684 replies to this topic
#421 FcHsChilD
FcHsChilD
  • 86 posts
  • LocationWellington
Posted 20 March 2013 - 04:25 AM
Is there a way to downgrade to ICS and root again?
As far as I know, no there is not.
#422 nickap
nickap
Posted 20 March 2013 - 04:30 AM
I factory data reset doesn't mess with the system partition so you will not lose root when you do it. I would try a reset first and see if it clears up your issues. If not then we can talk about reapplying the leak.
Hi! im more or less in the same possition as detonation... i had some issues while rooted and now i want to re-root from the begining but i cant seem to. ive tried everything! factory reset, wipe data/cache, even tried reinstalling the OTA but nothing. superuser and its binaries are still present in the system.... do you have any idea how to proceed? pm if you like! cheers for your great work!
edit: i just realised that it doesnt work for xt910. so ill wait for the xt910 root! thanks!
#423 jayryan84
jayryan84
  • 12 posts
  • LocationCentral NJ
Posted 20 March 2013 - 06:13 PM
Could not get any easier... thanks!
#424 djwayt11
djwayt11
  • Google+:djwayt11@gmail.com
  • LocationIdaho
  • Current Device(s):Razr
Posted 20 March 2013 - 07:21 PM
Mine will not go past where it says "Daemon Started Successfully" I made sure to follow all the steps on the download plus all the steps for connecting the device but no luck any help?
#425 SkooterMcGaven
SkooterMcGaven
Posted 20 March 2013 - 07:58 PM
Very frustrated. Tried everything in the thread except reset which I really don't want to do. Can't uninstall any smart action updates cause its not even an option. Can't update it either. Don't know whats wrong. All drivers are up to date. And yes I have 4.1.2
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
link failed No such file or directory
[*] Rebooting device...
[*] Phase two...
.jar: No such file or directory
[*] 2. Select "Get Started".
[*] 4. Select "Save".
[*] 5. Press the Home button.
848 KB/s (3477 bytes in 0.004s)
arJarDex.jar: No such file or directory
link failed File exists
[*] Phase four...
4990 KB/s (91992 bytes in 0.018s)
4824 KB/s (1867568 bytes in 0.378s)
4215 KB/s (574184 bytes in 0.133s)
4452 KB/s (63838 bytes in 0.014s)
[*] Cleaning up...
failed on '/data/logger.bak' - No such file or directory
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
#426 Luckster
Luckster
  • 31 posts
  • Twitter:@TreatnHerRight
Posted 21 March 2013 - 05:28 AM
I know im very late to this but just to be 100% sure.
Im on System Version 98.72.16.XT912.Verizon.en.US
This is what i would use to root my device am i right?
Posted Image @TreatnHerRight
#427 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 21 March 2013 - 05:39 AM
yes. Be sure to clear data on the smart actions app prior to running
  • mercon likes this
#428 Luckster
Luckster
  • 31 posts
Posted 21 March 2013 - 05:56 AM
Settings-Apps-All-SmartActions(version 4.2.2.4.2)-Clear Data
Is that all? Sorry for bugging just wanting to make sure everything goes right.
#429 Memnoch73
  • 5,016 posts
Posted 21 March 2013 - 05:58 AM
You got it man. :)
  • Luckster likes this
#430 jbthuis
jbthuis
  • Current Device(s):Razr Maxx
Posted 21 March 2013 - 10:52 AM
FYI - The batch file did not run on my WIn8 machine. (Updated Moto drives, able to read/write via USB, USB debug on, not in mass storage, etc.)
It got this far and then hung (It never found a device):
Switched to an XP machine and it ran perfectly! (Also with updated Moto drives, able to read/write via USB, USB debug on, not in mass storage, etc.)
Thought it might help someone else who is thinking of trying it on Win8.
#431 Guest_BDH_*
Guest_BDH_*
Posted 21 March 2013 - 11:01 AM
Works fine on my Win8 x64 machine.
#432 Tick
Tick
Posted 21 March 2013 - 11:57 AM
I Would Like To Thank all of you hard working and Talented individuals who made this happen Ive never rooted a ph but im gonna try it And go from there one question is it ok to have app 3 rd party or does it have to be totally Factory Blan? Any imput would be very helpfull Ty in advance ... Tick
#433 xsylus
xsylus
  • Twitter:xsylus_dev
Posted 21 March 2013 - 12:01 PM
Thanks for your awesome work! Is there any chance you could release a batch to root the Droid 4 which recently upgraded to Jelly Bean 4.1. For some reason Voodoo Root Keeper didn't work when I installed the 4.1 OTA.
#434 Memnoch73
  • 5,016 posts
I would love to help but I just tried to make sense of that for 10 minutes and failed. I have no clue what you are asking. :blink:
#435 Luckster
Luckster
  • 31 posts
Posted 21 March 2013 - 12:26 PM
-Make sure the phone IS NOT in mass storage mode
Does this mean i can pick Media device (MTP) or Camera (PTP)
Which is better to choose.
#436 Memnoch73
  • 5,016 posts
Posted 21 March 2013 - 12:28 PM
Either is fine
#437 BlueSun
BlueSun
Posted 21 March 2013 - 12:39 PM
I have a Droid RAZR with JB 4.1.2 (System ver 98.72.16). I plan to root the phone using RAZR Blade, which I have just downloaded. I'm ready to go, but have a question or two.
Does this install CWM Touch or SafeStrap 3 recovery s/w, or do I have to do that after I root?
#438 Luckster
Luckster
  • 31 posts
Posted 21 March 2013 - 12:44 PM
Thanks, ran into a problem it says "open smart actions" "Click Get started" "Click Battery Saver" "Click Save"
I go to get started and there is no battery saver button, only Custom. What do i do?
EDIT: I did clear the data. After i cleared again i tested and i see the correct button will try again.
#439 Luckster
Luckster
  • 31 posts
Posted 21 March 2013 - 01:02 PM
how long is "cleaning up" supposed to take?
EDIT: Screen just turning on and off still. (sorry i get nervous)
EDIT: After almost 15 minutes it reboots ^_^
#440 jdiercks
jdiercks
Posted 21 March 2013 - 02:26 PM
For those using the OSX / Mac script, I updated the razr_blade.sh file in order to get it to install. Like others in the group, I was getting the error that others have posted where the script would fail. Rather than perform a FDR i used it as a clue that perhaps the phone hadn't completely settled down yet when the script was trying to continue. So, my change was to change the Sleep command in the script from Sleep 40 to Sleep 80. After making this change, the script ran perfectly.
Hope this helps anyone with the problem on a Mac, although I suspect the same situation could apply for a PC.
This worked for me on Linux! Thanks scratchsf for the tweak.
