684 replies to this topic
#321 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Posted 06 March 2013 - 05:39 PM
got it. missed the cmd.exe step before running the root. thanks
Always Welcome! :)
Site Rules and Guidelines
#322 rcji
rcji
Posted 07 March 2013 - 06:06 PM
Does this work for the new official Jelly Bean build?
#323 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 07 March 2013 - 06:09 PM
Yes
Edit: for smart actions to work you need to clear data for that app in manage apps then uninstall updates.
#324 rcji
rcji
Posted 07 March 2013 - 06:59 PM
Yes
Thank you for the reply. I already tried it out and it worked great. I didn't have to do that for smart actions though. I just used one of the following options when prompted and everything worked out still.
  • Memnoch73 likes this
#325 jjuanico73
jjuanico73
  • 32 posts
  • LocationAlbuquerque, New Mexico
  • Current Device(s):Razr
Posted 08 March 2013 - 01:44 PM
What do you mean used one of the following options? This will work for? System:98.72.16.XT912.Verizon.en.US / Build:9.8.20-72_VZW-16
#326 Memnoch73
  • 5,016 posts
Posted 08 March 2013 - 02:09 PM
Yes this will work for the new JB. Not sure what he means about one of the following. Check it out and let us know if you run into problems
#327 jjuanico73
jjuanico73
  • 32 posts
Posted 08 March 2013 - 02:21 PM
I don't know if I have time now. I will on Monday though for sure. Thanks.
#328 razrmaxxing1
razrmaxxing1
  • Current Device(s):Razr Maxx
Posted 08 March 2013 - 06:58 PM
Sorry, Did a factory Data reset and all is better now.
Also, I've found that it doesn't matter if you have other smart actions enabled (it saved the ones i had through backup assistant), just so long as battery saver is enabled
Glad you got it figured out. A factory data reset usually fixes those issues. Enjoy!
Thanks, y'all!
I had the same problem - once I got to phase 3:
I too use a Mac, had ICS4.04 (rooted), upgraded to JB4.12, and applied the script. I got the same 'permission denied' error.
I'll do a factory reset and then restore my apps with Titanium... I miss having Avast firewall, and I bet the phone will run a lot faster too... :)
#329 razrmaxxing1
razrmaxxing1
Posted 08 March 2013 - 08:25 PM
NUTS!!
After a factory reset, I still got this...
bash razr_blade.sh
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
[*] Rebooting device...
[*] Phase two...
[*] 2. Select Get Started.
[*] 3. Select Battery Saver.
[*] 4. Select Save.
[*] 5. Press the Home button.
1491 KB/s (3477 bytes in 0.002s)
link failed File exists
[*] Phase four...
818 KB/s (91992 bytes in 0.109s)
3876 KB/s (1867568 bytes in 0.470s)
4497 KB/s (574184 bytes in 0.124s)
3308 KB/s (63838 bytes in 0.018s)
[*] Cleaning up...
Segmentation fault
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
The Jelly Bean update is slow as well, but I'm hoping that's because it's trying to restore apps in the background (which it was doing).
What else could be going wrong? I really want root back so I can freeze and get rid of bloatware trash again... :(
Thanks!
#330 razrmaxxing1
razrmaxxing1
Posted 08 March 2013 - 09:11 PM
Update:
I just ran the Windows version and there was no error of any sort shown in the script - yay!
I granted full root rights to Titanium, so - at least the Windows version - works with the RAZR.
From what I'd read on other forums, I wouldn't have been the first to do a factory reset -- and it never hurts to do, anyway...
But there could be a bug in the MacOS script...
#331 cmh714
Posted 11 March 2013 - 01:29 PM
Update:
The MacOS stuff works but is kludgy. I used it last night on a member that was having issues....I think we ran the utilities 4 or 5 times before everything went through fine.
#332 bl8demast3r
bl8demast3r
Posted 12 March 2013 - 10:23 AM
Can I disable the Battery Saver in SmartActions?
Also this won't hurt the OTA right?
#333 razrmaxxing1
razrmaxxing1
Posted 12 March 2013 - 12:20 PM
Thanks!
I ultimately reapplied JB onto my phone, after wiping the cache partition and re-rooting on my Windows machine. (the funny part is, despite doing a factory reset as well, some of my data still existed after the reinstall was done. I didn't see Android's auto-app reinstall take place, nor did I reinstall data with Titanium... Titanium did say my Android ID change, so I had it revert my ID to the original one. I've too many paid-for apps to take that risk...
So far it's working a lot better, though Chrome is laggy and battery-guzzling at times - but it's nothing like the complete system-wide lag I had before...
My CPU monitor programs still can't determine which process uses how much CPU time, but that's minor. The general reading of CPU usage is between 2 and 8% (as opposed to 50~90%).
#334 SpeKtroNet
SpeKtroNet
  • LocationOC
Posted 12 March 2013 - 01:04 PM
YESS!!
Thanks Mr. Rosenberg!
-=Razr=-
#335 Nockz
Nockz
  • 9 posts
  • LocationPlauen [Germany]
  • Current Device(s):RAZR
Posted 12 March 2013 - 02:42 PM
EDIT: Wrong Thread...
#336 whitemike358
whitemike358
  • 5 posts
  • LocationGeorgia
  • Current Device(s):og razr
Posted 12 March 2013 - 05:41 PM
I Can'T Get This To Work
#337 Memnoch73
  • 5,016 posts
Posted 12 March 2013 - 05:46 PM
We can only help if you give us a bit more info. :D
#338 whitemike358
whitemike358
  • 5 posts
  • LocationGeorgia
Posted 12 March 2013 - 05:48 PM
I Installed The Ota This Morning And Tonight Tried The Razr Blade Utility. The superSU APp Installed But When I Try To Open It It Tells Me "There Is No SU Binary Installed, And superSU Cannot Install It. This Is A Problem!" I Also Cannot Unistall The superSU App. I Checked With Root Checker And I Do Not Have Root. Is It Safe To Try Again With That App Still Installed? I'm Pretty Sure I Followed All The Steps Correctly. Any Help Would Be Greatly Appreciated.
#339 Memnoch73
  • 5,016 posts
Posted 12 March 2013 - 05:51 PM
Yup you're safe to run it again.
#340 whitemike358
whitemike358
  • 5 posts
  • LocationGeorgia
Posted 12 March 2013 - 05:54 PM
Any Suggestions Before I Do It Again? IT doesn'T Say I Have Any Updates For Smart Actions Installed, And I Cleared The Data For It. I Can't Think Of Anything Else.
