: tried re-installing safestrap, gives me this message: [INSTALL_FAILED_ALREADY_EXISTS]
If safestrap already exists on my phone why wont it load? ugh this is frustrating, sorry about all the questions. I'm completely new to this, first time rooting a phone.
#497
Posted 28 March 2013 - 02:52 AM
Personally, now that you removed BMM...
Using the Utility again, just start over follow the steps given...This way everything is Cleaned and No conflicts...Do the neccessary Wipes...after you do the Process...
You should be Crusing the Boulevard with your Red 57 Chevy...
Its Bubba
#498
Posted 28 March 2013 - 03:52 AM
[*] Device found.
[*] Phase one...
[*] Phase two...
[*] Phase four...
[*] Cleaning up...
[*] Rebooting...
I have same prblem, please help to root the Razr, can't root after upgrade to 4.1.2
#499
Posted 28 March 2013 - 04:13 AM
The issue that I was having was that the RAZR Blade exploit was giving me the following errors when trying to root:
mkdir failed for /data/logger, File Exists
link failed File exisits
Device: Droid 4
Network: Verizon
System: XT894
Android version: 4.1.2
What I did to solve the problem:
-Settings > Apps > Smart Actions > Clear data
-Settings > Storage > ≡ Button > USB computer connection > Select "Media device (MTP)
-Ran the exploit again. Went through with no errors. Upon reboot I had root access.
After I had root access, I went back to the USB computer connection and changed back to Mass Storage mode.
Thanks for all of the help you guys gave me. I really appreciate it!
#500
Posted 28 March 2013 - 07:40 AM
Its Bubba
What do steps 1 and 2 do? I had found the link to root my phone seperately so that's how I got it done prior to this thread. My phone was already on JB 4.1.2 from the OTA
