684 replies to this topic
#301 davian2012
davian2012
  • 7 posts
  • Current Device(s):droid razr xt912 verizon
Posted 02 March 2013 - 05:00 AM
Good job... success to Root
But I have problem now...
My droid Razr always shows ap fastboot failure..
How can I fix this???
Need help!!
#302 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 02 March 2013 - 05:02 AM
Need help!!
Search for the boot logo utility and flash one of them. You can also flash a empty radio image but the boot logo changer is probably easier.
#303 davian2012
davian2012
  • 7 posts
Posted 02 March 2013 - 06:59 AM
have i to use bmm or safestrap to flash it?
#304 cmh714
Posted 02 March 2013 - 07:57 AM
Most of us dont use BMM in this forum, we use SS....so flash with SS, or youre on your own to some degree with BMM
#305 davian2012
davian2012
  • 7 posts
Posted 02 March 2013 - 08:15 AM
i have flashed empty radio with ss
but it didn't work...
i tried to use boot logo changer (rom tool box) but also nothing happen...
#306 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 02 March 2013 - 09:54 AM
You need to flash the empty radio in Fastboot mode not SS
#307 jwoe
jwoe
  • Current Device(s):Droid Razr, Bionic
Posted 02 March 2013 - 11:36 AM
Awesome. Worked beautifully first try. Thanks to Dan for the root and thanks to everyone else for your comments and tips. They greatly contributed to my success.
Only thing I can add that I haven't seen mentioned(could've missed it):To solve problem of Smart Action trying to auto update I put my phone in airplane mode during the root process.
#308 davian2012
davian2012
  • 7 posts
Posted 02 March 2013 - 03:49 PM
what is the tool to flash it in fastboot mode?...
directly from droid razr or using pc...
i have rsd lite installed on my pc
#309 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 02 March 2013 - 03:53 PM
I'm sorry I should have been more specific. I was half asleep when I was trying to help lol. I'll be home soon and I will post or get into chat to help you more.
#310 davian2012
davian2012
  • 7 posts
Posted 03 March 2013 - 01:05 AM
thanks tmyinc...
i'll wait your helping
#311 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 03 March 2013 - 01:41 AM
thanks tmyinc...
Sorry still not home. Try this utility to flash a custom boot logo. Will clear up the fastboot flash failure.
)#entry81261
Boot Logo Changer. Monkeymouth Edition (Edited 10-24-12)
#312 davian2012
davian2012
  • 7 posts
Posted 03 March 2013 - 02:13 AM
)#entry81261
thanks very much...it works...
my problem solved...
  • tmyinc likes this
#313 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 03 March 2013 - 02:27 AM
Awesome. Glad it worked. Plus you get a cool boot logo. Its a win win!
#314 davian2012
davian2012
  • 7 posts
Posted 03 March 2013 - 03:28 AM
yes bro...
my problem solved plus i get a new boot screen...
my droid razr is working properly...
#315 bubblyhobo
bubblyhobo
Posted 03 March 2013 - 10:45 AM
I'm sorry if someone else has posted this issue, but I'm too lazy to read all of the post. I unistalled all of the updates to smartactions like it was suggested by other posters, but i keep getting this error in phase 3
[*] Rebooting device...
link failed File exists
[*] Phase four...
851 KB/s (91992 bytes in 0.105s)
2958 KB/s (1867568 bytes in 0.616s)
2594 KB/s (574184 bytes in 0.216s)
800 KB/s (63838 bytes in 0.077s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
it says that it doesn't have the permissions to create data/logger directory. It also can not find the /system/bin/sh: su: directory. I am performing this on a Mac, but from what i see their shouldn't be any issues with this. I have the latest moto-drivers installed, and I am running 4.1.2 98.72.8.xt912.Verizon.en.US
i should've rooted before I installed the update, but i was impatient and thought i could just use this exploit to root afterwards. Does anyone know of a solution to this problem
#316 bubblyhobo
bubblyhobo
Posted 03 March 2013 - 11:03 AM
[*] Phase four...
[*] Cleaning up...
[*] Rebooting...
Sorry, Did a factory Data reset and all is better now.
Also, I've found that it doesn't matter if you have other smart actions enabled (it saved the ones i had through backup assistant), just so long as battery saver is enabled
#317 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 03 March 2013 - 02:14 PM
Glad you got it figured out. A factory data reset usually fixes those issues. Enjoy!
#318 eeisner
eeisner
Posted 06 March 2013 - 12:32 AM
would love some input here on my failed root. Was running SS3 with a very old JB rom on the ICS kernel, uninstalled SS3, fastbooted back to stock so I knew i was 100% stock. forgot to root before upgrading to the leaked JB. trying to root and get the following errors:
[*] Waiting for device...
[*] Device found.
[*] Phase one...
link failed No such file or directory
[*] Phase two...
.jar: No such file or directory
[*] 2. Select "Get Started".
[*] 4. Select "Save".
[*] 5. Press the Home button.
1131 KB/s (3477 bytes in 0.003s)
arJarDex.jar: No such file or directory
[*] Phase four...
4082 KB/s (91992 bytes in 0.022s)
3650 KB/s (1867568 bytes in 0.499s)
3315 KB/s (574184 bytes in 0.169s)
4153 KB/s (63838 bytes in 0.015s)
[*] Cleaning up...
[*] Rebooting...
Figured I'd ask y'all whats up before i go to a factory reset....
#319 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Posted 06 March 2013 - 03:44 AM
This should help
Site Rules and Guidelines
#320 eeisner
eeisner
Posted 06 March 2013 - 05:20 PM
This should help
got it. missed the cmd.exe step before running the root. thanks
