684 replies to this topic
#441 SkooterMcGaven
SkooterMcGaven
Posted 21 March 2013 - 02:36 PM
When I clear the cache and data from Smart Actions and I go to complete the steps the only option is to set a custom and I can't complete the steps. Sorry if I missed the resolution somewhere.
#442 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 21 March 2013 - 02:44 PM
There are sample ones somewhere. Maybe hit menu.
#443 SkooterMcGaven
SkooterMcGaven
Posted 21 March 2013 - 03:14 PM
Doesn't seem to matter what I do, get the same errors everytime. Was rooted before I got the 4.1.2 update but for whatever reason this just isn't working
#444 Bratster2
Bratster2
    IDK what I am
  • 560 posts
  • LocationCalifornia
  • Current Device(s):Pixel 2 XL on Google Fi
Posted 21 March 2013 - 04:20 PM
Edit: multi quote seems to have failed me
"quote name='Tick' timestamp='1363895844' post='232223']I Would Like To Thank all of you hard working and Talented individuals who made this happen Ive never rooted a ph but im gonna try it And go from there one question is it ok to have app 3 rd party or does it have to be totally Factory Blan? Any imput would be very helpfull Ty in advance ... Tick"
I would love to help but I just tried to make sense of that for 10 minutes and failed. I have no clue what you are asking. :blink:
My guess would be he is wanting to know if it will work if there are 3rd party apps installed or if it has to be factory blank.
#445 Memnoch73
  • 5,016 posts
Posted 21 March 2013 - 04:26 PM
Ahhh... You could be right. As far as I know it should work fine.
#446 Tick
Tick
Posted 21 March 2013 - 04:29 PM
what i meant by that was can you have apps on your device and still root or does the device have to be factory "stock"/
#447 Tick
Tick
Posted 21 March 2013 - 04:30 PM
Yes That Is exactly what i ment
#448 Memnoch73
  • 5,016 posts
Posted 21 March 2013 - 04:34 PM
Best you can do is try it. If you follow the instructions to a T then it should work however some people have no been able to do it and have HAD to factory reset/Fastboot back to stock and then it works. We always try to cover all the issues and try and get it to work first. Fastboot is the last ditch option
#449 Brbballin
Brbballin
Posted 21 March 2013 - 04:37 PM
Very frustrated. Tried everything in the thread except reset which I really don't want to do. Can't uninstall any smart action updates cause its not even an option. Can't update it either. Don't know whats wrong. All drivers are up to date. And yes I have 4.1.2
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
link failed No such file or directory
[*] Rebooting device...
[*] Phase two...
.jar: No such file or directory
[*] 2. Select "Get Started".
[*] 4. Select "Save".
[*] 5. Press the Home button.
848 KB/s (3477 bytes in 0.004s)
arJarDex.jar: No such file or directory
link failed File exists
[*] Phase four...
4990 KB/s (91992 bytes in 0.018s)
4824 KB/s (1867568 bytes in 0.378s)
4215 KB/s (574184 bytes in 0.133s)
4452 KB/s (63838 bytes in 0.014s)
[*] Cleaning up...
failed on '/data/logger.bak' - No such file or directory
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
getting these exact things when trying to root my phone, any help is appreciated
#450 Memnoch73
  • 5,016 posts
Posted 21 March 2013 - 04:40 PM
As long as you have clear SA data, USB debugging on, MTP USB mode. If you are still getting errors you will need to Fastboot back to stock before rooting. Sorry guys.
#451 Brbballin
Brbballin
Posted 21 March 2013 - 04:51 PM
SA, as in wipe cache partition? correct?
#452 Memnoch73
  • 5,016 posts
Posted 21 March 2013 - 05:01 PM
Clear data of the smart actions app in manage apps
#453 mrwebguy
mrwebguy
Posted 21 March 2013 - 06:05 PM
This is also my problem. I cannot uninstall SA updates; I dont have an option to do that. I have cleared the SA cache, but i fear my version of SA "updated today" my have a fix applied.
what are my options?? Any advice is greatly appriciated...
#454 Memnoch73
  • 5,016 posts
Posted 21 March 2013 - 06:16 PM
What do you mean smart actions updated today? From the play store? Or from installing JB OTA?? Did you clear DATA on SA?? All else fails you can use the Utility posted a couple above to fastboot back to stock and then immediately root
#455 mrwebguy
mrwebguy
Posted 21 March 2013 - 06:24 PM
Yes, from the Play store. I have cleared the cache. still fails....
#456 mrwebguy
mrwebguy
Posted 21 March 2013 - 06:31 PM
Im sorry I cannot find fastboot stuff, although I think thats what I did to get OTA JB to install. So.... if I go back to ICS, and re-root with the popular method, how do I keep it during upgrade to JB? Thanks!!
#457 Memnoch73
  • 5,016 posts
Posted 21 March 2013 - 06:35 PM
Use this Utility
. Do option 1 and wipe data. This will put you on Fresh JB. After setting up phone, do not log in to Google. Run the root option in the Utility.
#458 SkooterMcGaven
SkooterMcGaven
Posted 21 March 2013 - 06:48 PM
Well had to do it and do a wipe, worked perfect after that. Not sure what the issue was before that. Thanks!!!
#459 Tick
Tick
Posted 21 March 2013 - 07:09 PM
Well Guys It Apparently Doesnt Matter if you have Apps or not The Code WORKS I even Unplugged the USB Connection ( I WOULD NOT RECOMMEND ) but I was Testing the USB Options to make sure they Worked Correctly and Didnt Remember if I Had it On the Correct USB Option I Just Started Over REALLY HUGE SHOUT OUT To Dan Rosenberg That Man Knows His S*!T TY SIR !!
Cool Can Anyone Help Me Out With a Link To VooDoo and Straps?? B)
#460 Memnoch73
  • 5,016 posts
Posted 21 March 2013 - 07:39 PM
Glad you got it man. Use the Utility in my post above #458
