#381 Guest_pmhvldsk_*
Posted 15 March 2013 - 03:19 AM
it doesn't work for me,so does it work for xt910 razr (europe)? i tried almost everything and i always got :
[*] is connected via USB.
Appuyez sur une touche pour continuer...
[*] Waiting for device...
[*] Device found.
[*] Phase one...
link failed Permission denied
[*] Rebooting device...
[*] Phase two...
.jar: Permission denied
[*] 2. Select "Get Started".
[*] 4. Select "Save".
[*] 5. Press the Home button.
678 KB/s (3477 bytes in 0.005s)
arJarDex.jar: Permission denied
/system/bin/sh: can't create /data/dontpanic/apanic_console: Permission denied
[*] Phase four...
2897 KB/s (91992 bytes in 0.031s)
3080 KB/s (1867568 bytes in 0.592s)
2607 KB/s (574184 bytes in 0.215s)
3116 KB/s (63838 bytes in 0.020s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
Thank you
#382
Posted 15 March 2013 - 07:47 AM
#383
Posted 15 March 2013 - 08:51 AM
- hamood likes this
#384
Posted 15 March 2013 - 09:03 AM
so i just tried rooting my razr maxx which updated to jelly bean yesterday but the code reached a point where it displays
and now it just paused and hasn't done anything else... how can i stop it and try it again? or what else should i do?
Update (or install) the Motorola drivers on your computer. I was stuck there too until I did that.
Here's the link for the drivers:
Hope this helps. I'm actually rooting now, but I got past the 'daemon' part and am on phase three now.
#385
Posted 15 March 2013 - 09:08 AM
Off to delete some bloatware and get wi-fi tether back. If that works, I'm ecstatic.
#386
Posted 15 March 2013 - 10:26 AM
#387
Posted 15 March 2013 - 12:18 PM
#388
Posted 16 March 2013 - 06:02 AM
#389
Posted 16 March 2013 - 06:20 AM
I just updated by OS to V4.1.2 However I get the following error during my root process "failed on '/data/logger' - Permission denied". I still do not have root. Any help with this?
Did you clear data in the smart actions app??
#390
Posted 16 March 2013 - 07:04 AM
#391
Posted 16 March 2013 - 07:06 AM
access to razrblade page from link - Access Denied, File not found errors @ 1130am
Huh? Are you talking about the download links?? I just downloaded all 3 version without issue
#392
Posted 16 March 2013 - 07:16 AM
I have windows- other version links work fine-hmmmmmm- maybe overloaded?
Forbidden
You don't have permission to access /public/razr_blade.zip on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
#393
Posted 16 March 2013 - 07:40 AM
- Memnoch73 likes this
#394
Posted 16 March 2013 - 09:38 AM
#395
Posted 16 March 2013 - 10:04 AM
Im doing this ATM and im at phase 4 at the point where it says "cleaning up", it has been at this step for nearly 10 mins, is this normal?
Check your phone and allow root permissions.
#396
Posted 16 March 2013 - 04:32 PM
We just recently received an OTA update to JB
#397 Guest_BDH_*
Posted 16 March 2013 - 07:50 PM
Sorry guys, but would this work on Motorola Electrify 2?
No, definitely would not.
#398
Posted 17 March 2013 - 11:15 AM
#399
Posted 17 March 2013 - 12:38 PM
#400
Posted 17 March 2013 - 01:18 PM
can something be done on the european xt910. I messed up my root backup and I cant root my jb
same here
