Link failed. No such file or directory.
There is a link in the OP of this
Posted 21 February 2013 - 03:25 PM
Posted 22 February 2013 - 07:25 PM
Posted 22 February 2013 - 08:42 PM
This method is for the JB leak (4.1.2) not ICS. Use Matt's utility to root that.I can't get this to work on my OG RAZR. I'm on 4.0.4 and 6.16.215.XT912
Posted 23 February 2013 - 08:44 AM
Posted 23 February 2013 - 08:46 AM
After I do that will it allow me to get the JB leak (4.1.2)?
Posted 23 February 2013 - 10:22 AM
Posted 23 February 2013 - 10:36 AM
Where can I get the JB Leak?
Posted 23 February 2013 - 03:08 PM
Posted 23 February 2013 - 03:51 PM
OUTSTANDING!! Work like a charm. Thanks tmyinc.
Posted 25 February 2013 - 05:11 PM
Posted 25 February 2013 - 05:21 PM
Now that I've successfully side loaded the JB OTA, Rooted using Dan's Razr_Blade and run TripleCore for a month, how do I go back? I want to remove root, remove Safestrap and just go back to the JB OTA as it was before Razr_Blade. I got my email last night from Motorola to join the Soak Test and I want to do it CLEAN! Any help would be appreciated...
Posted 26 February 2013 - 08:49 AM
Not really a "good" way to do this. Only thing I can think is to use Matt's Unbrick utility to essentially "soft brick" your phone and then re-install the JB leak. I don't really recommend this though as I don't want you to get to a place you cannot recover from.
Edit: maybe you can go back to your unsafe side(stock rom) and factory reset??
Posted 28 February 2013 - 08:51 AM
Posted 28 February 2013 - 05:16 PM
Posted 28 February 2013 - 05:21 PM
Posted 28 February 2013 - 05:23 PM
Posted 28 February 2013 - 05:24 PM
Posted 28 February 2013 - 05:29 PM
Posted 28 February 2013 - 09:04 PM
Posted 01 March 2013 - 06:43 AM
Didn't work for me..... oh well. I guess I'll just wait.
